Re: FreePBX probleem
Geplaatst: 08 jun 2012, 14:35
door krisken
Wat bedoel je juist met contexten?
Bij deze de logs...
0484xxxxxx = mijn gsm nummer
329xxxxxxx = opgeroepen nummer op mijn pbx
[2012-06-08 14:31:26] VERBOSE[2841] netsock2.c: == Using SIP RTP TOS bits 184
[2012-06-08 14:31:26] VERBOSE[2841] netsock2.c: == Using SIP RTP CoS mark 5
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk-sip-WeePee Trunk:1] Set("SIP/WeePee Trunk-00000000", "GROUP()=OUT_1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk-sip-WeePee Trunk:2] Goto("SIP/WeePee Trunk-00000000", "from-trunk,329xxxxxxx,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (from-trunk,329xxxxxxx,1)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:1] Set("SIP/WeePee Trunk-00000000", "__FROM_DID=329xxxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:2] Gosub("SIP/WeePee Trunk-00000000", "app-blacklist-check,s,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@app-blacklist-check:1] GotoIf("SIP/WeePee Trunk-00000000", "0?blacklisted") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@app-blacklist-check:2] Set("SIP/WeePee Trunk-00000000", "CALLED_BLACKLIST=1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@app-blacklist-check:3] Return("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:3] Set("SIP/WeePee Trunk-00000000", "CDR(did)=329xxxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:4] ExecIf("SIP/WeePee Trunk-00000000", "0 ?Set(CALLERID(name)=0484xxxxxx)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:5] Ringing("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] WARNING[5873] func_callerid.c: CALLERPRES is deprecated. Use CALLERID(name-pres) or CALLERID(num-pres) instead.
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:6] Set("SIP/WeePee Trunk-00000000", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:7] Set("SIP/WeePee Trunk-00000000", "CALLERPRES()=allowed_not_screened") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [329xxxxxxx@from-trunk:8] Goto("SIP/WeePee Trunk-00000000", "from-did-direct,1067,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (from-did-direct,1067,1)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [1067@from-did-direct:1] Set("SIP/WeePee Trunk-00000000", "__RINGTIMER=120") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [1067@from-did-direct:2] Macro("SIP/WeePee Trunk-00000000", "exten-vm,1067,1067,0,0,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:1] Macro("SIP/WeePee Trunk-00000000", "user-callerid,") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:1] Set("SIP/WeePee Trunk-00000000", "AMPUSER=0484xxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:2] GotoIf("SIP/WeePee Trunk-00000000", "0?report") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:3] ExecIf("SIP/WeePee Trunk-00000000", "1?Set(REALCALLERIDNUM=0484xxxxxx)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:4] Set("SIP/WeePee Trunk-00000000", "AMPUSER=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:5] Set("SIP/WeePee Trunk-00000000", "AMPUSERCIDNAME=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:6] GotoIf("SIP/WeePee Trunk-00000000", "1?report") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-user-callerid,s,13)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:13] GotoIf("SIP/WeePee Trunk-00000000", "0?continue") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:14] Set("SIP/WeePee Trunk-00000000", "__TTL=64") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:15] GotoIf("SIP/WeePee Trunk-00000000", "1?continue") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-user-callerid,s,26)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:26] Set("SIP/WeePee Trunk-00000000", "CALLERID(number)=0484xxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:27] Set("SIP/WeePee Trunk-00000000", "CALLERID(name)=0484xxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-user-callerid:28] Set("SIP/WeePee Trunk-00000000", "CHANNEL(language)=en") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:2] Set("SIP/WeePee Trunk-00000000", "RingGroupMethod=none") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:3] Set("SIP/WeePee Trunk-00000000", "__EXTTOCALL=1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:4] Set("SIP/WeePee Trunk-00000000", "__PICKUPMARK=1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:5] Set("SIP/WeePee Trunk-00000000", "RT=120") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:6] Gosub("SIP/WeePee Trunk-00000000", "sub-record-check,s,1(exten,1067,)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:1] GotoIf("SIP/WeePee Trunk-00000000", "1?check") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (sub-record-check,s,6)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:6] Set("SIP/WeePee Trunk-00000000", "__MON_FMT=wav") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:7] GotoIf("SIP/WeePee Trunk-00000000", "1?next") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (sub-record-check,s,10)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:10] ExecIf("SIP/WeePee Trunk-00000000", "0?Return()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:11] GotoIf("SIP/WeePee Trunk-00000000", "0?exten,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:12] Set("SIP/WeePee Trunk-00000000", "__REC_STATUS=INITIALIZED") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:13] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(__REC_POLICY_MODE=)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:14] Set("SIP/WeePee Trunk-00000000", "NOW=1339158686") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:15] Set("SIP/WeePee Trunk-00000000", "__DAY=08") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:16] Set("SIP/WeePee Trunk-00000000", "__MONTH=06") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:17] Set("SIP/WeePee Trunk-00000000", "__YEAR=2012") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:18] Set("SIP/WeePee Trunk-00000000", "__TIMESTR=20120608-143126") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:19] Set("SIP/WeePee Trunk-00000000", "__FROMEXTEN=0484xxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:20] Set("SIP/WeePee Trunk-00000000", "__CALLFILENAME=exten-1067-0484xxxxxx-20120608-143126-1339158686.0") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@sub-record-check:21] Goto("SIP/WeePee Trunk-00000000", "exten,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (sub-record-check,exten,1)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:1] GotoIf("SIP/WeePee Trunk-00000000", "0?callee") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:2] Set("SIP/WeePee Trunk-00000000", "__REC_POLICY_MODE=never") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:3] GotoIf("SIP/WeePee Trunk-00000000", "0?caller") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:4] GotoIf("SIP/WeePee Trunk-00000000", "1?callee") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (sub-record-check,exten,8)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:8] GosubIf("SIP/WeePee Trunk-00000000", "0?record,1(exten,1067,0484xxxxxx)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [exten@sub-record-check:9] Return("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:7] GotoIf("SIP/WeePee Trunk-00000000", "1?macrodial") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-exten-vm,s,13)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:13] GosubIf("SIP/WeePee Trunk-00000000", "0?clrheader,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:14] Macro("SIP/WeePee Trunk-00000000", "dial-one,120,tr,1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:1] Set("SIP/WeePee Trunk-00000000", "DEXTEN=1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:2] Set("SIP/WeePee Trunk-00000000", "DIALSTATUS_CW=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:3] GosubIf("SIP/WeePee Trunk-00000000", "0?screen,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:4] GosubIf("SIP/WeePee Trunk-00000000", "0?cf,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:5] GotoIf("SIP/WeePee Trunk-00000000", "1?skip1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-dial-one,s,8)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:8] GotoIf("SIP/WeePee Trunk-00000000", "0?nodial") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:9] GotoIf("SIP/WeePee Trunk-00000000", "0?continue") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:10] Set("SIP/WeePee Trunk-00000000", "EXTHASCW=ENABLED") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:11] GotoIf("SIP/WeePee Trunk-00000000", "0?next1:cwinusebusy") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-dial-one,s,23)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:23] GotoIf("SIP/WeePee Trunk-00000000", "1?next3:continue") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-dial-one,s,24)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:24] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(DIALSTATUS_CW=BUSY)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:25] GotoIf("SIP/WeePee Trunk-00000000", "0?nodial") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:26] GosubIf("SIP/WeePee Trunk-00000000", "1?dstring,1():dlocal,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:1] Set("SIP/WeePee Trunk-00000000", "DSTRING=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:2] Set("SIP/WeePee Trunk-00000000", "DEVICES=1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:3] ExecIf("SIP/WeePee Trunk-00000000", "0?Return()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:4] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(DEVICES=067)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:5] Set("SIP/WeePee Trunk-00000000", "LOOPCNT=1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:6] Set("SIP/WeePee Trunk-00000000", "ITER=1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:7] Set("SIP/WeePee Trunk-00000000", "THISDIAL=SIP/1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:8] GosubIf("SIP/WeePee Trunk-00000000", "1?zap2dahdi,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/WeePee Trunk-00000000", "0?Return()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/WeePee Trunk-00000000", "NEWDIAL=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/WeePee Trunk-00000000", "LOOPCNT2=1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/WeePee Trunk-00000000", "ITER2=1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/WeePee Trunk-00000000", "THISPART2=SIP/1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(THISPART2=DAHDI/1067)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/WeePee Trunk-00000000", "NEWDIAL=SIP/1067&") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/WeePee Trunk-00000000", "ITER2=2") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/WeePee Trunk-00000000", "0?begin2") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/WeePee Trunk-00000000", "THISDIAL=SIP/1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:9] Set("SIP/WeePee Trunk-00000000", "DSTRING=SIP/1067&") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:10] Set("SIP/WeePee Trunk-00000000", "ITER=2") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:11] GotoIf("SIP/WeePee Trunk-00000000", "0?begin") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:12] Set("SIP/WeePee Trunk-00000000", "DSTRING=SIP/1067") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [dstring@macro-dial-one:13] Return("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:27] GotoIf("SIP/WeePee Trunk-00000000", "0?nodial") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:28] GotoIf("SIP/WeePee Trunk-00000000", "0?skiptrace") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:29] GosubIf("SIP/WeePee Trunk-00000000", "1?ctset,1():ctclear,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [ctset@macro-dial-one:1] Set("SIP/WeePee Trunk-00000000", "DB(CALLTRACE/1067)=0484xxxxxx") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [ctset@macro-dial-one:2] Return("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:30] Set("SIP/WeePee Trunk-00000000", "D_OPTIONS=tr") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:31] ExecIf("SIP/WeePee Trunk-00000000", "0?SIPAddHeader(Alert-Info: )") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:32] ExecIf("SIP/WeePee Trunk-00000000", "0?SIPAddHeader()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:33] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(CHANNEL(musicclass)=)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:34] GosubIf("SIP/WeePee Trunk-00000000", "0?qwait,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:35] Set("SIP/WeePee Trunk-00000000", "__CWIGNORE=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:36] Set("SIP/WeePee Trunk-00000000", "__KEEPCID=TRUE") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:37] GotoIf("SIP/WeePee Trunk-00000000", "0?usegoto,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:38] GotoIf("SIP/WeePee Trunk-00000000", "1?godial") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (macro-dial-one,s,42)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:42] Dial("SIP/WeePee Trunk-00000000", "SIP/1067,120,tr") in new stack
[2012-06-08 14:31:26] WARNING[5873] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Unknown)
[2012-06-08 14:31:26] VERBOSE[5873] app_dial.c: == Everyone is busy/congested at this time (1:0/0/1)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:43] ExecIf("SIP/WeePee Trunk-00000000", "0?Set(DIALSTATUS=)") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:44] GosubIf("SIP/WeePee Trunk-00000000", "0?s-CHANUNAVAIL,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-dial-one:45] MacroExit("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:15] Set("SIP/WeePee Trunk-00000000", "SV_DIALSTATUS=CHANUNAVAIL") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:16] GosubIf("SIP/WeePee Trunk-00000000", "0?docfu,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:17] GosubIf("SIP/WeePee Trunk-00000000", "0?docfb,1()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:18] Set("SIP/WeePee Trunk-00000000", "DIALSTATUS=CHANUNAVAIL") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [s@macro-exten-vm:19] ExecIf("SIP/WeePee Trunk-00000000", "1?MacroExit()") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [1067@from-did-direct:3] Set("SIP/WeePee Trunk-00000000", "__PICKUPMARK=") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [1067@from-did-direct:4] GotoIf("SIP/WeePee Trunk-00000000", "1?app-blackhole,congestion,1") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Goto (app-blackhole,congestion,1)
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [congestion@app-blackhole:1] NoOp("SIP/WeePee Trunk-00000000", "Blackhole Dest: Congestion") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [congestion@app-blackhole:2] Answer("SIP/WeePee Trunk-00000000", "") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [congestion@app-blackhole:3] PlayTones("SIP/WeePee Trunk-00000000", "congestion") in new stack
[2012-06-08 14:31:26] VERBOSE[5873] pbx.c: -- Executing [congestion@app-blackhole:4] Congestion("SIP/WeePee Trunk-00000000", "20") in new stack
[2012-06-08 14:31:31] VERBOSE[5873] pbx.c: == Spawn extension (app-blackhole, congestion, 4) exited non-zero on 'SIP/WeePee Trunk-00000000'
Geplaatst: 08 jun 2012, 16:27
door Splitter
context zijn de regels waarin bepaald is wat elk onderdeel moet doen.
jij hebt onderandere from-trunk, did-direct enzo.
called_blacklist=1 ? die 329xxxx is je nummer van weepee veronderstel ik (je trunk)?
vraag ik me af waarom die in de blacklist gaat kijken en dan zegt dat het nr in de blacklist staat?
verder lijkt het er inderdaad op dat asterisk doet wat hij moet:
- zien dat er een call binnenkomt
- de macro uitvoeren om de call naar extensie 1067 te sturen en over te gaan:
haal, indien mogelijk, eens even zoveel mogelijk controles & macro's eruit, zodat je eigenlijk puur een 1-1 verhouding krijgt: call die binnenkomt rechtstreeks naar 1067 sturen.
en dan kijken naar de logs van exact dat moment.
