				TELE2 Blockt websites ?
				Geplaatst: 22 sep 2009, 01:50
				door B166IR
				Als ik naar deze website ga <knip> en
http://binsearch.net krijg ik een timeout, wat raar is, als ik inlog via een Amerikaanse VPN kan ik wel op die sites zonder probleem.
nog iemand anders die dit heeft ?
Mod edit: knipje
Niet toegelaten acties  :
    * links naar illegale software (zaken), porno, warez, crack-sites, ...
				Re: TELE2 Blockt websites ?
				Geplaatst: 22 sep 2009, 05:52
				door cptKangaroo
				Tracing route to <knip>
over a maximum of 30 hops:
  1    13 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2     *        *        *     Request timed out.
  3    11 ms    11 ms    12 ms  94.104.0.54
  4    12 ms    12 ms    11 ms  94.104.0.54
  5    14 ms    14 ms    14 ms  zvtm-s1-rou-1041.BE.eurorings.net [134.222.148.230]
  6    18 ms    18 ms    18 ms  asd2-rou-1021.NL.eurorings.net [134.222.231.185]
  7    21 ms    20 ms    20 ms  obl-rou-1021.NL.eurorings.net [134.222.231.130]
  8    21 ms    21 ms    20 ms  195.190.227.222
  9   209 ms   154 ms   147 ms  rc2ec.il.shawcable.net [195.69.144.148]
 10   142 ms   143 ms   142 ms  rc1ec-tge0-0-2-0.il.shawcable.net [66.163.65.45]
 11   155 ms   155 ms   155 ms  rc2sh-pos3-0.mt.shawcable.net [66.163.76.146]
 12   154 ms   154 ms   154 ms  66.163.66.90
 13   155 ms   155 ms   154 ms  rx0sh-q9-networks.mt.bigpipeinc.com [66.244.223.202]
 14   156 ms   156 ms   156 ms  dist1-1.tor1-f2.q9.net [69.46.123.43]
 15   156 ms   156 ms   156 ms  dist1-1-g-access2-2.tor1.q9.net [69.46.121.78]
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
Tracing route to binsearch.net [83.149.75.183]
  1    45 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    13 ms    12 ms    12 ms  cust-1-0-110-94.dyn.versateladsl.be [94.110.0.1]
  3  cust-1-0-110-94.dyn.versateladsl.be [94.110.0.1]  reports: Destination net unreachable.
Trace complete.
De binsearch.net ligt er waarschijnlijk uit door een gecrashte router bij het evoswitch.com datacenter in Nederland - mijn site is ook nog steeds onbereikbaar voor mij vanwege die routeringsproblemen en geeft dezelfde boodschap. De <knipje> site is waarschijnlijk vanwege een ander probleem ergens op de huidige route.
Mod edit: knipje
				Geplaatst: 22 sep 2009, 08:23
				door Goendi
				Destination net unreachable. betekend zoveel als het zegt: destination network not reachable... Dat is geen blokkering, dat is een standaard melding die aangeeft dat het IP wat overeenstemt met die bepaalde website niet bereikbaar is via het publieke internet (blackholed bvb).
				Geplaatst: 22 sep 2009, 08:48
				door Goztow
				Geplaatst: 23 sep 2009, 18:19
				door cptKangaroo
				Hopelijk wordt de evoswitch link snel gefixt
				Geplaatst: 23 sep 2009, 18:28
				door TheGabeMan
				Hi
Ik lijk t zelfde probleem te hebben. Een vriendin van mij belde me dat bepaalde websites niet bereikbaar zijn. Zij heeft een versatel abo en kan niet op
http://www.relatieplanet.nl en .be Ook hier een timeout. Laptop van haar naar mij thuis en werkt prima. Laptop terug naar haar thuis werkt niet meer.
Zelfs surfen op IP adres lukt niet. Terwijl dat bij mij thuis dus wel werkt. We checken gelijktijdig op MSN en de site is echt wel in de lucht.
Heb nu mijn laptop meegenomen en zit op haar verbinding en inderdaad nu kan ik die sites ook niet meer bereiken. Ligt dus zeker niet aan laptop of internet explorer.
Dns oplossing, (nslookup
www.relatieplanet.nl) geeft correcte IP adres terug.
Ben benieuwd of er toch echt geen block is. Probleem treedt trouwens pas sinds enkele dagen op.
Gabrie
				Geplaatst: 23 sep 2009, 19:42
				door MeYeR
				Ik zit met eenzelfde probleem.
Samen met een aantal mensen huren we een dataserver. Er staat ook een scriptje zodat je kan inloggen met je browser en enkele zaken kunt bekijken. Sinds maandag is de server helaas niet meer bereikbaar van thuis uit. Op gelijk welke PC thuis is de server niet te vinden. Iemand anders kan er echter wel op. Met een proxy site zoals freeproxyserver.net kan ik inloggen via m'n browser maar data afhalen lukt niet.
Dus het is duidelijk dat Tele2 de server voor mij blokkeert.
Is hier een workaround voor. Of moet ik mss toch eens contact opnemen met Tele2. Over de content die op de server staat moet ik wss geen uitleg geven
				Geplaatst: 23 sep 2009, 19:52
				door TheGabeMan
				MeYeR schreef:Ik zit met eenzelfde probleem.
Heb al een support call aangemaakt bij United Telecom. Weet ook niet hoe die er precies mee te maken hebben maar daar betaald mijn vriendin het abo aan. En United ging een techneut laten terug bellen. Maar dat zal wrs zijn als ik er niet ben en die kennis van mij weet verschil tussen MSN en IExplorer niet eens
				Geplaatst: 23 sep 2009, 22:15
				door topaz
				Ik heb hetzelfde problem, denk ik.
Ik ben een Tele2/Base (vroeger Versatel) 4Mb Internet klant.
Ik kan mijn web-hoster niet accesseren (
http://www.alfanet.be), noch kan ik surfen naar "mijn" web site, of upload via FTP.
Dit is nu zo sinds
2 dagen.
Het helpdesk (!) van Tele2 erkent het problem: "onze techniekers werken er op, maar we weten niet waaneer het zal opgelost worden."
Internet, het netwerk met een redundant architectuur:  ongelooflijk.
Heeft iemand meer inzicht over wat is hier aan de gang ?
				Geplaatst: 23 sep 2009, 22:20
				door TheGabeMan
				topaz schreef:Ik heb hetzelfde problem, denk ik.
Dit is nu zo sinds
2 dagen.
Kun jij de sites die de andere posters hier noemen ook niet bereiken?
				Geplaatst: 23 sep 2009, 23:03
				door MeYeR
				Ik heb ook eens de test gedaan.
http://www.alfanet.be en
http://www.relatieplanet.nl zijn ook niet bereikbaar voor mij.
Ernaartoe surfen via
http://www.freeproxyserver.net/ lukt dan wel weer. Sommige sites zijn dus niet meer toegankelijk
				Geplaatst: 23 sep 2009, 23:58
				door topaz
				TheGabeMan,
rap een test gedaan:
  freeproxyserver - OK
  relatieplanet, binsearch - niet OK
Topaz
				Geplaatst: 24 sep 2009, 00:00
				door TheGabeMan
				topaz schreef:TheGabeMan,
Topaz
Moet toch wel haast een block zijn. Het IP adres wordt via DNS wel correct resolved en als je naar het IP direct surft, kom je ook niet op de pagina.
				Geplaatst: 24 sep 2009, 00:24
				door B166IR
				nfohump.com
werkt ook niet, de lijst begint al te groeien. is dit nu echt een block op warez sites ?
				Geplaatst: 24 sep 2009, 04:15
				door cptKangaroo
				Zoals ik al zei: een routercrash bij EvoSwitch datacenter (voornamelijk Leaseweb hosting) heeft dit waarschijnlijk veroorzaakt. DNS staat los van de routes die aan de IPs hangen - waarom er geen nieuwe routes komen, is de vraag, maar men is er blijkbaar mee bezig. Doe maar een tracert evoswitch.com dan kan je zien dat 'normale' sites er ook onder te lijden hebben.
				Geplaatst: 24 sep 2009, 11:14
				door 320i
				Ik heb het intern ook even doorgegeven om na te kijken en eventueel contact op te nemen waar nodig om dit euvel te verhelpen.
				Geplaatst: 24 sep 2009, 11:34
				door TheGabeMan
				320i schreef:Ik heb het intern ook even doorgegeven om na te kijken en eventueel contact op te nemen waar nodig om dit euvel te verhelpen.
Hi
Ik ben nog nieuw hier op forum, maar werk jij voor Tele2 / Versatel? Of wat bedoel je met intern?
Gr
Gabrie
				Geplaatst: 24 sep 2009, 12:18
				door Uzzi
				320i werkt inderdaad bij T2
				Geplaatst: 24 sep 2009, 13:07
				door The Conquer
				Uzzi schreef:320i werkt inderdaad bij T2
En nog wel op een goede positie!
320i heeft hier al velen geholpen, waarvoor nogmaals dank
				Geplaatst: 24 sep 2009, 13:15
				door splinterbyte
				Lijkt opgelost te ziin hier via tele2.
				Geplaatst: 24 sep 2009, 17:55
				door MeYeR
				Hier is het probleem ook opgelost
				Geplaatst: 24 sep 2009, 18:47
				door TheGabeMan
				Bij vriendin lijkt t nu ook opgelost
				Geplaatst: 24 sep 2009, 19:28
				door B166IR
				Yep, alles is in orde nu. heeft wel lang geduurt om eerlijk te zijn.
				Geplaatst: 25 sep 2009, 00:20
				door topaz
				Bij mij ook opgelost (
http://www.alfanet.be, etc.).
Veel dank 320i !
Ik ben akkord met B166IR, en een beetje status info van T2 zal ook niet slecht zijn geweest.
Topaz
				Geplaatst: 28 sep 2009, 07:54
				door 320i
				@Topaz: dacht hier nog te reageren, maar ben er niet meer toe gekomen.
Donderdag avond had ik de informatie gekregen dat het sinds 's morgens opgelost was.
