MikroTik L009UiGS-RM router
L009 is more than just a router. This product line is up to 4 times faster than RB2011, it has a modern ARM CPU with container support, an innovative enclosure that allows mounting up to four routers in a single 1U space, more RAM, PoE, and 2.5G SFP support. This version comes with 1U rackmount accessories.
https://mikrotik.com/product/l009uigs_rm
In goede werkende staat, steeds gebruikt in een propere onderhouden omgeving.
Mogelijk kleine krasjes op de behuizing en de rack ears. Foto's op aanvraag.
Inclusief originele rackmount & voeding.
Meeneemprijs excl.: €79,00
Transportkosten:
NL: €11,00 met postnl of DPD.
BE: €9,00 met bpost.
[Te koop] MikroTik L009UiGS-RM router
- Ken
- Bedankt: 113 keer
Deze kan tegenwoordig ook naar ARM64 geüpgraded worden via netinstall.
Incl. app support. Een krachtig beestje dus!Usually, when a device is built on arm32 architecture, it is not possible to switch to arm64 due to hardware limitations, but this is an exception! The L009UiGS and L009UiGS-2HaxD-IN devices come with an arm64 processor that was initially run in arm32 mode for stability, but we have improved our software! Now, it is possible to do a simple package switch.
