Ik merk dat het aantal crc errors op mijn ATM interface nogal sterk omhoog loopt, terwijl die niet te zien zijn op de dsl interface. Opstelling is een Cisco 1841 met een WIC-1ADSL op een max 6 dyn. Ik heb al verschillende IOS versies getest.
Nog iemand met een Cisco die dit fenomeen ziet?
#sh int atm 0/0/0
ATM0/0/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
Description: POTS ADSL Wic to EDPNET
MTU 4470 bytes, sub MTU 4470, BW 640 Kbit, DLY 800 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 5d18h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 37
Queueing strategy: Per VC Queueing
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
3596706 packets input, 196594918 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 20309 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2202827 packets output, 276901258 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 unknown protocol drops
0 output buffer failures, 0 output buffers swapped out
#sh dsl interface
ATM0/0/0
Alcatel 20150 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'ALCB' 'ALCB'
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x00 0x0F
Capacity Used: 63% 72%
Noise Margin: 14.5 dB 15.0 dB
Output Power: 18.0 dBm 12.0 dBm
Attenuation: 14.0 dB 9.0 dB
Defect Status: None None
Last Fail Code: None
Selftest Result: 0x00
Subfunction: 0x15
Interrupts: 2651 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: embedded
Operation FW: embedded
SW Version: 3.8131
FW Version: 0x1A04
Interleave Fast Interleave Fast
Speed (kbps): 0 6144 0 640
Cells: 0 97601382 0 755102855
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Bit Errors: 0 0
BER Valid sec: 0 0
BER Invalid sec: 0 0
CRC errors op ATM interface Cisco
billeman
- Bedankt: 23 keer
Inderdaad, dit is een fenomeen dat zicht voordoet op een WIC-1ADSL.Siglo schreef:Ik merk dat het aantal crc errors op mijn ATM interface nogal sterk omhoog loopt, terwijl die niet te zien zijn op de dsl interface. Opstelling is een Cisco 1841 met een WIC-1ADSL op een max 6 dyn. Ik heb al verschillende IOS versies getest.
Ik heb hierdoor vroeger zelfs ooit een ticket geopend bij mijn provider.
Waarom het gebeurd weet ik niet, maar niks van aantrekken zolang er bij show dsl interface niet teveel crc fouten staan
