Telnet (Shell) commando's voor de BBOX2
jackho
Bedankt: 279 keer
Is het niet mogelijk om een overzicht te maken van alle mogelijke Telnet en Telnet shell commando's in verband met de BBOX2 ?
mvg,
TiTanium
Bedankt: 472 keer
Zoiets als dit?
login: admin
Password: ********
[admin @ home]$ help
Error: help should be called with 1 argument
help   Commands Help
Usage:
        help <"all" | category | command>
        where:
        help all - show all available commands
        help <category> - show commands in a certain category
        help <command> - show detailed help for a specific command
Availble help Categories
help terminal - show help about Commands to contorol OpenRG execution
help dns_route - show help about Dyncamic Routing according to DNS replies
help igmp - show help about IGMP Proxy related commands
help pvc - show help about PVC scan related commands
help rg_conf - show help about Read and write OpenRG configuration data
help ffs - show help about Flash file system
help mii - show help about MII Low level control
help FT commands - show help about FT commands
help FT atm commands - show help about FT atm commands
help FT sndcp commands - show help about FT sndcp commands
help rmt_mng - show help about Remote Management Commands
help firewall - show help about Control and display Firewall and NAT data
help resetstat - show help about RESET stats
help guistat - show help about GUI stats
help adslstat - show help about ADSL stats
help mirror - show help about mirror
help cmd - show help about Commands related to the Command module
help tasks - show help about API for OpenRG tasks
help debug - show help about Debug OpenRG
help log - show help about Contorols OpenRG logging behaviour
help main_task - show help about main_task commands
help flash - show help about Flash and loader related commands
En Help All
[admin @ home]$ help all
Command Category terminal - Commands to contorol OpenRG execution
exit           Exit sub menu
ls             List sub menue contents
die            Exit from OpenRG and return ret
ps             Print OpenRG's tasks
entity_close   Close an entity
Command Category dns_route - Dyncamic Routing according to DNS replies
dyn_route_print   Print Dynamic Routes
dyn_route_del     Delete Dynamic Routes
Command Category igmp - IGMP Proxy related commands
igmp_status   Print IGMP subscription of device
igmp_reset    Clear all IGMP subscriptions
Command Category pvc - PVC scan related commands
pvc_scan           Scan predefined vpi.vci to determine PPP protocol
pvc_scan_restart   Restart PVC scan
pvc_scan_status    Display PVC scan status
Command Category rg_conf - Read and write OpenRG configuration data
rg_conf_print         Print OpenRG configuration
rg_conf_set           Set OpenRG configuration path to value
rg_conf_set_obscure   Set OpenRG configuration path to an obscured value
rg_conf_del           Delete subtree from OpenRG configuration
rg_conf_ram_set       Set OpenRG dynamic configuration
rg_conf_ram_print     Print OpenRG dynamic configuration
rg_conf_ram_del       Delete subtree from OpenRG dynamic configuration
reconf                Reconfigure the system according to the current OpenRG
                      configuration
Command Category ffs - Flash file system
ffs_mount    Mount FFS device
ffs_umount   Unmount FFS device
ffs_format   Format FFS device
Command Category mii - MII Low level control
mii_dev_link_status_get   Get Link Status for all device ports using MII
mii_phy_reg_get           Get PHY MII register value
mii_phy_reg_set           Set PHY MII register value
mii_eth_reg_get           Get Ethernet MII register value
mii_eth_reg_set           Set Ethernet MII register value
Command Category FT commands - FT commands
save           Save configurating to flash
flash_chksum   Display all flash sections checksums
Command Category FT atm commands - FT atm commands
atm   atm
Command Category FT sndcp commands - FT sndcp commands
sndcp   sndcp
Command Category rmt_mng - Remote Management Commands
rmt_mng_enable
rmt_mng_login
rmt_mng_add_user
Command Category firewall - Control and display Firewall and NAT data
fw_restart       Stop and start Firewall & NAT
fw_start         Start Firewall & NAT
fw_stop          Stop Firewall & NAT
fw_filter        Turn Firewall packet inspection on/off
mac_cache_dump   Dump MAC cache data
fw_dump          Dispaly Firewall data
fw_variable      Display variables of the firewall rules
fw_trace         Trace packet traversal via the Firewall ruleset
Command Category resetstat - RESET stats
resetstat   RESET stats.
Command Category guistat - GUI stats
guistat   GUI stats.
Command Category adslstat - ADSL stats
adslstat   ADSL stats.
Command Category mirror - mirror
mirror_add_dev        mirror_add_dev
mirror_start          mirror_start
mirror_stop           mirror_stop
mirror_deconf         mirror_deconf
mirror_show           mirror_show
mirror_trace_on       mirror_trace_on
mirror_trace_off      mirror_trace_off
mirror_set_out_dev    mirror_set_out_dev
mirror_set_out_addr   mirror_set_out_addr
Command Category cmd - Commands related to the Command module
help   Commands Help
Command Category tasks - API for OpenRG tasks
host          Resolve host by name
bridge_info   Print bridge information
vlan_add      Add VLAN interface
Command Category debug - Debug OpenRG
sys_ioctl         issue openrg ioctl
etask_list_dump   Dump back trace of all etasks
meminfo           Print memory information
wbm_debug_set     Stop and start WBM debug mode
Command Category log - Contorols OpenRG logging behaviour
cat_log       Prints or deletes contents of log to console
log_lev_on    Redirect rg_error output equal to or higher than level to the
              current console.
log_lev_off   Stop rg_error redirection to the current console
exit           Exit sub menu
Command Category main_task - main_task commands
reboot              Reboot the system
rg_ifconfig         List OpenRG Network Devices
restore_default     Restore default configuration
exec                Execute program
print_main_wan      Print the name of the current main wan device
cat                 Print file contents to console
shell               Spawn busybox shell in foreground
cgi_session_check   Check if session id is valid or not
cgi_set_randomize   For a session_id given, it set a random number for web pages
cgi_check_random    For a session_id given, it checks the random number in
                    order to access web pages
route               Print route table
ver                 Display version information
date                Print the current UTC and local time
Command Category flash - Flash and loader related commands
flash_commit   Save OpenRG configuration to flash
flash_erase    Erase a given section in the flash
load           Load and burn image
boot           Boot the system
flash_layout   Print the flash layout and content
flash_dump     Dump the flash content
lock           Lock mtd region
unlock         Unlock mtd region
bset           Configure bootloader
ifconfig       Configure network interface
ping           Test network connectivity
Returned 0
