FLASH (.js) - links werken niet
Alles over programmeren en development binnen de IT-wereld
tammzak
Ik heb een .swf flash object gemaakt en het heeft dit ebstand nodig:AC_RunActiveContent.js, maar als ik er dan een link onder plaats, werken deze wel in mozilla firefox maar niet in internet explorer, iemand een oplossing voor dit?
AC_RunActiveContent.js Code. (gegenereerd door Flash CS3 met ActionScript 3.0)
// Copyright 2005-2007 Adobe Systems Incorporated.  All rights reserved.
var isIE  = (navigator.appVersion.indexOf("MSIE") != -1) ? true : false;
var isWin = (navigator.appVersion.toLowerCase().indexOf("win") != -1) ? true : false;
var isOpera = (navigator.userAgent.indexOf("Opera") != -1) ? true : false;
function ControlVersion()
	var version;
	var axo;
	var e;
	// NOTE : new ActiveXObject(strFoo) throws an exception if strFoo isn't in the registry
	try {
		// version will be set for 7.X or greater players
		axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
		version = axo.GetVariable("$version");
	} catch (e) {
	if (!version)
		try {
			// version will be set for 6.X players only
			axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
			// installed player is some revision of 6.0
			// GetVariable("$version") crashes for versions 6.0.22 through 6.0.29,
			// so we have to be careful.
			// default to the first public version
			version = "WIN 6,0,21,0";
			// throws if AllowScripAccess does not exist (introduced in 6.0r47)
			axo.AllowScriptAccess = "always";
			// safe to call for 6.0r47 or greater
		} catch (e) {
	if (!version)
		try {
			// version will be set for 4.X or 5.X player
			axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.3");
		} catch (e) {
	if (!version)
		try {
			// version will be set for 3.X player
			version = "WIN 3,0,18,0";
		} catch (e) {
	if (!version)
		try {
			// version will be set for 2.X player
			axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
			version = "WIN 2,0,0,11";
		} catch (e) {
			version = -1;
	return version;
// JavaScript helper required to detect Flash Player PlugIn version information
function GetSwfVer(){
	// NS/Opera version >= 3 check for Flash plugin in plugin array
	var flashVer = -1;
	if (navigator.plugins != null && navigator.plugins.length > 0) {
		if (navigator.plugins["Shockwave Flash 2.0"] || navigator.plugins["Shockwave Flash"]) {
			var swVer2 = navigator.plugins["Shockwave Flash 2.0"] ? " 2.0" : "";
			var flashDescription = navigator.plugins["Shockwave Flash" + swVer2].description;
			var descArray = flashDescription.split(" ");
			var tempArrayMajor = descArray[2].split(".");
			var versionMajor = tempArrayMajor[0];
			var versionMinor = tempArrayMajor[1];
			var versionRevision = descArray[3];
			if (versionRevision == "") {
				versionRevision = descArray[4];
			if (versionRevision[0] == "d") {
				versionRevision = versionRevision.substring(1);
			} else if (versionRevision[0] == "r") {
				if (versionRevision.indexOf("d") > 0) {
					versionRevision = versionRevision.substring(0, versionRevision.indexOf("d"));
			var flashVer = versionMajor + "." + versionMinor + "." + versionRevision;
	// MSN/WebTV 2.6 supports Flash 4
	else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.6") != -1) flashVer = 4;
	// WebTV 2.5 supports Flash 3
	else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.5") != -1) flashVer = 3;
	// older WebTV supports Flash 2
	else if (navigator.userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 2;
	else if ( isIE && isWin && !isOpera ) {
		flashVer = ControlVersion();
	return flashVer;
// When called with reqMajorVer, reqMinorVer, reqRevision returns true if that version or greater is available
function DetectFlashVer(reqMajorVer, reqMinorVer, reqRevision)
	versionStr = GetSwfVer();
	if (versionStr == -1 ) {
		return false;
	} else if (versionStr != 0) {
		if(isIE && isWin && !isOpera) {
			// Given "WIN 2,0,0,11"
			tempArray         = versionStr.split(" "); 	// ["WIN", "2,0,0,11"]
			tempString        = tempArray[1];			// "2,0,0,11"
			versionArray      = tempString.split(",");	// ['2', '0', '0', '11']
		} else {
			versionArray      = versionStr.split(".");
		var versionMajor      = versionArray[0];
		var versionMinor      = versionArray[1];
		var versionRevision   = versionArray[2];
        	// is the major.revision >= requested major.revision AND the minor version >= requested minor
		if (versionMajor > parseFloat(reqMajorVer)) {
			return true;
		} else if (versionMajor == parseFloat(reqMajorVer)) {
			if (versionMinor > parseFloat(reqMinorVer))
				return true;
			else if (versionMinor == parseFloat(reqMinorVer)) {
				if (versionRevision >= parseFloat(reqRevision))
					return true;
		return false;
function AC_AddExtension(src, ext)
  if (src.indexOf('?') != -1)
    return src.replace(/\?/, ext+'?');
  else
    return src + ext;
function AC_Generateobj(objAttrs, params, embedAttrs)
  var str = '';
  if (isIE && isWin && !isOpera)
    str += '<object ';
    for (var i in objAttrs)
      str += i + '="' + objAttrs[i] + '" ';
    str += '>';
    for (var i in params)
      str += '<param name="' + i + '" value="' + params[i] + '" /> ';
    str += '</object>';
  else
    str += '<embed ';
    for (var i in embedAttrs)
      str += i + '="' + embedAttrs[i] + '" ';
    str += '> </embed>';
  document.write(str);
function AC_FL_RunContent(){
  var ret =
    AC_GetArgs
    (  arguments, ".swf", "movie", "clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
     , "application/x-shockwave-flash"
  AC_Generateobj(ret.objAttrs, ret.params, ret.embedAttrs);
function AC_SW_RunContent(){
  var ret =
    AC_GetArgs
    (  arguments, ".dcr", "src", "clsid:166B1BCA-3F9C-11CF-8075-444553540000"
     , null
function AC_GetArgs(args, ext, srcParamName, classid, mimeType){
  var ret = new Object();
  ret.embedAttrs = new Object();
  ret.params = new Object();
  ret.objAttrs = new Object();
  for (var i=0; i < args.length; i=i+2){
    var currArg = args[i].toLowerCase();
    switch (currArg){
      case "classid":
        break;
      case "pluginspage":
        ret.embedAttrs[args[i]] = args[i+1];
        break;
      case "src":
      case "movie":
        args[i+1] = AC_AddExtension(args[i+1], ext);
        ret.embedAttrs["src"] = args[i+1];
        ret.params[srcParamName] = args[i+1];
        break;
      case "onafterupdate":
      case "onbeforeupdate":
      case "onblur":
      case "oncellchange":
      case "onclick":
      case "ondblclick":
      case "ondrag":
      case "ondragend":
      case "ondragenter":
      case "ondragleave":
      case "ondragover":
      case "ondrop":
      case "onfinish":
      case "onfocus":
      case "onhelp":
      case "onmousedown":
      case "onmouseup":
      case "onmouseover":
      case "onmousemove":
      case "onmouseout":
      case "onkeypress":
      case "onkeydown":
      case "onkeyup":
      case "onload":
      case "onlosecapture":
      case "onpropertychange":
      case "onreadystatechange":
      case "onrowsdelete":
      case "onrowenter":
      case "onrowexit":
      case "onrowsinserted":
      case "onstart":
      case "onscroll":
      case "onbeforeeditfocus":
      case "onactivate":
      case "onbeforedeactivate":
      case "ondeactivate":
      case "type":
      case "codebase":
      case "id":
        ret.objAttrs[args[i]] = args[i+1];
        break;
      case "width":
      case "height":
      case "align":
      case "vspace":
      case "hspace":
      case "class":
      case "title":
      case "accesskey":
      case "name":
      case "tabindex":
        ret.embedAttrs[args[i]] = ret.objAttrs[args[i]] = args[i+1];
        break;
      default:
        ret.embedAttrs[args[i]] = ret.params[args[i]] = args[i+1];
  ret.objAttrs["classid"] = classid;
  if (mimeType) ret.embedAttrs["type"] = mimeType;
  return ret;
meon
Twitter: meon
Bedankt: 780 keer
Ik gebruik nooit de RunActiveContent maar SWFObject. Heb daar redelijk goeie ervaringen mee en is lekker makkelijk om variabelen door te geven enz.
tammzak
die RunActiveContent wordt auto gemaakt door Flash CS3 ...
moet ik die dan gewoon weglaten en een SWFOBJECT in de plaats zetten?
meon
Twitter: meon
Bedankt: 780 keer
Ehm, ik heb 'maar' Flash 8, dus weet niet wat CS3 juist genereert, maar je hebt eigenlijk enkel je .swf nodig, swfobject.js en het stukje code dat gedocumenteerd staat op de site die ik je eerder noemde.
tammzak
jup, thanks het werkt!
Terug naar “Development”
