OpenBSD 3.8 (GENERIC) #0
    [email protected]:/usr/src/sys/arch/i386/compile/GENERIC
cpu0: Intel(R) Pentium(R) 4 CPU
3.00GHz ("GenuineIntel" 686-class) 3 GHz
cpu0: FPU,V86,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CFLUSH,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,SBF,SSE3,MWAIT,CNXT-ID
real mem  =
1073324032 (1048168K)
avail mem = 972783616 (949984K)
using 4278 buffers containing 53768192 bytes (52508K) of memory
mainbus0 (root)
bios0 at mainbus0: AT/286+(eb) BIOS, date 04/14/05, BIOS32 rev. 0 @ 0xfb7f0
apm0 at bios0: Power Management spec V1.2
apm0: AC on, battery charge unknown
apm0: flags 70102 dobusy 1 doidle 1
pcibios0 at bios0: rev 2.1 @ 0xf0000/0xdf64
pcibios0: PCI IRQ Routing Table rev 1.0 @ 0xfde90/192 (10 entries)
pcibios0: PCI Exclusive IRQs: 5 9 10 11
pcibios0: PCI Interrupt Router at 000:31:0 ("Intel 82371SB ISA" rev 0x00)
pcibios0: PCI bus #1 is the last bus
bios0: ROM list: 0xc0000/0x8000
cpu0 at mainbus0
pci0 at mainbus0 bus 0: configuration mode 1 (no bios)
pchb0 at pci0 dev 0 function 0 "Intel 82875P Host" rev 0x02
ppb0 at pci0 dev 30 function 0 "Intel 82801BA AGP" rev 0xc2
pci1 at ppb0 bus 1
vga1 at pci1 dev 9 function 0 "ATI Rage XL" rev 0x27
wsdisplay0 at vga1 mux 1: console (80x25, vt100 emulation)
wsdisplay0: screen 1-5 added (80x25, vt100 emulation)
em0 at pci1 dev 10 function 0 "
Intel PRO/1000MT (82541EI)" rev 0x00: irq 10, address: 00:30:48:76:7b:1a
em1 at pci1 dev 11 function 0 "Intel PRO/1000MT (82541EI)" rev 0x00: irq 5, address: 00:30:48:76:7b:1b
ichpcib0 at pci0 dev 31 function 0 "Intel 82801EB/ER LPC" rev 0x02
pciide0 at pci0 dev 31 function 1 "Intel 82801EB/ER IDE" rev 0x02: DMA, channel 0 configured to compatibility, channel 1 configured to compatibility
atapiscsi0 at pciide0 channel 0 drive 0
scsibus0 at atapiscsi0: 2 targets
cd0 at scsibus0 targ 0 lun 0:  SCSI0 5/cdrom removable
cd0(pciide0:0:0): using PIO mode 4, Ultra-DMA mode 2
pciide0: channel 1 disabled (no drives)
pciide1 at pci0 dev 31 function 2 "Intel 82801EB SATA" rev 0x02: DMA, channel 0 configured to native-PCI, channel 1 configured to native-PCI
pciide1: using irq 11 for native-PCI interrupt
wd0 at pciide1 channel 0 drive 0:
wd0: 16-sector PIO, LBA,
76319MB, 156301488 sectors
wd0(pciide1:0:0): using PIO mode 4, Ultra-DMA mode 5
wd1 at pciide1 channel 1 drive 0:
wd1: 16-sector PIO, LBA,
wd1(pciide1:1:0): using PIO mode 4, Ultra-DMA mode 5
"Intel 82801EB/ER SMBus" rev 0x02 at pci0 dev 31 function 3 not configured
isa0 at ichpcib0
isadma0 at isa0
pckbc0 at isa0 port 0x60/5
pckbd0 at pckbc0 (kbd slot)
pckbc0: using irq 1 for kbd slot
wskbd0 at pckbd0: console keyboard, using wsdisplay0
pmsi0 at pckbc0 (aux slot)
pckbc0: using irq 12 for aux slot
wsmouse0 at pmsi0 mux 0
pcppi0 at isa0 port 0x61
midi0 at pcppi0:
spkr0 at pcppi0
sysbeep0 at pcppi0
lpt0 at isa0 port 0x378/4 irq 7
lm0 at isa0 port 0x290/8: W83627HF
npx0 at isa0 port 0xf0/16: using exception 16
pccom0 at isa0 port 0x3f8/8 irq 4: ns16550a, 16 byte fifo
pccom1 at isa0 port 0x2f8/8 irq 3: ns16550a, 16 byte fifo
fdc0 at isa0 port 0x3f0/6 irq 6 drq 2
fd0 at fdc0 drive 0: 1.44MB 80 cyl, 2 head, 18 sec
biomask eb45 netmask ef65 ttymask ffe7
pctr: user-level cycle counter enabled
dkcsum: wd0 matches BIOS drive 0x80
dkcsum: wd1 matches BIOS drive 0x81
root on wd0a
rootdev=0x0 rrootdev=0x300 rawdev=0x302
Oprechte dank aan Edpnet om ons dit stevig machien ter beschikking te stellen uiteraard.
De vervanging komt voort uit het feit dat we op nirwana een beetje probleempjes hebben met de SATA implementatie en daardoor naar iets anders op zoek zijn gegaan.
