sorry dat ik jullie nogmaals moet storen maar na reeds meer dan een uur te sukkelen lukt het me niet, in tegenstelling tot de vorige development build Android L. Toen kon ik dit onder win7 installeren, helaas ben ik nu verplicht om de terminal van mac te gebruiken. ik ben al zover dat adb werkt want het commando ./adb reboot bootloader zet de nexus 5 effectief in die speciale mode. ik zit enkel vast met het ./flashall.sh commando. geef ik dit in dan krijg ik
./flash-all.sh: line 17: fastboot: command not found
./flash-all.sh: line 18: fastboot: command not found
./flash-all.sh: line 20: fastboot: command not found
./flash-all.sh: line 21: fastboot: command not found
./flash-all.sh: line 23: fastboot: command not found
doe ik ./fastboot krijg ik dit
usage: fastboot [ <option> ] <command>
commands:
update <filename> reflash device from update.zip
flashall flash boot, system, vendor and if found,
recovery
flash <partition> [ <filename> ] write a file to a flash partition
erase <partition> erase a flash partition
format[:[<fs type>][:[<size>]] <partition> format a flash partition.
Can override the fs type and/or
size the bootloader reports.
getvar <variable> display a bootloader variable
boot <kernel> [ <ramdisk> [ <second> ] ] download and boot kernel
flash:raw boot <kernel> [ <ramdisk> [ <second> ] ] create bootimage and
flash it
devices list all connected devices
continue continue with autoboot
reboot reboot device normally
reboot-bootloader reboot device into bootloader
help show this help message
options:
-w erase userdata and cache (and format
if supported by partition type)
-u do not first erase partition before
formatting
-s <specific device> specify device serial number
or path to device port
-l with "devices", lists device paths
-p <product> specify product name
-c <cmdline> override kernel commandline
-i <vendor id> specify a custom USB vendor id
-b <base_addr> specify a custom kernel base address.
default: 0x10000000
-n <page size> specify the nand page size.
default: 2048
-S <size>[K|M|G] automatically sparse files greater
than size. 0 to disable
ik volg deze leidraad
http://androidworld.nl/nieuws/android-m ... -download/
