ndiswrapper werkt wel met centrino, hier de gegevens:
Log:
Aug 29 17:16:48 linux /etc/hotplug/usb.agent[1533]: need a device for this command
Aug 29 17:16:48 linux kernel: PCI: Setting latency timer of device 0000:00:1d.1 to 64
Aug 29 17:16:48 linux kernel: uhci_hcd 0000:00:1d.1: irq 11, io base 00001600
Aug 29 17:16:48 linux kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
Aug 29 17:16:48 linux kernel: usb usb2: Product: UHCI Host Controller
Aug 29 17:16:48 linux kernel: usb usb2: Manufacturer: Linux 2.6.4-52-default uhci_hcd
Aug 29 17:16:48 linux kernel: usb usb2: SerialNumber: 0000:00:1d.1
Aug 29 17:16:48 linux kernel: hub 2-0:1.0: USB hub found
Aug 29 17:16:48 linux kernel: hub 2-0:1.0: 2 ports detected
Aug 29 17:16:48 linux kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Aug 29 17:16:48 linux /etc/hotplug/usb.agent[1594]: need a device for this command
Aug 29 17:16:48 linux kernel: PCI: Setting latency timer of device 0000:00:1d.2 to 64
Aug 29 17:16:48 linux kernel: uhci_hcd 0000:00:1d.2: irq 11, io base 00001700
Aug 29 17:16:48 linux kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
Aug 29 17:16:48 linux kernel: usb usb3: Product: UHCI Host Controller
Aug 29 17:16:48 linux kernel: usb usb3: Manufacturer: Linux 2.6.4-52-default uhci_hcd
Aug 29 17:16:48 linux kernel: usb usb3: SerialNumber: 0000:00:1d.2
Aug 29 17:16:48 linux kernel: hub 3-0:1.0: USB hub found
Aug 29 17:16:48 linux kernel: hub 3-0:1.0: 2 ports detected
Aug 29 17:16:49 linux /etc/hotplug/usb.agent[1681]: need a device for this command
Aug 29 17:16:50 linux kernel: hw_random: RNG not detected
Aug 29 17:16:50 linux modprobe: FATAL: Error inserting hw_random (/lib/modules/2.6.4-52-default/kernel/drivers/char/hw_random.ko): No such device
Aug 29 17:16:50 linux /etc/hotplug/pci.agent[1609]: ... can't load module hw_random
Aug 29 17:16:50 linux /etc/hotplug/pci.agent[1609]: missing kernel or user mode driver hw_random
Aug 29 17:16:50 linux kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Aug 29 17:16:50 linux kernel: PCI: Setting latency timer of device 0000:00:1d.7 to 64
Aug 29 17:16:50 linux kernel: ehci_hcd 0000:00:1d.7: irq 11, pci mem e1859000
Aug 29 17:16:50 linux kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
Aug 29 17:16:50 linux kernel: PCI: cache line size of 32 is not supported by device 0000:00:1d.7
Aug 29 17:16:50 linux kernel: ehci_hcd 0000:00:1d.7: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29
Aug 29 17:16:50 linux kernel: usb usb4: Product: EHCI Host Controller
dmesg:
Linux version 2.6.4-52-default (geeko@buildhost) (gcc version 3.3.3 (SuSE Linux)) #1 Wed Apr 7 02:08:30 UTC 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
BIOS-e820: 000000001fff0000 - 000000001fffffc0 (ACPI data)
BIOS-e820: 000000001fffffc0 - 0000000020000000 (ACPI NVS)
BIOS-e820: 00000000ffb80000 - 00000000ffc00000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
501MB vmalloc/ioremap area available.
0MB HIGHMEM available.
511MB LOWMEM available.
On node 0 totalpages: 131056
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 126960 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
DMI 2.3 present.
ACPI: RSDP (v000 OID_00 ) @ 0x000e6010
ACPI: RSDT (v001 INSYDE RSDT_000 0x00000001 _CSI 0x00010101) @ 0x1fffa7f0
ACPI: FADT (v001 COMPAL DCL56 0x00000200 _CSI 0x00010101) @ 0x1ffffb00
ACPI: BOOT (v001 INSYDE SYS_BOOT 0x00000100 _CSI 0x00010101) @ 0x1ffffb90
ACPI: DBGP (v001 INSYDE DBGP_000 0x00000100 _CSI 0x00010101) @ 0x1ffffbc0
ACPI: SSDT (v001 INSYDE GV3Ref 0x00002000 INTL 0x20021002) @ 0x1fffa830
ACPI: DSDT (v001 COMPAL DCL561 0x00000006 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: local apic disabled
Built 1 zonelists
Kernel command line: root=/dev/hda3 vga=0x317 desktop resume=/dev/hda2 splash=silent
bootsplash: silent mode.
Initializing CPU#0
PID hash table entries: 2048 (order 11: 16384 bytes)
CKRM Initialized
Detected 1495.377 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Memory: 514960k/524224k available (1969k kernel code, 8468k reserved, 677k data, 212k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 2965.50 BogoMIPS
Security Scaffold v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
There is already a security framework initialized, register_security failed.
Failure registering capabilities with the kernel
selinux_register_security: Registering secondary module capability
Capability LSM initialized
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Looking for DSDT in initrd ...No customized DSDT found in initrd!
Freeing initrd memory: 1114k freed
CPU: After generic identify, caps: afe9f9bf 00000000 00000000 00000000
CPU: After vendor identify, caps: afe9f9bf 00000000 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: After all inits, caps: afe9f9bf 00000000 00000000 00000040
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel(R) Pentium(R) M processor 1.50GHz stepping 06
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
do_initcalls
init_elf_binfmt
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xe97a4, last bus=2
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
No customized DSDT found!
ACPI: IRQ9 SCI: Edge set to Level Trigger.
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
... the first call_usermodehelper: pci_bus
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGPB._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB_._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 5 *10)
ACPI: PCI Interrupt Link [LNKB] (IRQs 5 10)
ACPI: PCI Interrupt Link [LNKC] (IRQs 5 10)
ACPI: PCI Interrupt Link [LNKD] (IRQs 5 10)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 5 10)
ACPI: Embedded Controller [EC0] (gpe 28)
Linux Plug and Play Support v0.97 (c) Adam Belay
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
PCI: Using ACPI for IRQ routing
PCI: if you experience problems, try using option 'pci=noacpi' or even 'acpi=off'
vesafb: framebuffer at 0xa8000000, mapped to 0xe080d000, size 16384k
vesafb: mode is 1024x768x16, linelength=2048, pages=84
vesafb: protected mode interface info at c000:5673
vesafb: scrolling: redraw
vesafb: directcolor: size=0:5:6:5, shift=0:11:5:0
fb0: VESA VGA frame buffer device
Simple Boot Flag at 0x37 set to 0x1
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
Initial HugeTLB pages allocated: 0
ikconfig 0.7 with /proc/config*
VFS: Disk quotas dquot_6.5.1
SELinux: Registering netfilter hooks
Initializing Cryptographic API
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
bootsplash 3.1.6-2004/03/31: looking for picture.... silentjpeg size 35400 bytes, found (1024x768, 16102 bytes, v3).
Console: switching to colour frame buffer device 118x41
Real Time Clock Driver v1.12
Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Using anticipatory io scheduler
floppy0: no floppy controllers found
RAMDISK driver initialized: 16 RAM disks of 64000K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH4: IDE controller at PCI slot 0000:00:1f.1
PCI: Enabling device 0000:00:1f.1 (0005 -> 0007)
ICH4: chipset revision 3
ICH4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x1100-0x1107, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x1108-0x110f, BIOS settings: hdc:DMA, hdd:pio
hda: TOSHIBA MK6026GAX, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hdc: Slimtype DVDRW SDW-431S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 117210240 sectors (60011 MB), CHS=65535/16/63, UDMA(100)
hda: hda1 hda2 hda3
ide-floppy driver 0.99.newide
mice: PS/2 mouse device common for all mice
input: PC Speaker
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
Synaptics Touchpad, model: 1
Firmware: 5.9
Sensor: 37
new absolute packet format
Touchpad has extended capability bits
-> multifinger detection
-> palm detection
input: SynPS/2 Synaptics TouchPad on isa0060/serio4
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 4096 buckets, 32Kbytes
TCP: Hash tables configured (established 32768 bind 65536)
NET: Registered protocol family 8
NET: Registered protocol family 20
Resume Machine: resuming from /dev/hda2
Resuming from device hda2
Resume Machine: This is normal swap space
PM: Reading pmdisk image.
PM: Resume from disk failed.
ACPI: (supports S0 S1 S3 S4 S4bios S5)
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
ReiserFS: hda3: found reiserfs format "3.6" with standard journal
ReiserFS: hda3: using ordered data mode
ReiserFS: hda3: journal params: device hda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: hda3: checking transaction log (hda3)
ReiserFS: hda3: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Trying to move old root to /initrd ... failed
Unmounting old root
Trying to free ramdisk memory ... okay
Freeing unused kernel memory: 212k freed
Adding 1032184k swap on /dev/hda2. Priority:42 extents:1
md: autorun ...
device-mapper: 4.1.0-ioctl (2003-12-10) initialised:
[email protected]
NTFS driver 2.1.6 [Flags: R/O MODULE].
NTFS volume version 3.0.
subfs 0.9
8139too Fast Ethernet driver 0.9.27
eth0: RealTek RTL8139 at 0xe183f000, 00:02:3f:07:f8:7f, IRQ 11
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
drivers/usb/core/usb.c: registered new driver usbfs
drivers/usb/core/usb.c: registered new driver hub
Linux Kernel Card Services
options: [pci] [cardbus] [pm]
Yenta: CardBus bridge found at 0000:02:03.0 [14c0:0012]
Yenta: Using CSCINT to route CSC interrupts to PCI
Yenta: Routing CardBus interrupts to PCI
Yenta: ISA IRQ mask 0x0018, PCI irq 11
Socket status: 30000006
cs: IO port probe 0x0c00-0x0cff: clean.
cs: IO port probe 0x0820-0x08ff: clean.
cs: IO port probe 0x0800-0x080f: clean.
cs: IO port probe 0x03e0-0x04ff: excluding 0x4d0-0x4d7
cs: IO port probe 0x0100-0x03af: excluding 0x230-0x237 0x378-0x37f
cs: IO port probe 0x0a00-0x0aff: clean.
eth0: link down
NET: Registered protocol family 17
ehci_hcd 0000:00:1d.7: irq 11, pci mem e1849000
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.4-52-default ehci_hcd
usb usb1: SerialNumber: 0000:00:1d.7
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 6 ports detected
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:1d.0: UHCI Host Controller
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: irq 10, io base 00001200
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
usb usb2: SerialNumber: 0000:00:1d.0
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
usb usb3: SerialNumber: 0000:00:1d.1
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
usb usb4: Product: UHCI Host Controller
usb usb4: Manufacturer: Linux 2.6.4-52-default uhci_hcd
usb usb4: SerialNumber: 0000:00:1d.2
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ieee1394: Initialized config rom entry `ip1394'
ohci1394: $Rev: 1193 $ Ben Collins <
[email protected]>
Linux agpgart interface v0.100 (c) Dave Jones
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[11] MMIO=[d0001800-d0001fff] Max Packet=[2048]
agpgart: Detected an Intel 855PM Chipset.
agpgart: Maximum main memory to use for agp memory: 439M
agpgart: AGP aperture is 64M @ 0xb0000000
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00023f4752400326]
PCI: Setting latency timer of device 0000:00:1f.5 to 64
ACPI: AC Adapter [ACAD] (off-line)
ACPI: Battery Slot [BAT1] (battery present)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID]
ACPI: Processor [CPU0] (supports C1 C2 C3, 8 throttling states)
speedstep-centrino: found unsupported CPU with Enhanced SpeedStep: send /proc/cpuinfo to Jeremy Fitzhardinge <
[email protected]>
powernow: This module only works with AMD K7 CPUs
NET: Registered protocol family 10
Disabled Privacy Extensions on device c03545c0(lo)
IPv6 over IPv4 tunneling driver
intel8x0_measure_ac97_clock: measured 49570 usecs
intel8x0: clocking to 48000
hda: task_no_data_intr: status=0x51 { DriveReady SeekComplete Error }
hda: task_no_data_intr: error=0x04 { DriveStatusError }
parport0: PC-style at 0x378 [PCSPP,TRISTATE,EPP]
lp0: using parport0 (polling).
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
drivers/usb/core/usb.c: registered new driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
Non-volatile memory driver v1.2
hdc: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
SCSI subsystem initialized
st: Version 20040318, fixed bufsize 32768, s/g segs 256
BIOS EDD facility v0.13 2004-Mar-09, 1 devices found
eth0: no IPv6 routers present
mtrr: 0xa8000000,0x8000000 overlaps existing 0xa8000000,0x1000000
eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
LSPCI
0000:00:00.0 Host bridge: Intel Corp. 82855PM Processor to I/O Controller (rev 21)
0000:00:01.0 PCI bridge: Intel Corp. 82855PM Processor to AGP Controller (rev 21)
0000:00:1d.0 USB Controller: Intel Corp. 82801DB USB (Hub #1) (rev 03)
0000:00:1d.1 USB Controller: Intel Corp. 82801DB USB (Hub #2) (rev 03)
0000:00:1d.2 USB Controller: Intel Corp. 82801DB USB (Hub #3) (rev 03)
0000:00:1d.7 USB Controller: Intel Corp. 82801DB USB2 (rev 03)
0000:00:1e.0 PCI bridge: Intel Corp. 82801BAM/CAM PCI Bridge (rev 83)
0000:00:1f.0 ISA bridge: Intel Corp. 82801DBM LPC Interface Controller (rev 03)
0000:00:1f.1 IDE interface: Intel Corp. 82801DBM Ultra ATA Storage Controller (rev 03)
0000:00:1f.3 SMBus: Intel Corp. 82801DB/DBM SMBus Controller (rev 03)
0000:00:1f.5 Multimedia audio controller: Intel Corp. 82801DB AC'97 Audio Controller (rev 03)
0000:00:1f.6 Modem: Intel Corp. 82801DB AC'97 Modem Controller (rev 03)
0000:01:00.0 VGA compatible controller: ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]
0000:02:00.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 80)
0000:02:01.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
0000:02:02.0 Network controller: Intel Corp.: Unknown device 4220 (rev 05)
0000:02:03.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01)
LSMOD
linux:/var/log # lsmod
Module Size Used by
edd 9240 0
joydev 10176 0
sg 35360 0
st 38940 0
sd_mod 19840 0
sr_mod 15652 0
scsi_mod 107980 4 sg,st,sd_mod,sr_mod
ide_cd 36484 0
cdrom 36508 2 sr_mod,ide_cd
nvram 8328 0
usbserial 28912 0
parport_pc 35264 1
lp 10916 0
parport 37704 2 parport_pc,lp
snd_seq_oss 30976 0
snd_seq_midi_event 7680 1 snd_seq_oss
snd_seq 54672 5 snd_seq_oss,snd_seq_midi_event
snd_pcm_oss 56868 0
snd_mixer_oss 18688 1 snd_pcm_oss
ipv6 244100 13
speedstep_lib 3712 0
freq_table 4612 0
thermal 12424 0
processor 16040 1 thermal
fan 3972 0
button 6032 0
battery 8580 0
ac 4868 0
snd_intel8x0 32424 4
snd_ac97_codec 60676 1 snd_intel8x0
snd_pcm 96776 2 snd_pcm_oss,snd_intel8x0
snd_timer 25476 2 snd_seq,snd_pcm
snd_page_alloc 11012 2 snd_intel8x0,snd_pcm
gameport 4736 1 snd_intel8x0
snd_mpu401_uart 7808 1 snd_intel8x0
snd_rawmidi 24992 1 snd_mpu401_uart
snd_seq_device 8328 3 snd_seq_oss,snd_seq,snd_rawmidi
snd 59524 21 snd_seq_oss,snd_seq_midi_event,snd_seq,snd_pcm_oss,snd_mixer_oss,snd_intel8x0,snd_ac97_codec,snd_pcm,snd_timer,snd_mpu401_uart,snd_rawmidi,snd_seq_device
soundcore 8800 1 snd
intel_agp 17052 1
agpgart 28712 1 intel_agp
ohci1394 30724 0
ieee1394 99896 1 ohci1394
uhci_hcd 29584 0
ehci_hcd 27140 0
evdev 9600 0
af_packet 20360 0
ds 17284 2
yenta_socket 15744 0
pcmcia_core 61636 2 ds,yenta_socket
usbcore 96988 5 usbserial,uhci_hcd,ehci_hcd
8139too 23040 0
mii 5248 1 8139too
subfs 7296 1
nls_utf8 2176 1
ntfs 86092 1
dm_mod 50044 0
reiserfs 233808 1
______________________________________
