scarlet IPv4 en IPv6
Geplaatst: 25 dec 2014, 13:54
mijn fritzbox geeft volgende mogelijkheid:
dus kan zowel 4 of 6 selecteren...
werkt scarlet al met IPv6 ?
IPv6 Support
IPv6 support enabled
IPv6 Connectivity
Always use a native IPv4 connection (recommended)
First a native IPv4 connection is established. If a 6RD server address was learned through DHCP, a 6RD tunnel is established. Otherwise the device will attempt to establish a native IPv6 connection (Dual Stack).
Always use a native IPv6 connection
For this operation mode your Internet service provider must support native IPv6 on your line.
Always use a tunnel protocol for the IPv6 connection
Use IPv6 with a tunnel protocol over a conventional IPv4 connection. To use this operating mode your Internet service provider does not have to support IPv6.
IPv6 Support
IPv6 Connectivity
