fritzbox tijd en datum instellen
- Bedankt: 103 keer
lolon4bam schreef:Inloggen op de FB >> Settings >> Timezone (zie ook manual)
via "FBEditor" moet het lukken; iemand een idee hoe ik een timeserver toevoeg?
Manueel kun je de tijd ook instellen via #83*hhmmDDMMYYYY*
- Bedankt: 103 keer
gevonden(of het werkt weet ik ng niet:)
**** FRITZ!Box Fon WLAN 7170 CONFIGURATION EXPORT
Password=$$$$TDZISOYVRD4XEF21YYU4GXBZ6G4MLRQ4UD64CSSGPXXPK4OQL5M1K4VBWSIVB3HAMWUZXLTDABUEVGYKBRWQG4MVJLRKPTMDBANVEGIA
FirmwareVersion=29.04.57
CONFIG_INSTALL_TYPE=ar7_8MB_xilinx_4eth_3ab_isdn_nt_te_pots_wlan_usb_host_25762
OEM=avme
Country=031
**** CFGFILE:ar7.cfg
* /var/flash/ar7.cfg
* Thu Aug 28 04:11:32 2008
ar7cfg {
mode = dsldmode_bridge;
tsdisabled = no;
igddenabled = yes;
igdd_control_enabled = yes;
wan_bridge_with_dhcpc = no;
wan_bridge_gateway = 192.168.0.5;
dhcpc_use_static_dns = yes;
ethmode = ethmode_bridge;
tcom_targetarch = no;
StatisticStartOfMonth = 1;
macdsl_override = 00:15:0C:BA:0A:19;
ethinterfaces {
name = "eth0";
dhcp = no;
ipaddr = 192.168.0.100;
netmask = 255.255.255.0;
dstipaddr = 0.0.0.0;
dhcpenabled = yes;
dhcpstart = 192.168.0.6;
dhcpend = 192.168.0.99;
name = "eth0:0";
dhcp = no;
ipaddr = 169.254.1.1;
netmask = 255.255.0.0;
dhcpenabled = yes;
dhcpstart = 0.0.0.0;
dhcpend = 0.0.0.0;
name = "usbrndis";
dhcp = no;
ipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
ipaddr = 192.168.182.1;
interfaces = "tiwlan0", "wdsup0", "wdsdw0", "wdsdw1",
"wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
interfaces = "eth0", "usbrndis", "tiwlan0", "wdsup0",
"wdsdw0", "wdsdw1", "wdsdw2", "wdsdw3";
dhcpenabled = yes;
name = "lan:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface {
name = "dsl";
dhcp = no;
ipaddr = 169.254.2.1;
netmask = 255.255.255.255;
dstipaddr = 169.254.2.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface_metric = 2;
ipbridge {
enabled = no;
pppoefw {
interfaces = "lan", "usbrndis", "eth0", "wlan";
nofirewall = yes;
ipnetbiosfilter = yes;
dnsfilter_for_active_directory = yes;
hostuniq_filter = "";
dpconfig {
security = dpsec_host;
lowinput {
policy = "reject";
accesslist =
"permit ip any any connection outgoing-related",
"permit ip any any connection incoming-related",
"permit icmp any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 169.254.0.0 255.255.0.0",
"reject udp any any range 161 162",
"reject udp any any eq 111";
shaper = "globalshaper";
budget {
Enabled = no;
Period = 2;
VolumeLow = 0;
VolumeHigh = 0;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 8;
VCI = 35;
traffic_class = atm_traffic_class_UBR;
pcr = 0;
scr = 0;
priority = 0;
dsl_encap = dslencap_pppoe;
ipbridgeing = no;
ipbridgeing_igmp = no;
pppoeforwarding = no;
connections = "internet", "voip";
mcupstream = "internet";
voip_forwardrules = "udp 0.0.0.0:5060 0.0.0.0:5060",
"tcp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078+32 0.0.0.0:7078";
tr069_forwardrules = "tcp 0.0.0.0:8089 0.0.0.0:8089";
dslifaces {
enabled = yes;
name = "internet";
dsl_encap = dslencap_inherit;
dslinterfacename = "dsl";
no_masquerading = no;
no_firewall = no;
pppoevlanauto = no;
pppoevlanauto_startwithvlan = no;
ppptarget = "internet";
etherencapcfg {
use_dhcp = no;
ipaddr = 192.168.0.5;
gateway = 192.168.0.100;
dns1 = 192.168.0.100;
dns2 = 192.168.0.100;
mtu = 0;
is_mcupstream = yes;
stay_always_online = yes;
only_route_when_connected = no;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 10m;
redial_after_limit_reached_variance = 5m;
redial_delay_after_low_error = 10s;
routes_only_for_local = no;
ripv2receiver_enabled = no;
dsldpconfig {
security = dpsec_firewall;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny udp any any eq 135",
"deny tcp any any eq 135",
"deny udp any any range 137 139",
"deny tcp any any range 137 139",
"deny udp any any range 161 162",
"deny udp any any eq 520",
"deny udp any any eq 111",
"deny udp any any eq 22289",
"deny udp any any eq 1710",
"deny udp any any eq 1048",
"deny udp any any eq 158",
"deny udp any any eq 515";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
forwardrules =
"tcp 0.0.0.0:12000 192.168.0.20:46640 0 # ";
enabled = yes;
name = "voip";
no_firewall = no;
pppoevlanauto = no;
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = no;
redial_limit = 3;
tcclassroutes = "sipdns", "sip", "rtp";
dsldpconfig {
lowinput {
policy = "permit";
accesslist = "permit udp any any",
"permit icmp any any",
"reject ip any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "$$$$JJYLN4EA1Y2IMEWOC6HWO6IVACPOQCJWENLAFKXQJKPLT3AAA";
passwd = "$$$$HJBU63BXZ6DALHI3XWOEOSKBFL4EPQVEPMU13DNAKI1KIIFPRLAX6AGAAA";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 0w;
bUseChargeInterval = no;
nChargeInterval = 1m;
no_lcpecho_disconnect = no;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
overwrite_dns1 = 192.168.0.5;
overwrite_dns2 = 192.168.0.5;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 0;
bProviderDisconnectPrevention = no;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 4;
bProviderDisconnectPreventionHourSet = yes;
passiv_on_outgoing = no;
name = "voip";
local {
username = "";
passwd = "";
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
overwrite_dns1 = 0.0.0.0;
overwrite_dns2 = 0.0.0.0;
dslglobalconfig {
autodetect = no;
autodetectparams {
nround = 2;
timeout = 3s;
npacket = 1;
pppoeiface = "eth0";
speed_in_netto = 3600;
speed_out_netto = 440;
manual_speed = yes;
connect_delay_when_synced = 3s;
default_tcom_vlan = 7;
templates {
VPI = 1;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa_llc;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 64;
manu = 0;
VPI = 8;
VCI = 36;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 9;
VCI = 35;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 33;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 1;
VCI = 50;
manu = 0;
VPI = 1;
VCI = 50;
manu = 0;
MaxDownstreamRate = 0;
MaxUpstreamRate = 0;
RFI = 0;
DownstreamBlackoutBandStart = 0;
DownstreamBlackoutBandEnd = 0;
ControlBitfield = 0;
DownstreamMarginOffset = 0;
DownstreamPcbOffset = 0;
UpstreamPcbOffset = 0;
DiagnosticEnabled = no;
shapers {
name = "globalshaper";
OutFragmentWhenVoIP = 0;
shaperconnection {
enabled = yes;
targets = "";
name = "Fritz!Box";
limiters {
name = "default-out";
bps_limit {
limit_total = 100;
limit_p0 = 0;
limit_p1 = 95;
limit_p2 = 95;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 3;
grouping_by_source_ip = no;
grouping_by_dest_ip = no;
grouping_by_source_port = no;
grouping_by_dest_port = no;
dynamic_balancing = no;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
shapeOutgoingOnIncomingCounters = no;
name = "default-in";
bps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 0;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
out_rules {
name = "fon-rtp";
filter = "tc:rtp,sip";
priority = 3;
limiters = "default-out";
name = "download-tcp-ack";
filter = "tc:tcp_ack";
priority = 2;
name = "dns";
filter = "tc:dns,sipdns,ntpdns,tr069dns";
priority = 1;
name = "http-requests";
filter = "tc:http_req,tr069";
priority = 1;
name = "pri-out";
filter = "tc:icmp";
priority = 1;
name = "default";
filter = "";
priority = 0;
in_rules {
name = "default";
filter = "";
priority = 0;
limiters = "default-in";
demasquerade = no;
RunVoIPDSLAutodetect = 0;
saved_non_ata_ip_config {
dns1 = 192.168.180.1;
dns2 = 192.168.180.2;
accesslist_version = 1;
servercfg {
hostname = "(none)";
dns1 = 192.168.0.5;
dns2 = 192.168.0.5;
websrv {
port = "80";
https_port = "";
read_timeout = 15m;
request_timeout = 30s;
keepalive_timeout = 5m;
nokeepalive = "*";
errordir = "/usr/lib/websrv/errors";
webdir = "/usr/www";
cgidir = "cgi-bin";
indexfn = "index.var", "index.htm", "index.html";
users {
username = "geen";
passwd = "$$$$BRQRHWZIQEYQFTHJ1T131ZNIHQNG4TRGQPQTBUX4EFMRRJF2D3LWSHM3EWTEALYQEPUURNQMK66LGAAA";
users_only_for_https = yes;
dhcpserver {
saveinterval = 1h;
generic {
default_lease_time = 10d;
max_lease_time = 13d;
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = yes;
domain = "$$$$FQFXFDI6JW2KA6VYNRUIYYJV5H2CJIVTYTZP5UP3EZPVB5GICICUQIFW4IA22SC1CSE2MYVZJIEXCIHATVFCNI3CAMW3FKMA4RBKO5JQ";
iface = 0;
username = "$$$$3KHRGEPUH3OWNTB3WSBNYMR1JDF1AWRXWX5AWSDXS5TZV3TL3N56VPU34CFLFLAMP3WXQOUX1PINIAAA";
passwd = "$$$$42FCIAO2DBAPQ6YNGQZY5EDFZKANKL5LZT61PVQL6AACUPUYPFOVREPPE4JYVHKX5I6LCERYYJXH1AAA";
ddnsprovider = "dyndns.org-statdns";
types {
type = "dyndns";
url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-custom";
url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-statdns";
url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "noip";
url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
type = "2mydns";
url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
type = "dns4biz";
url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
type = "selfhost";
url = "/nic/update?myip=<ipaddr>&host=<domain>&textmodi=1&http_status=1";
type = "strato";
url = "/nic/update?hostname=<domain>";
type = "userdefined";
url = "";
provider {
name = "dyndns.org";
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
server = "members.dyndns.org";
infourl = "http://www.dyndns.org/";
name = "dyndns.org-custom";
livedelay = 0w;
touchtime = 30d;
name = "dyndns.org-statdns";
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
server = "dynupdate.no-ip.com:8245";
infourl = "http://www.no-ip.com/";
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
server = "dyn.2mydns.com";
infourl = "http://www.2mydns.com/";
name = "DNS4BIZ.DE Premium";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.net";
infourl = "http://www.dns4biz.com/services_avm.php3";
name = "DNS4BIZ.DE Business";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.biz";
name = "selfhost.de";
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
server = "carol.selfhost.de";
infourl = "http://www.selfhost.de";
name = "STRATO AG";
type = "strato";
livedelay = 4m;
touchtime = 0w;
server = "dyndns.strato.com";
infourl = "http://www.strato.de/webhosting/index.html";
name = "User-defined";
livedelay = 4m;
touchtime = 0w;
server = "";
infourl = "http://";
webui {
username = "";
password = "";
expertmode = yes;
wizard_completed = no;
event_filter = 0;
read_access_without_login = no;
fminiframework {
enabled = no;
converted = yes;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
show_eventlist = yes;
show_voipstat = yes;
show_kidsstat = yes;
show_onlinecntstat = yes;
show_fonstat = yes;
usbhost {
readonly = no;
password = "";
autoprov_enabled = yes;
ftp_internet_enabled = no;
aura_enabled = no;
aura_config = 0;
ftp_server_enabled = yes;
samba_server_enabled = no;
night_time_control {
enabled = no;
time_on = "";
time_off = "";
ring_blocked = no;
ntpclient {
server_list = "ntp.belnet.be";
led {
infoled_reason = 0;
timezone_manual {
enabled = yes;
offset = -1;
dst_enabled = yes;
TZ_string = "XXX-2";
mrouter {
igmp_version_for_upstream = 3;
igmp_version_for_other = 3;
igmp_prio = 48;
rip {
cpu_schedule {
dsl_token = 5000;
lan_token = 20000;
media {
enabled = no;
max_entries = 5000;
TR_064 {
enabled = yes;
username = "dslf-config";
password = "$$$$6U3VQPJS14FGMCW1O4X1JT2PGQZ4M5XFUSD264PHRPTFX1VWSU4NNHVQHFEDDGDAV36KCN2SVMNDCAAA";
persistent_data = "";
landevices {
qos {
always_set_tos = no;
rules {
tcclass = "sip";
rules = "udp.dport 5060";
tcclass = "dns";
rules = "udp.dport 53";
tcclass = "http_req";
rules = "tcp.dport 80 ip.len <= 800",
"tcp.dport 8080 ip.len <= 800",
"tcp.dport 3128 ip.len <= 800";
tcclass = "tcp_ack";
rules = "ip.proto == tcp ip.len <= 64";
tcclass = "icmp";
rules = "ip.proto == icmp";
prios {
nqos {
ethernet_eco {
eth0_mode = 2;
eth1_mode = 1;
eth2_mode = 1;
eth3_mode = 1;
unattended_update {
update_found = no;
no_update_found_time = "1970-01-01 01:00:00";
avmlogd {
enabled = no;
// EOF
**** END OF FILE ****
**** CFGFILE:voip.cfg
* /var/flash/voip.cfg
* Wed Jan 5 02:57:40 2000
voipcfg {
dnsport = 7077;
rtpport_start = 7078;
sip_srcport = 5060;
ua1 {
enabled = yes;
username = "$$$$QDLDNBQS2VR6RXK2MB3J5RVTKBZCNSKSAXFMHVB5UPQUC6OVTLMSHIAAA";
authname = "$$$$X2WMQGUW5OPSHXP4W1Y42N2D4RAFP4QQWDGB5AAA";
passwd = "$$$$2QGGCE52FWXYSW2ZTCHYY5W3NROFIQMAWGFYZT5AKXO2CYXWAAA";
registrar = "sip.justvoip.com";
ttl = 30m;
sipping_enabled = yes;
sipping_interval = 280s;
name =
dtmfcfg = dtmfcfg_automatic;
register_failwaitmax = 30m;
stunserver = "stun.justvoip.com";
stunserverport = 3478;
use_internat_calling_numb = no;
is_nat_aware = yes;
localip = 0.0.0.0;
ignore_received_header = no;
clirtype = clir_display_and_username;
colptype = colp_none;
only_one_dialog = no;
presence_supported = no;
mwi_supported = yes;
reg_support = regsupport_auto;
tx_packetsize_in_ms = 20;
reject_refer = yes;
no_register_fetch = no;
do_not_register = no;
only_call_from_registrar = no;
outboundproxy = "sip.justvoip.com";
outboundproxy_without_route_header = no;
dditype = ddi_none;
ddireception = "";
backup_wanted = no;
use_session_timer = no;
use_rport = yes;
add_rtpmap_for_all_codecs = no;
answer_only_one_codec = no;
without_annexb_no = no;
srtp_supported = no;
use_488_for_no_t38 = no;
g726_via_rfc3551 = no;
ua2 {
enabled = yes;
username = "$$$$SWULWLQFXFDI6JW2
"$$$$2EIVQHOTJXTVRYUPCMI6IPMM3NYHIKVBBH2AEJNDIL1AJ3IAGCZMMXUIURF6B3EJATONIYAAA";
passwd = "$$$$IKIMHGVOS2TZL2WR1VGNSOAIFAPWQDQ42YYD5NLQTPTOUP2ENVVUNKB61NL4PSAAA";
registrar = "sip.smsdiscount.com";
ttl = 30m;
name =
stunserver = "";
is_nat_aware = yes;
localip = 0.0.0.0;
reject_refer = yes;
outboundproxy =
dditype = ddi_none;
ddireception = "";
backup_wanted = no;
use_rport = yes;
use_audiocodecs = no;
audiocodecs = "PCMA", "PCMU", "G726-32";
verbose = no;
sip_prio = 0;
rtp_prio = 0;
dyn_codecs = no;
prio_low_codec = no;
send_ringtone = no;
blacklist = no;
t38_support_enabled = yes;
enum_support_enabled = no;
bandwidth_to_leave_KBits = 0;
enumdomains = "e164.arpa", "e164.org";
rtpstream {
voice_activity_detection {
enabled = no;
vad_threshold = 10000;
plc {
in_the_stack = yes;
jitter {
auto_on = yes;
in_ms = 50;
in_packets = 0;
rtcp_enabled = yes;
voip_assi_enabled = no;
// EOF
**** CFGFILE:wlan.cfg
* /var/flash/wlan.cfg
* Fri Aug 22 05:07:42 2008
wlancfg {
ap_enabled = 1;
channel = 8;
channelwidth = 0;
ssid = "fritz";
hidden_ssid = 0;
power_level = 1;
bg_mode = 1;
user_isolation = 0;
encryption = 1;
passwd = "";
wep_auth_type = "open";
allowSharedKeyAuth = yes;
key_id = 0;
key_value0 = "$$$$G1DBFXLD6DPCXP3KRPZK1O5ZLI22HXO3T2BD6POWVDWW2IPDOY2MQ3WFPDUZVJLHLEYEBGE2WMYWY3J4";
key_len0 = 5;
key_value1 = "";
key_len1 = 5;
key_value2 = "";
key_len2 = 5;
key_value3 = "";
key_len3 = 5;
pskvalue = "$$$$Y4WVLWKLXDJCTZERWNXYGYFKLQKMKK5DFXWQSIXDS6M4RLY1A6H5F6OHL4EGCFLE4FR1P2XKIUU6M3J4";
interval = 3600;
turbomode = no;
WDS_enabled = no;
WDS_hop = 0;
WDS_mac_master = 00:00:00:00:00:00;
WDS_mac_slave0 = 00:11:50:D2:45:F5;
WDS_mac_slave1 = 00:00:00:00:00:00;
WDS_mac_slave2 = 00:00:00:00:00:00;
WDS_mac_slave3 = 00:00:00:00:00:00;
WDS_encryption = 0;
WDS_key = "";
night_time_control_enabled = no;
night_time_control_no_forced_off = no;
greenmode_enabled = no;
wmm_enabled = yes;
IPTVoptimize = no;
wireless_stickandsurf_enabled = yes;
tx_autopower = no;
autochannel_plus = no;
force_channel_conversion = no;
wps_mode = 0;
wps_pin = "";
// EOF
**** BINFILE:fx_cg
00000000000000000400000091113319010000000000000000000000000000000000000009000000
9111331A0100000000000000000000000000000000000B0003000000A153198A0100000000000000
000000000000000000000C000A000000512834198700000000000000000000000000000000000B00
0E000000213641770200000000000000000000000000000000000C000D0000005179621986000000
00000000000000000000000000000001000000005179621986000000000000000000000000000000
00000B0009000000213641770200000000000000000000000000000000000B000900000021364177
0200000000000000000000000000000000000B00D300000021364177020000000000000000000000
00000000000000011A000000000000000000000000000000000000000000000000000B0056000000
213641770200000000000000000000000000000000000B008C000000213641770200000000000000
00000000000000000000000116000000000000000000000000000000000000000000000000000001
0E000000000000000000000000000000000000000000000000000B003F0000002136417702000000
00000000000000000000000000000001270300000000000000000000000000000000000000000000
00000B00ED0000004143882507000000000000000000000000000000000000011700000000000000
00000000000000000000000000000000000000010E000000A1336945070000000000000000000000
0000000000000C000D000000517962198600000000000000000000000000000000000C001F000000
517962198600000000000000000000000000000000000B0027000000213641770200000000000000
000000000000000000000B0021000000213641770200000000000000000000000000000000000B00
1B000000213641770200000000000000000000000000000000000001940600000000000000000000
00000000000000000000000000000001130000000000000000000000000000000000000000000000
00000B0030000000A13343790100000000000000000000000000000000000B005A000000A1232266
0600000000000000000000000000000000000B005A000000A153198A010000000000000000000000
0000000000000B006501000021364177020000000000000000000000000000000000000132000000
000000000000000000000000000000000000000000000B0006040000A153198A0100000000000000
000000000000000000000C002300000051795454A600000000000000000000000000000000000001
0A0000005179621986000000000000000000000000000000000000010A0000005179621986000000
000000000000000000000000000000010A0000005179621986000000000000000000000000000000
0000000119000000517962198600000000000000000000000000000000000B00E2000000A1732217
02000000000000000000000000000000000000010000000000000000000000000000000000000000
0000000000000B003D000000213641770200000000000000000000000000000000000B001A000000
21364177020000000000000000000000000000000000000106010000000000000000000000000000
000000000000000000000B0011000000213641770200000000000000000000000000000000000C00
0A000000517962198600000000000000000000000000000000000C00090000005179621986000000
00000000000000000000000000000C00040000005179621986000000000000000000000000000000
00000000070000005179621986000000000000000000000000000000000000000900000051796219
86000000000000000000000000000000000000000D00000051796219860000000000000000000000
000000000000000004000000517962198600000000000000000000000000000000000C0004000000
517962198600000000000000000000000000000000000C0008000000517962198600000000000000
000000000000000000000C0005000000517962198600000000000000000000000000000000000C00
05000000517962198600000000000000000000000000000000000B007F050000A153198A01000000
00000000000000000000000000000C00030000005179621986000000000000000000000000050707
06000000000000000000000000000000000000000000000000000000000000000000000000000000
00000000000000000000000000000000000000000000000000000000000000000000000000000000
OEM=avme
Country=031
ar7cfg {
tsdisabled = no;
igddenabled = yes;
ethinterfaces {
name = "eth0";
dhcp = no;
dhcpenabled = yes;
name = "eth0:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "usbrndis";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
"wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
dhcpenabled = yes;
name = "lan:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface {
name = "dsl";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
ipbridge {
enabled = no;
pppoefw {
nofirewall = yes;
dpconfig {
lowinput {
policy = "reject";
accesslist =
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
budget {
Enabled = no;
Period = 2;
VolumeLow = 0;
VolumeHigh = 0;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 8;
VCI = 35;
pcr = 0;
scr = 0;
priority = 0;
ipbridgeing = no;
dslifaces {
enabled = yes;
name = "internet";
no_firewall = no;
pppoevlanauto = no;
etherencapcfg {
use_dhcp = no;
mtu = 0;
redial_limit = 3;
dsldpconfig {
lowinput {
policy = "permit";
accesslist =
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
forwardrules =
enabled = yes;
name = "voip";
no_firewall = no;
pppoevlanauto = no;
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
mtu = 0;
is_mcupstream = no;
redial_limit = 3;
dsldpconfig {
lowinput {
policy = "permit";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
targets {
name = "internet";
local {
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
name = "voip";
local {
username = "";
passwd = "";
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
dslglobalconfig {
autodetect = no;
autodetectparams {
nround = 2;
timeout = 3s;
npacket = 1;
manual_speed = yes;
templates {
VPI = 1;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 64;
manu = 0;
VPI = 8;
VCI = 36;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 9;
VCI = 35;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 1;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 33;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 1;
VCI = 50;
manu = 0;
VPI = 1;
VCI = 50;
manu = 0;
RFI = 0;
shapers {
shaperconnection {
enabled = yes;
targets = "";
name = "Fritz!Box";
limiters {
bps_limit {
limit_total = 100;
limit_p0 = 0;
limit_p1 = 95;
limit_p2 = 95;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 3;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
bps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 0;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
out_rules {
name = "fon-rtp";
priority = 3;
priority = 2;
name = "dns";
priority = 1;
priority = 1;
name = "pri-out";
filter = "tc:icmp";
priority = 1;
name = "default";
filter = "";
priority = 0;
in_rules {
name = "default";
filter = "";
priority = 0;
demasquerade = no;
servercfg {
dns1 = 192.168.0.5;
dns2 = 192.168.0.5;
websrv {
port = "80";
https_port = "";
read_timeout = 15m;
nokeepalive = "*";
cgidir = "cgi-bin";
users {
username = "geen";
dhcpserver {
saveinterval = 1h;
generic {
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = yes;
iface = 0;
types {
type = "dyndns";
type = "noip";
type = "2mydns";
type = "dns4biz";
type = "selfhost";
type = "strato";
url = "";
provider {
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
livedelay = 0w;
touchtime = 30d;
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
name = "STRATO AG";
type = "strato";
livedelay = 4m;
touchtime = 0w;
livedelay = 4m;
touchtime = 0w;
server = "";
webui {
username = "";
password = "";
expertmode = yes;
event_filter = 0;
fminiframework {
enabled = no;
converted = yes;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
show_fonstat = yes;
usbhost {
readonly = no;
password = "";
aura_enabled = no;
aura_config = 0;
enabled = no;
time_on = "";
time_off = "";
ring_blocked = no;
ntpclient {
led {
infoled_reason = 0;
timezone_manual {
enabled = yes;
offset = -1;
dst_enabled = yes;
mrouter {
igmp_prio = 48;
rip {
cpu_schedule {
dsl_token = 5000;
lan_token = 20000;
media {
enabled = no;
max_entries = 5000;
TR_064 {
enabled = yes;
landevices {
qos {
rules {
tcclass = "sip";
tcclass = "dns";
tcclass = "icmp";
prios {
nqos {
ethernet_eco {
eth0_mode = 2;
eth1_mode = 1;
eth2_mode = 1;
eth3_mode = 1;
unattended_update {
update_found = no;
avmlogd {
enabled = no;
// EOF
voipcfg {
dnsport = 7077;
sip_srcport = 5060;
ua1 {
enabled = yes;
ttl = 30m;
name =
is_nat_aware = yes;
localip = 0.0.0.0;
reject_refer = yes;
dditype = ddi_none;
ddireception = "";
backup_wanted = no;
use_rport = yes;
ua2 {
enabled = yes;
ttl = 30m;
name =
stunserver = "";
is_nat_aware = yes;
localip = 0.0.0.0;
reject_refer = yes;
outboundproxy =
dditype = ddi_none;
ddireception = "";
backup_wanted = no;
use_rport = yes;
verbose = no;
sip_prio = 0;
rtp_prio = 0;
dyn_codecs = no;
send_ringtone = no;
blacklist = no;
rtpstream {
enabled = no;
plc {
in_the_stack = yes;
jitter {
auto_on = yes;
in_ms = 50;
in_packets = 0;
rtcp_enabled = yes;
// EOF
wlancfg {
ap_enabled = 1;
channel = 8;
channelwidth = 0;
ssid = "fritz";
hidden_ssid = 0;
power_level = 1;
bg_mode = 1;
user_isolation = 0;
encryption = 1;
passwd = "";
key_id = 0;
key_len0 = 5;
key_value1 = "";
key_len1 = 5;
key_value2 = "";
key_len2 = 5;
key_value3 = "";
key_len3 = 5;
interval = 3600;
turbomode = no;
WDS_enabled = no;
WDS_hop = 0;
WDS_encryption = 0;
WDS_key = "";
wmm_enabled = yes;
IPTVoptimize = no;
tx_autopower = no;
wps_mode = 0;
wps_pin = "";
// EOF
**** BINFILE:fx_cg
- Bedankt: 3779 keer
- Recent bedankt: 20 keer
FritzBoxen zijn gemaakt in Duitsland, en in eerste instantie voor de Duitse markt .... Daar hebben de meeste mensen ISDN, of analoog met CLIP.silencer schreef:niet dus, na een restart ben je trouwens ook je manueel ingestelde tijd kwijt.
iemand een idee?
* Bij ISDN wordt een tijdsignaal gestuurd bij het einde van ieder gesprek.
* Bij analoog wordt de tijd meegestuurd als onderdeel van de CLIP informatie (tussen eerste en tweede belsignaal)
Dus als je FritzBox aangesloten is op je vaste lijn (ISDN of analoog + CLIP), dan zou in principe je tijd korrekt ingesteld moeten zijn ....
Verder maakt de FritzBox verbinding met een ntp server lijst (0.europe.pool.ntp.org), dus zou de tijd altijd goed moeten zijn. Ik heb verschillende Boxen lopen als ATA achter een router, en nog nooit problemen ondervonden ...
Philippe
- Bedankt: 103 keer
Het gaat hier wel over een gepatste box,het zal daardoor zijn.philippe.deleye schreef:FritzBoxen zijn gemaakt in Duitsland, en in eerste instantie voor de Duitse markt .... Daar hebben de meeste mensen ISDN, of analoog met CLIP.silencer schreef:niet dus, na een restart ben je trouwens ook je manueel ingestelde tijd kwijt.
iemand een idee?
Philippe
als ik op programs klik verschijnt er:
The Internet connection has been terminated. FRITZ!Box must be connected with the Internet to show the range of software products.
Ik stel het wel manueel in,alleen spijtig dat ik na een reboot het opnieuw moet instellen.
klopt: code om setings te saven is #91**silencer schreef:via een telefooncode kun je alle gemaakte settings saven.
maar of dit helpt om de tijd niet te verliezen bij een restart weet ik zo niet ...
Philippe.
- Bedankt: 103 keer
Het werkt in ieder geval, enkele keren gereboot, call list blijft correctphilippe.deleye schreef:klopt: code om setings te saven is #91**silencer schreef:via een telefooncode kun je alle gemaakte settings saven.
Philippe.
04.09.08 21:26 laatste call(na een reboot gepleegd).
