System DLLuser32.dll ERROR ???
memyselfandi
Hey
Ik heb zopas m'n computer geformateerd (volledig gewist !) en nu ik opnieuw opstard komt dezelfde error als voorheen op het scherm weet iemand wat die betekend en hoe ik deze error kan 'oplossen'?
volgende komt op het scherm als window opgestart is:
the system DLLUSER32.DLL was reloed in memory. the application will not run properly. the relocation occurred because the DLL c:\windows\system32\HHCTRL.OCX occupied an addres ronge reserved for windows system DLLs. the vendor supplying the DLL shoud be contacted for a new DLL.
Begrijp er helemaal niks van :eek:
hopelijk valt dit op te lossen want
bedankt voor jullie hulp en tijd :-)
AnD
Bedankt: 117 keer
Het heeft iets te maken met een driver van een soundkaart. Ik heb eens snel op google gekeken.
ou've got to love the user-friendly wonderfulness of Microsoft Windows XP error messages. Imagine the Poorhouse's angst upon every turn on of the Poor-computer resulting in the following morsel:
Rthdcpl.exe - Illegal System DLL Relocation
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occurred because the DLL C:\Windows\System32\Hhctrl.ocx occupied an address range reserved for Windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL.
The Poorhouse runs virus checkers, adware checkers and even tries to put some sort of cap on the amounts of p0rn and hack1ng 1llegal sites used per day. But something had clearly slipped through. Indeed it had...the nefarious and cunning creature known as Microsoft Windows Update.
It turns out that rthdcpl.exe is the "Realtek HD Audio Control Panel". Quite possibly nothing you've installed, but it comes with various soundcards and similar hardware that you may have purchased or came with your computer. Something about recent Microsoft Windows security updates messes up its loading process. Nice.
There is a simple solution though if you manage to find it - and of course it isn't the suggested "contact vendor for a new dll". Instead, simply visit a page at Microsoft Support and "Download the 935448 package now."
Install, run etc. etc. it faffs around for a while and seems to solve the problem. Horray. It does validate your copy of Windows before running so if you've got anything particularly dodgy (i.e. pirated) in terms of Windows
http://www.microsoft.com/downloads/deta ... laylang=en
memyselfandi
AnD heel heel erg bedankt het probleem is opgelost: de error verschijnt niet meer ik weet niet wat het probleem eigenlijk inhield maar nu de error weg is zal het wel opgelost zijn he :-)
hoe zoek je trouwens de oplossing van zo'n error op (zoals jij gedaan hebt :-))
nog eens bedankt
AnD
Bedankt: 117 keer
memyselfandi schreef:AnD heel heel erg bedankt het probleem is opgelost: de error verschijnt niet meer ik weet niet wat het probleem eigenlijk inhield maar nu de error weg is zal het wel opgelost zijn he :-)
nog eens bedankt
Eigenlijk heel simpel.
Je kopieert de foutmelding en dan plak je dat in google en je zoekt. ;)
Terug naar “Software en apps”
