I'm using the international firmware 6.88 on a Fritz!Box 7360v2.
I'm not using PPPoE Passthrough, but it is available in the GUI. I guess it just works.
7360 als modem
- Uitgedeelde bedankjes: 939 keer
- Bedankt: 3627 keer
- Recent bedankt: 11 keer
There is no need for any modification on the config fileStorn70 schreef: 09 okt 2024, 09:04 I've tried the modification on the config file but i've almost "bricked" my 7360V2 Fritzbox. Hopefully the box cames back after 10 minutes..
As mentioned by raf1 above, FW 124.06.88 will run on the Proximus network.
As menioned before, PPPoE passtroug will work fine with OS 06.88Storn70 schreef: 09 okt 2024, 09:04 Is anyone knows if we can now upgrade to International Firmware 6.88 and if the pppoe Passthrough works with only the settings on the GUI enabled ?
Condition of course:
- FritzBox is set to Country Belgium
- and you selected EDPNet (or any other ISP working with PPPoE on VLAN10).
- and EDPNet allows 2 PPPoE sessions (not sure abouth this)
Storn70
- Starter
Hi,
With the update on 6.88, everything works perfectly. Fyi, no vlan input is necessary on Dream Router side, just PPPoE Credentials.
B.R
B.R
thomasdb
- Bedankt: 18 keer
thanks for the info!
i didnt know i could receive a second external ip address, tried it, works fine ( edpnet ) - indeed no vlan settings behind the fritzbox (7530) required only the pppoe
