Are GPON SFP modules all equal towards routers SFP input ?
Geplaatst: 11 mei 2025, 17:00
door NoNoRoBo
Dear members,
I have a Fiber XS contract with EDPNet since february 2024.
Here is the current current setup of my home :
Passive splitter on last level (2nd level) > ONT > BBox3+ > POE 2.5GB Switch > POE APs for levels 0,1 & 2.
I would like to adapt my network infrastructure for various reasons (cable management, power consumption and future upgrade of my current contract).
So, the plan is to get both the Proximus ONT and BBox3+ replaced by a single wired fiber modem router.
I was considering the TP-Link ER7406 since it has a SFP WAN port which is "glasvezel compatibel" and VLANs seems to be quite easy to operate as a prosumer product (from what I saw on the TP Link online emulator, at least).
Of course, since EDPNet uses GPON network with their Fiber XS contract, some of you might encourage me to buy a Fritzbox 5590 International version and call it a day.
But it's more expensive and I don't need the WIFI function since I already have deported WIFI APs through my POE switch.
Also, I don't care about these old DECT and Zigbee technologies and VLANs seems more difficult to operate as well.
So, here are my questions :
"Since AVM sells a separate GPON SFP Module for a decent price (around 25€), will it be compatible with my router ?"
"Would it be better to buy the same module from TP-Link ?"
"Is it safe to say that any GPON SFP module will work ?"
"Will EDPNet agree to register my TP-Link Router (I know you need to call them to register the AVM one, but I don't know for other brands) ?
"Does the green fiber cable need to be replaced as well if I am staying on Proximus GPON network (see picture attached) ?
Thank in advance to all of you.
Best regards,
Arnaud
Re: Are GPON SFP modules all equal towards routers SFP input ?
Geplaatst: 11 mei 2025, 17:36
door philippe_d
NoNoRoBo schreef: 11 mei 2025, 17:00Of course, since EDPNet uses GPON network with their Fiber XS contract, some of you might encourage me to buy a Fritzbox 5590 International version and call it a day.
We have "modem freedom" since November, henc nobody can force you to use a B-box, FritzBox, or whatsoever ... it's completely up to you ... :wink:
NoNoRoBo schreef: 11 mei 2025, 17:00Since AVM sells a separate GPON SFP Module for a decent price (around 25€), will it be compatible with my router ?
No.
The Fritz!Box has a built-in modem, the Fritz!GPON SFP Module only acts as a media converter and not as a fiber modem
NoNoRoBo schreef: 11 mei 2025, 17:00Would it be better to buy the same module from TP-Link ?
It does not matter, as long you buy a GPON SFP Module with built-in modem (ONT), also known as a "GPON ONU SFP Module"
The TP-Link GPON ONU SFP might be the best choice to guarantee compatibility with your TP-Link router?
NoNoRoBo schreef: 11 mei 2025, 17:00Will EDPNet agree to register my TP-Link Router (I know you need to call them to register the AVM one, but I don't know for other brands).
They are legally obliged to do so. At the end, it is not their choice, they just register your modem in the Proximus tool they have access to.
NoNoRoBo schreef: 11 mei 2025, 17:00Does the green fiber cable need to be replaced as well if I am staying on Proximus GPON network
This depends which connector you need at the modem side.
The Proximus green/green cable fits on the AVM GPON module, for the AVM XGS-PON you need a green/blue cable.
If you buy the TP-Link GPON ONU SFP Module, you will need to check with TP-Link which connector you need.
Geplaatst: 11 mei 2025, 18:42
door NoNoRoBo
Hello Philippe,
Thank you for your fast answer and all those precious information's.
I will ask to TP-Link's support and see what SFP module they suggest.
Have a great day !
Arnaud
Geplaatst: 12 mei 2025, 21:15
door NoNoRoBo
Small update :
TP-Link did suggest me their XM60A...
I did send a message to the vendor to make sure there is a ModemID mentionned on it so I can get it activated by the Proximus parent network.
Thankx Again and to be continued !
Geplaatst: 12 mei 2025, 23:16
door philippe_d
The TP-Link XM60A will have a modem-ID starting with "TPLG" ....
https://hack-gpon.org/vendor/
The fiber connector is a SC/APC (big green one), the same as used the Proximus ONT.
https://www.tp-link.com/us/service-prov ... ifications
