Scarlet Uitval en Snelheid
Geplaatst: 04 sep 2025, 10:08
Laatste 2 maanden geregeld de lijn eruit, vervolgens snelheden ondermaats, dit gaat dan even omhoog tot de volgende uitval, en dan terug traag internet.
Bbox tool doet er soms 10 min over om met een resultaat te komen.
Onstabiel dus, hebben jullie tips.
04-09-2025
29-08-2025
24-08-2025
16-06-2025
23-06-2025
23-07-2025
04-09-2025
B-Box 3 Sagem Tool v0.13.0
Device: B-Box 3 Sagem
Downstream current bit rate: 39.999 kbps
Upstream current bit rate: 11.685 kbps
Downstream max bit rate: 75.682 kbps
Upstream max bit rate: 14.368 kbps
Downstream attenuation: 16,5 dB
Downstream noise margin: 18,2 dB
Upstream noise margin: 6,8 dB
Vectoring down: yes
Vectoring up: yes
Modem vectoring compatible: yes
ROP vectoring compatible: yes
DSL standard: VDSL2 Annex B
DSL profile: 17a
Estimated distance: 497 m
Proximus profile name: unknown
Proximus DLM profile: unknown
Proximus repair profile: unknownCode: Selecteer alles
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Upstream current bit rate: 12.611 kbps
Downstream max bit rate: 87.277 kbps
Upstream max bit rate: 14.649 kbps
Downstream attenuation: 16,8 dB
Downstream noise margin: 22,2 dB
Upstream noise margin: 6,3 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 508 m
Proximus profile name: 40/12.5
Proximus DLM profile: yes
Proximus repair profile: noCode: Selecteer alles
Downstream current bit rate: 29.969 kbps
Upstream current bit rate: 12.634 kbps
Downstream max bit rate: 92.328 kbps
Upstream max bit rate: 14.679 kbps
Downstream attenuation: 16,7 dB
Downstream noise margin: 27,4 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 504 m
Proximus profile name: 30/12,5
Downstream current bit rate: 49.722 kbps
Upstream current bit rate: 9.998 kbps
Downstream max bit rate: 59.712 kbps
Upstream max bit rate: 11.902 kbps
Downstream attenuation: 18,7 dB
Downstream noise margin: 17,1 dB
Upstream noise margin: 19,6 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 8b
Estimated distance: 481 m
Proximus profile name: 50/10
Downstream current bit rate: 59.997 kbps
Upstream current bit rate: 20.000 kbps
Downstream max bit rate: 79.984 kbps
Upstream max bit rate: 28.287 kbps
Downstream noise margin: 12,8 dB
Upstream noise margin: 11,4 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Proximus profile name: 60/20
Downstream max bit rate: 79.114 kbps
Upstream max bit rate: 27.912 kbps
Downstream noise margin: 12,5 dB
Upstream noise margin: 11,1 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Downstream max bit rate: 81.017 kbps
Upstream max bit rate: 28.023 kbps
Downstream attenuation: 18,9 dB
Downstream noise margin: 16,7 dB
Upstream noise margin: 11,2 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 485 m
Proximus profile name: 50/20
