DSL disconnects
Geplaatst: 24 jan 2023, 16:33
door heist_175
Is dit DLM aan het werk ofzo?
De UL blijft gelijk op +/- 35,
de DL jo-jo't wat 100 > 65 > 55 > 47 > 63 > 69 > 57 > 100
en finaal, na een 10-tal disconnects zijn we terug waar we al maanden/jaren zijn: 100/35
En kan dat soort gespeel niet ergens tussen 3 en 5u 's nachts?
24.01.23 16:14:18 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 16:14:16 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 16:14:13 DSL is available (DSL synchronized with 56499/33687 kbit/s).
24.01.23 16:13:09 DSL synchronization starting (training).
24.01.23 16:12:55 Timeout during PPP negotiation.
24.01.23 16:12:55 Internet connection cleared.
24.01.23 16:12:50 DSL not responding (no DSL synchronization).
24.01.23 16:12:35 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 16:12:26 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 16:12:23 DSL is available (DSL synchronized with 68981/33832 kbit/s).
24.01.23 16:11:21 DSL synchronization starting (training).
24.01.23 16:11:05 Timeout during PPP negotiation.
24.01.23 16:11:05 Internet connection cleared.
24.01.23 16:11:01 DSL not responding (no DSL synchronization).
24.01.23 16:07:34 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 16:06:54 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 16:06:51 DSL is available (DSL synchronized with 63739/34760 kbit/s).
24.01.23 16:05:48 DSL synchronization starting (training).
24.01.23 16:05:34 Timeout during PPP negotiation.
24.01.23 16:05:34 Internet connection cleared.
24.01.23 16:05:29 DSL not responding (no DSL synchronization).
24.01.23 16:04:31 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 16:04:05 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 16:04:01 DSL is available (DSL synchronized with 47218/35000 kbit/s).
24.01.23 16:02:57 DSL synchronization starting (training).
24.01.23 16:02:44 Timeout during PPP negotiation.
24.01.23 16:02:44 Internet connection cleared.
24.01.23 16:02:40 DSL not responding (no DSL synchronization).
24.01.23 16:01:42 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 16:01:34 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 16:01:31 DSL is available (DSL synchronized with 55357/35000 kbit/s).
24.01.23 16:00:27 DSL synchronization starting (training).
24.01.23 16:00:13 Timeout during PPP negotiation.
24.01.23 16:00:13 Internet connection cleared.
24.01.23 16:00:08 DSL not responding (no DSL synchronization).
24.01.23 15:59:39 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 15:59:31 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 15:59:28 DSL is available (DSL synchronized with 64772/34904 kbit/s).
24.01.23 15:58:23 DSL synchronization starting (training).
24.01.23 15:58:11 Timeout during PPP negotiation.
24.01.23 15:58:11 Internet connection cleared.
24.01.23 15:58:06 DSL not responding (no DSL synchronization).
24.01.23 15:53:13 The DSL data rate has been adapted. Further dynamic adaptations will be performed automatically (without specification).
24.01.23 15:53:07 Internet connection established successfully. IP address: *, DNS server: * and *, gateway: *, broadband PoP: *
24.01.23 15:53:04 DSL is available (DSL synchronized with 99989/35000 kbit/s).
24.01.23 15:51:58 DSL synchronization starting (training).
24.01.23 15:51:45 Timeout during PPP negotiation.
24.01.23 15:51:45 Internet connection cleared.
24.01.23 15:51:40 DSL not responding (no DSL synchronization).
Re: DSL disconnects
Geplaatst: 24 jan 2023, 18:32
door on4bam
Ik heb dat nooit gezien. DLM aanpassing van de snelheid gebeurde steeds in 1 keer.
Re: DSL disconnects
Geplaatst: 24 jan 2023, 18:37
door Splitter
dat wil zeggen dat de fritzbox zijn verbinding met de ROP is kwijtgeraakt (om whatever reason)
als er een regelmaat is, dan kan het dat de kaart herstart werd - maar dat zou normaal snachts moeten zijn.
als het 1 dag is, dan kan het dat er een technieker aan de ROP aan het werken was
als het veelvuldig is, kan dat duiden op een poort of kaart die defect aan het raken is in de ROP, of bekabeling die niet in orde is tussen de ROP en je modem (kan binnen of buiten zijn)
de bekabeling zou je een idee van moeten kunnen krijgen door de waardes in de fritzbox, de poort/kaart kan je zelf nooit te weten komen.
gezien het lijkt dat dit enkel vandaag was, op een uur dat techniekers effectief werken, lijkt me dat het waarschijnlijk daar zal gezeten hebben.
en dus nee, dat kan dan niet in het holst van de nacht :)
Re: DSL disconnects
Geplaatst: 25 jan 2023, 08:01
door heist_175
Ik heb sinds maanden/jaren 100/35 als profiel en het probleem deed zich, kijkend naar de logs van de Fritzbox, enkel gisteren rond 16u voor.
Ik heb het gemerkt, omdat de VPN eruit vloog tijdens een videocall. Niet zo handig.
De tijd tussen de disconnects was net lang genoeg om terug in de Teams te raken, waarop ik er terug uitvloog. Niet zo handig :(.
Re: DSL disconnects
Geplaatst: 25 jan 2023, 09:21
door Tomsworld
Ik zou bijna zeggen slecht contact, als het niet in huis was ergens publiek. Nieuwe aansluting aan het maken in de kvd, kabbel, verdeler ? Wel goed dat het terug ok gekomen is op 100/35.
