Scarlet Uitval en Snelheid
Moonboy
Bedankt: 35 keer
Laatste 2 maanden geregeld de lijn eruit, vervolgens snelheden ondermaats, dit gaat dan even omhoog tot de volgende uitval, en dan terug traag internet.
Bbox tool doet er soms 10 min over om met een resultaat te komen.
Onstabiel dus, hebben jullie tips.
04-09-2025
B-Box 3 Sagem Tool v0.13.0
Downstream current bit rate:   39.999 kbps
Upstream current bit rate:     11.685 kbps
Downstream max bit rate:       75.682 kbps
Upstream max bit rate:         14.368 kbps
Downstream attenuation:        16,5 dB
Downstream noise margin:       18,2 dB
Upstream noise margin:         6,8 dB
Vectoring down:                yes
Vectoring up:                  yes
Modem vectoring compatible:    yes
ROP vectoring compatible:      yes
DSL standard:                  VDSL2 Annex B
DSL profile:                   17a
Estimated distance:            497 m
Proximus profile name:         unknown
Proximus DLM profile:          unknown
Proximus repair profile:       unknown
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
29-08-2025
Upstream current bit rate:     12.611 kbps
Downstream max bit rate:       87.277 kbps
Upstream max bit rate:         14.649 kbps
Downstream attenuation:        16,8 dB
Downstream noise margin:       22,2 dB
Upstream noise margin:         6,3 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            508 m
Proximus profile name:         40/12.5
Proximus DLM profile:          yes
Proximus repair profile:       no
24-08-2025
Downstream current bit rate:   29.969 kbps
Upstream current bit rate:     12.634 kbps
Downstream max bit rate:       92.328 kbps
Upstream max bit rate:         14.679 kbps
Downstream attenuation:        16,7 dB
Downstream noise margin:       27,4 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            504 m
Proximus profile name:         30/12,5
Downstream current bit rate:   49.722 kbps
Upstream current bit rate:     9.998 kbps
Downstream max bit rate:       59.712 kbps
Upstream max bit rate:         11.902 kbps
Downstream attenuation:        18,7 dB
Downstream noise margin:       17,1 dB
Upstream noise margin:         19,6 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   8b
Estimated distance:            481 m
Proximus profile name:         50/10
16-06-2025
Downstream current bit rate:   59.997 kbps
Upstream current bit rate:     20.000 kbps
Downstream max bit rate:       79.984 kbps
Upstream max bit rate:         28.287 kbps
Downstream noise margin:       12,8 dB
Upstream noise margin:         11,4 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Proximus profile name:         60/20
23-06-2025
Downstream max bit rate:       79.114 kbps
Upstream max bit rate:         27.912 kbps
Downstream noise margin:       12,5 dB
Upstream noise margin:         11,1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
23-07-2025
Downstream max bit rate:       81.017 kbps
Upstream max bit rate:         28.023 kbps
Downstream attenuation:        18,9 dB
Downstream noise margin:       16,7 dB
Upstream noise margin:         11,2 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            485 m
Proximus profile name:         50/20
Laatst gewijzigd door philippe_d 3 dagen geleden, in totaal 1 gewijzigd.
Reden: code tags ingevoegd
Bedankt: 611 keer
ik vind je (max) upstream verdacht laag voor die geschatte afstand en haalbare downstream snelheden.
het feit dat je zo vaak wisselt tussen current bit rate lijkt me ook dat je op geen enkel moment echt het ingestelde profiel haalt,
en de verbinding dus gewoon "zen best" doet en gelimiteerd is door de upstream.
lijkt mij 1 van volgende 2 dat het probleem zal zijn:
- slechte (interne) bekabeling waar verlies op zit (of bv oxidatie in de tf2007)
- defect (rakende) modem die niet meer genoeg vermogen heeft om het signaal goed terug te sturen (of voeding)
Moonboy
Bedankt: 35 keer
Zal bekabeling eens nazien.
Toegevoegd na 29 minuten 12 seconden:
Kabel overlopen, alles goed blijkbaar, alles goed vast ook, WD 40 ingespoten op de verbinding plugjes, en dat heeft blijkbaar effect.
Upstream current bit rate:     12.675 kbps
Downstream max bit rate:       86.120 kbps
Upstream max bit rate:         14.477 kbps
Downstream attenuation:        16,6 dB
Downstream noise margin:       21,8 dB
Upstream noise margin:         6,1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Indigiswe
Bedankt: 23 keer
Ik had recent een soortgelijk probleem. Modem gaf wel enorm slechte lijnwaarden aan. Ondanks dat er een technieker het punt dat met Scotchloks in elkaar zat opnieuw had uitgevoerd (waardoor ik nu helaas nét de sync op 40 Mbps upload van voorheen niet meer haal), bracht dit toch geen soelaas.
Omdat de bbox-tool er ook lang over deed om die waarden op te halen, begon ik de modem te verdenken. Met een Fritz!Box bevestigd dat die wel perfect nette lijnwaarden kon uitlezen. Kostte wat moeite om Scarlet te overtuigen, maar toch een nieuwe bbox gekregen en probleem opgelost.
Conclusie: bij mij, met soortgelijke klachten, was de bbox aan vervanging toe.
De interventie van de technieker was dus niet nodig en heeft niets opgelost.
Als ik zelf niet met de vraag kwam de modem te vervangen, was het probleem duidelijk niet zo snel van de baan (toch ruim 2 weken zonder 'stabiel' internet/TV van Scarlet gezeten en daar, ocharme, €10 compensatie voor gekregen).
Moonboy
Bedankt: 35 keer
Ok, nu doet bbox-tool er maar enkele seconden over, enkele dagen geduld nog om te zien of de snelheden omhoog gaan en stabiel blijven, volgens Proximus krijgen we dit najaar hier Glasvezel, daar zal ik niet rouwen.
Bedankt: 611 keer
je upstream noise margin is nog altijd wat te kort bij de 6db, een beetje "met de hakken over de sloot", en ik vind de upstream max nog altijd vrij laag vergeleken met de downstream max (ik zou eerder 80/30 verwachten, zoals in je stats van juni te zien is
Moonboy
Bedankt: 35 keer
Er klopt inderdaad iets niet, want alweer herstart de modem uit zichzelf, ik contacteer Scarlet.
Toegevoegd na 40 minuten 58 seconden:
Na interventie van Scarlet (sync probleem)
Downstream current bit rate:   22.913 kbps
Upstream current bit rate:     6.653 kbps
Downstream max bit rate:       23.597 kbps
Upstream max bit rate:         6.741 kbps
Downstream attenuation:        32,6 dB
Downstream noise margin:       6,4 dB
Upstream noise margin:         6,2 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   8b
Estimated distance:            781 m
Bedankt: 611 keer
niks van sync probleem, ze hebben je upload gewoon laag gecapped nu en je hebt nog steeds een slechte noise margin
Moonboy
Bedankt: 35 keer
Vanwaar komt deze storing dan denkt u.
Bedankt: 611 keer
zoals ik hierboven al zei, lijkt het me 1 van 2 mogelijkheden te zijn:
- ofwel bekabeling (interne bekabeling, rj11 aansluiting, tf2007 met oxidatie, ergens een aftakking met scotchlocks die slecht is, of buiten)
- ofwel de modem (of voeding daarvan)
Moonboy
Bedankt: 35 keer
Ik had hier 2 x tf2007 doosjes, 1 in de garage waar de kabel binnenkomt en 1bij de telefoon, die is verdwenen wegens opzegging vaste lijn.
Deze in de garage zag er niet al te fraai meer uit, dus gesupprimeerd en kabel rechtstreeks verbonden, tf2007 in de woonruimte splitter eruit, kabel naar modem rechtstreeks ingeplugd, opgestart en zie voor het eerst in lange tijd knippert het DSL ledje nu heel snel.
Hopelijk stabiel VDSL nu, en vlug snellere download.
Upstream current bit rate:     13.123 kbps
Downstream max bit rate:       89.894 kbps
Upstream max bit rate:         15.188 kbps
Downstream attenuation:        16,4 dB
Downstream noise margin:       23,1 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            493 m
Bedankt: 611 keer
short answer: nope.
zolang je upstream max bit rate onder de 20 blijft en je upstream noise margin onder de, lets say, 8, is je lijn niet echt in orde (opnieuw: kijk naar de waardes van juni vs al de andere)
vdsl zit altijd wel wat variatie op, maar je gaat van een lijn die probleemloos 60/20 doet met genoeg speling op de noise margin naar een lijn die de 20 up niet eens meer aankan, zonder echte verschillen in afstand, dus er blijft iets mis.
Moonboy
Bedankt: 35 keer
De enige vooruitgang is dat het nu stabiel werkt, volgende week terug Scarlet bellen, het moet beter, ik kijk uit naar glasvezel, teveel problemen meegemaakt de laatste 20 jaar met de vaste lijn.
silentkiller
Bedankt: 102 keer
Je kan het paard naar het water brengen, maar..
Splitter heeft nu al 2x aangegeven dat je waardes in juni nog OK waren en nu niet meer alsook aan wat het zou kunnen liggen.
Loop alles eens af cfr. de post van Splitter ipv naar scarlet te bellen
Moonboy
Bedankt: 35 keer
Ga morgen aan de slag ermee.
Toegevoegd na 15 uren 2 minuten 38 seconden:
Geen beterschap, als ik de modem nu verplaats naar de garage waar de kabel binnenkomt en daar aansluit en vervolgens bbox-tool laat meten dan sluit ik de binnenbekabeling uit. Meten moet dan wel met de tablet of phone (wifi), anders moet ik een heel lange netwerkkabel naar mijn Workstation leggen.
Moonboy
Bedankt: 35 keer
Update:
Vandaag 08-09-2025
Upstream current bit rate:     8.000 kbps
Downstream max bit rate:       55.119 kbps
Upstream max bit rate:         9.442 kbps
Downstream noise margin:       22,8 dB
Upstream noise margin:         16,3 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   8b
Proximus profile name:         40/8
06-09-2025
Upstream current bit rate:     13.127 kbps
Downstream max bit rate:       89.606 kbps
Upstream max bit rate:         15.199 kbps
Downstream attenuation:        16,3 dB
Downstream noise margin:       23,0 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   17a
Estimated distance:            489 m
Moonboy
Bedankt: 35 keer
Hoelang duurt het vooraleer Vectoring die snelheid gaat verhogen, hier blijft het al de tijd hangen op
Downstream max bit rate:       55.209 kbps
Downstream noise margin:       22,9 dB
Vectoring down:                yes
Vectoring up:                  yes
DSL profile:                   8b
