Destination host unreachable
Lukse
Iemand een idee waar hetvolgende aan kan liggen?
C:\>ping groups.google.be
Pinging groups.l.google.com [64.233.167.99] with 32 bytes of data:
Destination host unreachable.
Ping statistics for 64.233.167.99:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\>tracert groups.google.be
Tracing route to groups.l.google.com [64.233.167.104]
over a maximum of 30 hops:
  1  Destination host unreachable.
Trace complete.
Dat is vanaf een WinXP pc.
Andere pc's in m'n LAN kunnen groups.google.be perfect bereiken.
rapweg
eerste idee zou zijn dat de default gateway verkeerd staat ingesteld? Probeer deze is manueel in te stellen anders.
Lukse
Default gateway staat goed.
Is gewoon het IP van m'n router.
Lukse
C:\>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 10 dc 0f 94 00 ...... Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0         10.0.0.1        10.0.0.2       20
         10.0.0.0        255.0.0.0         10.0.0.2        10.0.0.2       20
         10.0.0.2  255.255.255.255        127.0.0.1       127.0.0.1       20
   10.255.255.255  255.255.255.255         10.0.0.2        10.0.0.2       20
        127.0.0.0        255.0.0.0        127.0.0.1       127.0.0.1       1
        224.0.0.0        240.0.0.0         10.0.0.2        10.0.0.2       20
  255.255.255.255  255.255.255.255         10.0.0.2        10.0.0.2       1
Default Gateway:          10.0.0.1
Persistent Routes:
  None
Misschien dat iemand hier iets kan uithalen?
OpThaCop
Bedankt: 16 keer
post eens :
ping 10.0.0.1
ping 195.238.2.21
Lukse
C:\>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Reply from 10.0.0.1: bytes=32 time=1ms TTL=64
Reply from 10.0.0.1: bytes=32 time<1ms TTL=64
Ping statistics for 10.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\>ping 195.238.2.21
Pinging 195.238.2.21 with 32 bytes of data:
Reply from 195.238.2.21: bytes=32 time=16ms TTL=56
Reply from 195.238.2.21: bytes=32 time=17ms TTL=56
Reply from 195.238.2.21: bytes=32 time=15ms TTL=56
Ping statistics for 195.238.2.21:
    Minimum = 15ms, Maximum = 17ms, Average = 15ms
Lukse
Niemand met een oplossing?
Vreemd... :-D
crapiecorn
Bedankt: 12 keer
Geen oplossing, wel hetzelfde "probleem". gnu/linux geen probleem, windows xp sp2 unreachable
OpThaCop
Bedankt: 16 keer
Dit is wat ik krijg :
Pinging groups.l.google.com [64.233.167.104] with 32 bytes of data:
Reply from 64.233.167.104: bytes=32 time=109ms TTL=241
Reply from 64.233.167.104: bytes=32 time=108ms TTL=241
Ping statistics for 64.233.167.104:
    Minimum = 108ms, Maximum = 109ms, Average = 108ms
C:\>ping 64.233.167.99
Pinging 64.233.167.99 with 32 bytes of data:
Reply from 64.233.167.99: bytes=32 time=111ms TTL=241
Reply from 64.233.167.99: bytes=32 time=110ms TTL=241
Reply from 64.233.167.99: bytes=32 time=114ms TTL=241
Reply from 64.233.167.99: bytes=32 time=113ms TTL=241
    Minimum = 110ms, Maximum = 114ms, Average = 112ms
C:\>
Opmerkelijk te vinden dat bij PING wel het juiste IP adres (.104 vanachter) komt te staan.
Bij jou is ping en tracert verschillend !?
gimic
Bedankt: 13 keer
kan volkomen normaal zijn, google werkt met meer dan 1 server zal load balancing doen zodat alle servers/lijnen niet overbelast geraken.
Gimic
Sloppy Joe
Lukse,
je routing table ziet er prima uit...
Kan je de web interface van je router en de site van google bereiken door gewoon te surfen?
Als dit het geval is, dan is het enigste wat er mij te binnen schiet je windows firewall, als die op staat kan dit je probleem verklaren.
Joe
A man on a mission: http://www.paulswereld.be/
Lukse
Sloppy Joe schreef:Lukse,
Joe
Web interface van router en site van google zijn perfect te bereiken.
Met Windows Firewall uit, krijg ik nog steeds dezelfde melding.
OpThaCop
Bedankt: 16 keer
doe eens dit :
tracert 64.233.167.99
Astralon
Bedankt: 125 keer
netsh winsock reset catalog
al geprobeerd?
Astralon
Lukse
OpThaCop schreef:doe eens dit :
C:\>tracert 64.233.167.99
Tracing route to 64.233.167.99 over a maximum of 30 hops
Trace complete.
Astralon schreef:netsh winsock reset catalog
al geprobeerd?
Astralon
Yep, die had ik al geprobeerd.
X-2datop
Lukse,
Al eens geprobeerd om je TCP/IP stack te herinitialiseren ?
"netsh int ip reset c:\temp\log.txt"
Draait er één of andere p2p software of application firewall ?
Grtz,
X
The best way to hack a digital network is an analogue phonecall !
Lukse
X-2datop schreef:Lukse,
Net geprobeerd, heeft helaas niet geholpen.
Ben je iets met de log file?
X-2datop schreef:Draait er één of andere p2p software of application firewall ?
Enkel Bittorrent client (µtorrent) en windows firewall.
X-2datop
Lukse,
Heb je de patch voor de limiet op half-open tcp connecties reeds geinstalleerd ?
Stomme vraag, maar Windows Firewall ook al uitgeschakeld ? En toch zeker gereboot na die "netsh int ip reset" hé ?
Grtz,
X
PS: Wil die log wel eens zien ja
bijicool
Doe een ipconfig /all
ik wil effe controleren of het subnet op je PC hetzelfde is ingesteld als op je router
Sub Zero
Bedankt: 121 keer
Wegens het oprakelen van een oud topic: *closed*
