black friday (e.d.) 2019
Ordon
Bedankt: 7 keer
Re: black friday (e.d.) 2019
Berichtdoor Ordon » 28 Nov 2019, 09:57
Die 3.3 Volt, "Power Disable feature", werd gedefinieerd in SATA revision 3.3.
Mocht dat een "probleem" vormen voor jouw eventuele "oude" hardware dan kan je:
-) één pin afplakken (zie video)
-) zorgen dat in de voeding de 3.3 Volt niet aanwezig is (vb molex connector => sata power)
YouTube: https://www.youtube.com/watch?v=9W3-uOl4ruc
De PCB op de WD80EZAZ en WD RED 8TB zijn blijkbaar identiek.
Visueel zijn ze ook hetzelfde (op de sticker na).
De firmware versie (83.H0A83) is zelfs identiek (met allicht enkele andere default settings).
Output van hdparm -I (versie v9.43):
ATA device, with non-removable media
        Model Number:       WDC WD80EZAZ-11TDBA0
        Serial Number:      [REDACTED]
        Firmware Revision:  83.H0A83
        Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0; Revision: ATA8-AST T13 Project D1697 Revision 0b
Standards:
        Used: unknown (minor revision code 0x0029)
        Supported: 9 8 7 6 5
        Likely used: 9
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:  268435455
        LBA48  user addressable sectors:15628053168
        Logical  Sector size:                   512 bytes
        Physical Sector size:                  4096 bytes
        Logical Sector-0 offset:                  0 bytes
        device size with M = 1024*1024:     7630885 MBytes
        device size with M = 1000*1000:     8001563 MBytes (8001 GB)
        cache/buffer size  = unknown
        Form Factor: 3.5 inch
        Nominal Media Rotation Rate: 5400
Capabilities:
        LBA, IORDY(can be disabled)
        Queue depth: 32
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 16  Current = 0
        Advanced power management level: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
           *    Write cache
           *    Look-ahead
           *    Host Protected Area feature set
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    DOWNLOAD_MICROCODE
           *    Advanced Power Management feature set
                Power-Up In Standby feature set
           *    SET_FEATURES required to spinup after power up
                SET_MAX security extension
           *    48-bit Address feature set
           *    Device Configuration Overlay feature set
                      *    Mandatory FLUSH_CACHE
           *    FLUSH_CACHE_EXT
           *    SMART error logging
           *    SMART self-test
           *    Media Card Pass-Through
           *    General Purpose Logging feature set
           *    WRITE_{DMA|MULTIPLE}_FUA_EXT
           *    64-bit World wide name
           *    URG for READ_STREAM[_DMA]_EXT
           *    URG for WRITE_STREAM[_DMA]_EXT
           *    WRITE_UNCORRECTABLE_EXT command
           *    {READ,WRITE}_DMA_EXT_GPL commands
           *    Segmented DOWNLOAD_MICROCODE
                unknown 119[6]
                unknown 119[7]
           *    Gen1 signaling speed (1.5Gb/s)
           *    Gen2 signaling speed (3.0Gb/s)
           *    Gen3 signaling speed (6.0Gb/s)
           *    Native Command Queueing (NCQ)
           *    Host-initiated interface power management
           *    Phy event counters
           *    NCQ priority information
           *    unknown 76[15]
                Non-Zero buffer offsets in DMA Setup FIS
           *    DMA Setup Auto-Activate optimization
                Device-initiated interface power management
                In-order data delivery
           *    Software settings preservation
                unknown 78[7]
                unknown 78[10]
                unknown 78[11]
           *    SMART Command Transport (SCT) feature set
           *    SCT Write Same (AC2)
           *    SCT Error Recovery Control (AC3)
           *    SCT Features Control (AC4)
           *    SCT Data Tables (AC5)
           *    reserved 69[3]
           *    reserved 69[4]
           *    WRITE BUFFER DMA command
           *    READ BUFFER DMA command
Security:
        Master password revision code = 48059
                supported
        not     enabled
        not     locked
                frozen
        not     expired: security count
                supported: enhanced erase
Logical Unit WWN Device Identifier: [REDACTED]
        NAA             : [REDACTED]
        IEEE OUI        : [REDACTED]
        Unique ID       : [REDACTED]
Checksum: correct
Output van smartctl -l scterc /dev/sdg (pas dit aan naar jouw configuratie):
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Output van smartctl -l scterc,80,80 /dev/sdg
SCT Error Recovery Control set to:
           Read:     80 (8.0 seconds)
          Write:     80 (8.0 seconds)
Mocht deze TLER een probleem vormen, dan steek je deze setting in een opstart script. Problem solved.
Deze disk voelt aan als een enterprise disk (en is dit allicht ook).
Je kan via CristalDiskInfo (of vergelijkbare software) altijd nakijken welke disk in de behuizing zit (voor je deze open doet).
Indien het niet is wat je had verwacht ==> retour. :wink:
Ik ben deze schijven aan testen op een echte oude bak: Een Medion PC van 2008 ... waarvan de BIOS slecht een 1.7 TB herkende.
Het OS (Linux) ziet uiteraard de volledige disk.
Output lsblk:
sdf      8:80   0   7.3T  0 disk
└─sdf1   8:81   0   7.3T  0 part
sdg      8:96   0   7.3T  0 disk
└─sdg1   8:97   0   7.3T  0 part
PS.
Ik had ergens gehoopt dat ik een andere disk in de lege behuizing zou kunnen steken.
Doch met een "gewone" WD5000AAKX-00ERMA0 lukte het alvast niet.
Bedankt: 307 keer
Uitgedeelde bedankjes: 332 keer
Berichtdoor MClaeys » 28 Nov 2019, 10:15
Ordon schreef:Je kan via CristalDiskInfo (of vergelijkbare software) altijd nakijken welke disk in de behuizing zit (voor je deze open doet).
Ideaal, goed om weten.
Ordon schreef:Ik had ergens gehoopt dat ik een andere disk in de lege behuizing zou kunnen steken.
Jammer, want ik wou de enclosures anders daarna nog gebruiken ipv op de afvalhoop. Garantie is er dan toch niet meer op.
Xbox Live: MClaeys
ub4b
Bedankt: 334 keer
Berichtdoor ub4b » 28 Nov 2019, 10:23
MClaeys schreef:Jammer, want ik wou de enclosures anders daarna nog gebruiken ipv op de afvalhoop. Garantie is er dan toch niet meer op.
Met oudere Seagate Expansion drives van 4 TB lukte dat wel, heb er nu een hele doos vol van ... als je plastic er af haalde heb je metalen slee waar je even snel een HDD in schuift als in een Sharkoon quickport. Die dingen werken zelfs met oude HDD's uit de jaren stillekes, nu een 750GB model aan het wipen ermee:
Ordon
Bedankt: 7 keer
Berichtdoor Ordon » 28 Nov 2019, 10:24
Ik heb die behuizingen heel mooi open gekregen.
Toegegeven: de eerste was wat minder, de tweede quasi perfect omdat ik toen precies wist waar de clips zaten en hoe deze sluiten.
Indien nodig gaan deze ook weer heel mooi dicht. :lol:
Bedankt: 275 keer
Berichtdoor Tomby » 28 Nov 2019, 10:46
Bij kommago.nl is er wat interessant netwerk spul afgeprijsd.
* TP-Link TL-SG108PE POE switch voor €42.35
* EAP225 en EAP245, vooral in 3-pack zeer interessante prijzen: €149 en €199 resp.
Staan hier al een tijd op mijn to-do listje om thuis eens een deftig manageable wifi-netwerk te hebben op alle verdiepen. Nu is het een mix van Telenet HGW, Asus RT-N66U (als AP), en een Netgear WNDR-3700 met DD-WRT (als AP). Kortom, een allegaartje met regelmatig een issue inzake stabiliteit of managability.
Enige wat ik nog altijd moet zien uit te vissen is goede plaats voor die AP met een minimum aan door muren boren om ze in een andere ruimte te hangen dan waar ik netwerk heb.
Ordon
Bedankt: 7 keer
Berichtdoor Ordon » 28 Nov 2019, 10:49
Iemand ergens een energiezuinige L3 24 poorts gigabit switch in de aanbieding tegengekomen?
(Eventueel tweedehands).
gunnix
Bedankt: 5 keer
Berichtdoor gunnix » 28 Nov 2019, 11:34
honda4life
Bedankt: 256 keer
Berichtdoor honda4life » 28 Nov 2019, 12:57
Qua functionaliteit leuk... maar te zwaar qua gewicht vind ik persoonlijk
Bedankt: 268 keer
Uitgedeelde bedankjes: 222 keer
Berichtdoor on4bam » 28 Nov 2019, 13:11
DXO Photolab, Black Friday deal -50% €69.99 ipv €129 (Essential) €99.99 ipv €199 (elite)
Flippi
Bedankt: 32 keer
Berichtdoor Flippi » 28 Nov 2019, 13:53
E-Channelizer 19: The Ultimate Toolkit For DVB & IP Television.
25% Black Friday korting.
https://echannelizer.com/license/full
Dit is software om Linux-boxen zoals o.a. VU+ en Dreambox vanaf je Windows PC te beheren. Zeer praktisch om zenderlijsten bij te werken of te importeren van bijv. KingOfSat.
8balljunkie
Bedankt: 20 keer
Berichtdoor 8balljunkie » 28 Nov 2019, 13:54
bambipower schreef:Op amazon.de hebben de wd red schijven 6tb en 8tb wel deftige korting
https://www.amazon.de/dp/B00N4UVVGA/ref ... r=8-5&th=1
Helaas ze zijn verhoogd in prijs heb de mijne paar weken terug gekocht aan 192,55 voor de 6TB.
Bedankt: 211 keer
Recent bedankt: 12 keer
Berichtdoor CCatalyst » 28 Nov 2019, 14:05
Leuke link voor het komende weekend en goed advies voor onder de Kerstboom: https://foundation.mozilla.org/en/privacynotincluded/
Bedankt: 307 keer
Berichtdoor MClaeys » 28 Nov 2019, 19:21
Jammer genoeg is het leven de rappe, de WD My Book deal was voorbij toen ik thuis kwam. Misschien de komende dagen nog eens, deze keer bankkaart bij de hand :). Inmiddels eens aan het kijken voor Reolink camera's voor op men NAS te hangen dan. Ze zijn in promo op amazon, maar ook op Reolink.com (nog iets goedkoper en gratis verzending).
Xbox Live: MClaeys
Uzzi
Bedankt: 29 keer
Berichtdoor Uzzi » 28 Nov 2019, 19:48
1ste aankoop is een feit ... Reolink C1 Pro @ Amazon.de
Reolink zelf was iets goedkoper maar daar kon ik niet zakelijk aankopen.
:banana: :banana:
butskristof
Bedankt: 79 keer
Uitgedeelde bedankjes: 481 keer
Contact:
Berichtdoor butskristof » 28 Nov 2019, 21:18
gunnix schreef:Amazon.fr heeft de Logitech Mx Master voor 37,99 euro.
Aan die prijs toch eens besteld om te proberen in combinatie met m'n Mac. On the go gaat er voor mij niets boven het trackpad maar aan de bureau is een muis toch makkelijker. Op zich geen klagen van de Magic Mouse maar al veel goede commentaren gehoord over de MX serie.
Iemand ervaring in combinatie met Mac? (mag misschien afgesplitst worden indien te hard offtopic)
 MacBook Pro 15" (2017)  MacBook Pro 13" (2017)  iPhone XS  iPad Pro 11"  Watch Series 3
ub4b
Bedankt: 334 keer
Berichtdoor ub4b » 28 Nov 2019, 21:35
MClaeys schreef:Jammer genoeg is het leven de rappe, de WD My Book deal was voorbij toen ik thuis kwam. Misschien de komende dagen nog eens, deze keer bankkaart bij de hand :).
Gezien ik nogal wat storage consumeer kijk ik regelmatig naar deze site:
https://diskprices.com/?locale=de
Ordon
Bedankt: 7 keer
Berichtdoor Ordon » 29 Nov 2019, 09:42
't Is de moment: de prijs staat terug op €134,90.
Uzzi
Bedankt: 29 keer
Berichtdoor Uzzi » 29 Nov 2019, 10:14
Het is soms niet te volgen ... vanmorgen stond de DS918+ op Amazon ineens €469. Tegen dat ik goed en wel beslist had van OK, dit wordt hem was de prijs alweer terug €529. Nu staat hij plots weer €499,51. Wat wordt het binnen 5 minuten ?
Bedankt: 211 keer
Berichtdoor CCatalyst » 29 Nov 2019, 10:25
Uzzi schreef:Het is soms niet te volgen ... vanmorgen stond de DS918+ op Amazon ineens €469. Tegen dat ik goed en wel beslist had van OK, dit wordt hem was de prijs alweer terug €529. Nu staat hij plots weer €499,51. Wat wordt het binnen 5 minuten ?
Op Amazon is dit vooral doordat het item uitverkocht is bij de verkoper (Amazon of derde-partij) die het item aan de korting aanbood. Dan springt de prijs weer terug naar de volgende verkoper die het item aan laagste prijs aanbiedt. Het overzicht met prijzen van de verschillende verkopers kan hier wat meer info over bieden.
Er zijn wel constant algoritmes in werking zowel bij Amazon als de derde verkopers en die kunnen hun prijzen idd indrukwekkend verhogen of verlagen.
Dat unieke "marktplaats" spel op Amazon tussen Amazon en de versch verkopers onderling is wel een grote plus die je op bv Coolblue niet ziet.
liegebeestig
Bedankt: 39 keer
Berichtdoor liegebeestig » 29 Nov 2019, 10:34
Amazon.de Bose noise canceling 700 daarnet naar 285 eur gezakt. Nog veel maar in de goede richting.
jorisx
Berichtdoor jorisx » 29 Nov 2019, 13:31
MClaeys schreef:Inmiddels eens aan het kijken voor Reolink camera's voor op men NAS te hangen dan.
Ervaring met Reolink camera's?
Ik twijfel om er aan te schaffen. We hebben nog geen NAS in huis. De Reolinks kunnen blijkbaar de beelden ook opslaan op een SD-kaart en blijkbaar ook via FTP-doorsturen. (zou dit ook werken voor de gratis STACK opslag?)
Heeft een NVR dan nog een meerwaarde?
devastator
Bedankt: 30 keer
Berichtdoor devastator » 29 Nov 2019, 14:05
jorisx schreef:Heeft een NVR dan nog een meerwaarde?
Ja, voor het continu opslaan van alle beelden. Als je'm echt wil gebruiken voor bewaking, dan mag je niet vertrouwen op opnames die gestart worden op basis van motion. Als je algoritme dan de beweging eens niet gezien heeft bij een inbraak, zijn je camera's nutteloos geweest.
Bedankt: 307 keer
Berichtdoor MClaeys » 29 Nov 2019, 14:41
jorisx schreef:Ervaring met Reolink camera's?
Nee, enkel de reviews al bekeken. Had er vroeger nooit van gehoord, maar sinds ik met Home Assistant prul kom ik ze vaak tegen omdat ze in die groep vrij populair zijn. De beelden vallen ook dik mee als ik ze online bekijk.
Xbox Live: MClaeys
Ramaht
Bedankt: 126 keer
Berichtdoor Ramaht » 29 Nov 2019, 15:26
Amazon Frankrijk staat met interessant prijzen voor Tado.
Basiskit Thermostaat V3 aan €118 en twee sets van 4 kranen aan €167 per set.
Net op tijd voor de oplevering :)
Joneszy
Bedankt: 4 keer
Berichtdoor Joneszy » 29 Nov 2019, 16:21
dankjewel voor de tip! Het is mss een iets zwaardere muis maar allround een topper en werkt beter dan andere muizen op zetels enz !! :-D
ub4b
Bedankt: 334 keer
Berichtdoor ub4b » 29 Nov 2019, 17:21
Ordon schreef:'t Is de moment: de prijs staat terug op €134,90.
Nog ééntje erbij - heb nu 4x de WD en 1x de Seagate 8TB, ik denk dat ik nu een paar jaar geen storage meer bijkoop. Maar aan deze prijzen ....
rolandvc
Bedankt: 6 keer
Berichtdoor rolandvc » 29 Nov 2019, 18:55
Belachelijk overdreven gedoe. Ik heb een filter aangemaakt die alle mails waar de woorden Black Friday in voorkomen regelrecht de vuilbak inkiepert. Ik koop wel wat ik nodig heb wanneer ik het nodig heb.
Gray
Bedankt: 133 keer
Uitgedeelde bedankjes: 320 keer
Berichtdoor Gray » 29 Nov 2019, 19:01
vandaag mijn "eweka" nieuwsgroep abonnement verlengd, 3 euro ipv 7,5/maand (was persoonlijke korting vermoed ik en wel met 12maand contract).
en wat parfum besteld bij larise.de , 50% korting op alles èn gratis verzending.
En een dna test cadeau gedaan, 48euro op amazon.
Als iemand een goede bluetooth DAC wilt, Topping DX3pro heb hem gekocht bij de vorige promotie en zeer tevreden over. https://www.amazon.co.uk/gp/offer-listing/B07KG9P3X3
Abusimbal
Bedankt: 65 keer
Uitgedeelde bedankjes: 116 keer
Berichtdoor Abusimbal » 30 Nov 2019, 20:53
Ordon schreef:Iemand ergens een energiezuinige L3 24 poorts gigabit switch in de aanbieding tegengekomen?
Nog op zoek ? Was vandaag bezig met installatie 10Gbit switches. Mijn HPE OfficeConnect 1920 16G Switch (JG923A) gaat er uit.
Is van rond maart 2016, vind geen factuur meer. Altijd aan UPS gehangen.
Specs: https://www.router-switch.com/pdf/jg923a-datasheet.pdf
HPE OfficeConnect 1920 16G SwitchJG923A
•16 RJ-45 auto-negotiating 10/100/1000 ports
•4 SFP 1000 Mbps ports
•min=0 \ max=4 SFP Transceivers
•1U -Height
Layer 3 services
•Address Resolution Protocol (ARP)determines the MAC address of another IP host in the same subnet; supports static ARPs; gratuitous ARP allows detection of duplicate IP addresses; proxy ARP allows normal ARP operation between subnets or when subnets are separated by a Layer 2 network
•DHCP relaysimplifies management of DHCP addresses in networks with multiple subnets
Layer 3 routing
•Static IPv4/IPv6 routingprovides basic routing (supporting up to 32 static routes and 8 virtual VLAN interfaces); allows manual routing configuration
Ik moet hem wel nog factory resetten. Heb console kabel in bestelling volgende week krijg ik die dat kan ik hem resetten. Weet wachtwoor van interface namelijk niet meer.
Telenet All-Internet (300)
Samsung Galaxy S10+
Ubiquiti UDM
Synology DS3615xs
Nvidia Shield TV console
Dell Latitude 5480
Microsoft Surface Pro 4
Garmin VivoSmart HR (activity tracker)
Bedankt: 307 keer
Berichtdoor MClaeys » 01 Dec 2019, 01:13
rolandvc schreef:Ik koop wel wat ik nodig heb wanneer ik het nodig heb.
Ik werk met een lijst van zaken die ik wil of nodig heb en op zulke dagen of de solden komt die boven om te zien of er deals zijn.
Xbox Live: MClaeys
decat
Bedankt: 78 keer
Berichtdoor decat » 01 Dec 2019, 16:05
rolandvc schreef:Belachelijk overdreven gedoe. Ik heb een filter aangemaakt die alle mails waar de woorden Black Friday in voorkomen regelrecht de vuilbak inkiepert. Ik koop wel wat ik nodig heb wanneer ik het nodig heb.
Ik vond het er dit jaar echt veel, mailbox puilde uit. :|
Bedankt: 58 keer
Berichtdoor boonpwnz » 01 Dec 2019, 16:15
Ik heb afgelopen dagen mailboxen van 20 mails per dag gekregen naast dan nog het dubbele aan spam.
Godsamme normaal heb ik maar een 3 tal mails per dag :eek:
Bedankt: 268 keer
Berichtdoor on4bam » 01 Dec 2019, 16:37
Ik heb geen enkele "Black Friday" mail gekregen. Overal waar ik een account heb staat dan ook de optie "promoties/newsletters ontvangen" af. 8)
Mijn +/- 80 mails per dag zijn dan ook stabiel gebleven.
Ik koop niets extra omdat het nu eenmaal in promotie staat maar wacht wel tot er promotie is om wat ik wil te kopen.
Vrijdag DXo Photolab (vervanger Adobe Lightroom) gekocht aan -50%. Prijssetting was wel raar want 2 weken terug verkochten ze met korting aan €149, dan een week aan €199 (normale prijs) en voor BF aan €99.
De Raspberry Pi die ik op het oog had was niet in promotie... jammer... Misschien nog op Cybermonday :-D
MaT
Bedankt: 193 keer
Uitgedeelde bedankjes: 144 keer
Berichtdoor MaT » 01 Dec 2019, 17:54
Voor de DIY domotica enthousiastelingen: Shelly geeft nog tot morgen kortingen van 20% tot 51% op hun assortiment :)
https://shop.shelly.cloud/
-Met name de kosten in verband met de eindapparatuur (modem, settopbox, ...) zouden beperkt kunnen worden, als die toestellen hergebruikt zouden kunnen worden of vrij gekozen worden door de klant- Bron
9livesuni
Bedankt: 53 keer
Berichtdoor 9livesuni » 01 Dec 2019, 18:09
Ik koop zowat elke goede deal. Helaas heb ik mij dit weekend suf gezocht achter de koopjes. Onkosten dit weekend, 6€ voor een giant en 1€ voor een xbox gamepass. Over een gitzwart weekend gesproken.
Ordon
Bedankt: 7 keer
Berichtdoor Ordon » 01 Dec 2019, 21:50
Abusimbal schreef:Nog op zoek ?
Ja.
Wel wat poorten minder dan ik zocht.
Wat vraag je er voor, zo tussen Black Friday en Cyber Monday in? :lol:
Abusimbal
Bedankt: 65 keer
Berichtdoor Abusimbal » 01 Dec 2019, 23:02
hallo, 50
Samsung Galaxy S10+
Ubiquiti UDM
Synology DS3615xs
Dell Latitude 5480
ddd
Bedankt: 67 keer
Uitgedeelde bedankjes: 203 keer
Berichtdoor ddd » 02 Dec 2019, 10:41
Net Samsung S10e gekocht voor €447 Amazon.de .
devastator
Bedankt: 30 keer
Berichtdoor devastator » 02 Dec 2019, 11:34
Heb je een link ? Ben ook op zoek voor mn vrouw ...
Gray
Bedankt: 133 keer
Berichtdoor Gray » 02 Dec 2019, 12:23
Heel goedkope VPN met acceptabele snelheid.
11,3 euro voor 1 device, wel levenslang (zou gratis vernieuwd worden na 5jaar)
https://www.mydealz.de/deals/ivacy-vpn- ... 60-1482520
Terug naar “Goede deals”
Wie is er online
