Ik gebruik de SMP client al een paar dagen maar krijg telkens deze fout te zien, wat kan ik hier aan doen?
[06:32:13] Completed 100000 out of 500000 steps (20 percent)
[06:55:15] Writing local files
[06:55:15] Completed 105000 out of 500000 steps (21 percent)
[07:14:40] + Attempting to send results
[07:15:12] Couldn't send HTTP request to server (wininet)
[07:15:12] + Could not connect to Work Server (results)
[07:15:12] (171.64.65.64:8080)
[07:15:12] - Error: Could not transmit unit 01 (completed November 29) to work server.
[07:15:12] + Attempting to send results
[07:15:47] Couldn't send HTTP request to server (wininet)
[07:15:47] + Could not connect to Work Server (results)
[07:15:47] (171.64.122.76:8080)
[07:15:47] Could not transmit unit 01 to Collection server; keeping in queue.
[07:18:19] Writing local files
[07:18:19] Completed 110000 out of 500000 steps (22 percent)
[07:41:27] Writing local files
[07:41:27] Completed 115000 out of 500000 steps (23 percent)
[08:04:29] Writing local files
[08:04:29] Completed 120000 out of 500000 steps (24 percent)
[08:27:32] Writing local files
Probleem met SMP client
Astralon
- Bedankt: 125 keer
Blijkbaar gebruik je de instellingen van Internet Explorer.
Disable die eens: FAH.exe - config
Trouwens het gebeurt wel vaker dat de servers overbelast zijn en dan kan het uren duren alvorens de resultaten worden ge-upload.
- DonRaveN
- Bedankt: 1 keer
Launch directory: C:\Folding@Home Windows SMP Client V1.
Executable: C:\Folding@Home Windows SMP Client V1.01\fah
Arguments: -config
[11:32:32] - Ask before connecting: No
[11:32:32] - Use IE connection settings: Yes
[11:32:32] - User name: [UB]DonRaveN (Team 34517)
[11:32:32] - User ID: 4FB23FDB4C4F3516
[11:32:32] - Machine ID: 1
[11:32:32]
[11:32:32] Configuring Folding@Home...
User name [[UB]DonRaveN]? [UB]DonRaveN
Team Number [34517]? 34517
Do not launch this program automatically, remove the ser
Use Internet Explorer Settings (no/yes) [yes]? no
Use proxy (yes/no) [no]? no
Allow receipt of work assignments greater than 5MB in si
Change advanced options (yes/no) [no]? no
[11:33:19] - Ask before connecting: No
[11:33:19] - User name: [UB]DonRaveN (Team 34517)
[11:33:19] - User ID: 4FB23FDB4C4F3516
[11:33:19] - Machine ID: 1
[11:33:19]
[11:33:19] Loaded queue successfully.
[11:33:19]
[11:33:19] + Processing work unit
[11:33:19] Core required: FahCore_a1.exe
[11:33:19] + Attempting to send results
[11:33:19] Core found.
[11:33:19] Working on Unit 02 [November 30 11:33:19]
[11:33:19] + Working ...
[11:33:19] + Results successfully sent
[11:35:53] Thank you for your contribution to Folding@Home.
[11:35:53] + Starting local stats count at 1
Ja, daar had ik yes ingevuld, bedankt Astralon
Arguments: -config
[11:32:32]
[11:33:19]
[11:33:19]
- DonRaveN
- Bedankt: 1 keer
Nog een probleem waar ik al een tijdje last van heb,
[06:10:20] Writing local files
[06:10:20] Completed 500000 out of 500000 steps (100 percent)
[06:10:20] Writing final coordinates.
[06:10:24] Past main M.D. loop
[06:10:41] Will end MPI now
[06:11:41]
[06:11:41] Finished Work Unit:
[06:11:41] - Reading up to 3722208 from "work/wudata_04.arc": Read 3722208
[06:11:41] - Reading up to 1775872 from "work/wudata_04.xtc": Read 1775872
[06:11:41] goefile size: 0
[06:11:41] logfile size: 25510
[06:11:41] Leaving Run
[06:11:46] - Writing 5527990 bytes of core data to disk...
[06:11:46] ... Done.
[06:11:46] - Failed to delete work/wudata_04.sas
[06:11:46] - Failed to delete work/wudata_04.goe
[06:11:46] Warning: check for stray files
[06:11:46] - Shutting down core
[06:13:46]
[06:13:46] Folding@home Core Shutdown: FINISHED_UNIT
[06:13:46]
[06:13:52] CoreStatus = 64 (100)
[06:13:52] Sending work to server
[06:13:52] + Attempting to send results
[06:16:27] + Results successfully sent
[06:16:27] Thank you for your contribution to Folding@Home.
[06:16:27] + Number of Units Completed: 22
[06:18:32] - Preparing to get new work unit...
[06:18:32] + Attempting to get work packet
[06:18:32] - Connecting to assignment server
[06:18:33] - Successful: assigned to (171.64.65.64).
[06:18:33] + News From Folding@Home: Welcome to Folding@Home
[06:18:33] Loaded queue successfully.
[06:18:47] + Closed connections
[06:18:47]
[06:18:47] + Processing work unit
[06:18:47] Core required: FahCore_a1.exe
[06:18:47] Core found.
[06:18:47] Working on Unit 05 [January 9 06:18:47]
[06:18:47] + Working ...
[06:18:48]
[06:18:48] *------------------------------*
[06:18:48] Folding@Home Gromacs SMP Core
[06:18:48] Version 1.74 (March 10, 2007)
[06:18:48]
[06:18:48] Preparing to commence simulation
[06:18:48] - Ensuring status. Please wait.
[06:18:51] - Starting from initial work packet
[06:18:51]
[06:18:51] Project: 2653 (Run 32, Clone 125, Gen 36)
[06:18:51]
[06:18:53] Assembly optimizations on if available.
[06:18:53] Entering M.D.
[06:19:08] percent)
[06:19:09] - Starting from initial work packet
[06:19:09]
[06:19:09] Project: 2653 (Run 32, Clone 125, Gen 36)
[06:19:09]
[06:19:13] Entering M.D.
[06:19:19] Rejecting checkpoint
[06:19:21] Protein: Protein in POPC
[06:19:21] Writing local files
[06:19:23] Extra SSE boost OK.
[06:19:23] Writing local files
[06:19:24] Completed 0 out of 500000 steps (0 percent)
Hoe fix ik het probleem zodat hij de files wel wilt verwijderen?
Bedankt op voorhand wie mij kan helpen
[06:11:41]
[06:13:46]
[06:13:46]
[06:18:47]
[06:18:48]
[06:18:48]
[06:18:51]
[06:18:51]
[06:19:08] percent)
[06:19:09]
[06:19:09]
Astralon
- Bedankt: 125 keer
Zelf heb ik niet echt een oplossing maar het komt blijkbaar vaker voor.
http://fahwiki.net/index.php/CoreStatus_codes#7B
http://foldingforum.org/viewtopic.php?f ... &sk=t&sd=a
Sven.VdS
- Bedankt: 1 keer
Sorry had deze thread niet eerder gezien
Ik heb dat Stray Files probleem ook regelmatig voor ... niks van aantrekken, je client heeft er geen last van en je loopt geen WU's mis
/EDIT: Als die melding je echt zou storen kan je altijd gewoon je 'work' subdirectory deleten ... best wel vlak nadat je PC een WU heeft afgewerkt en vooraleer er een nieuwe WU is gedownload, anders raakt deze verloren. Op zich worden die na een tijd dan wel aan iemand anders toegewezen, maar het is niet echt "Folding-etiquette" om WU's zitten te deleten
De work directory wordt automatisch opnieuw aangemaakt.
Sven.VdS
- Bedankt: 1 keer
Oh neen, je moet zeker geen vrees hebben dat je schijf gaat vollopen hoor
De enige die er eventueel last van zou kunnen hebben is de client zelf maar moest je toch zien dat je corrupte WU's of zo krijgt kan je gerust die folder eens leegmaken.
