cccam foutmelding:
Geplaatst: 23 feb 2009, 21:20
door silencer
root@laurens-desktop:/usr# cd /usr/local/bin
root@laurens-desktop:/usr/local/bin# cccam -d
21:11:45.718 CCcam: ======================================================================
21:11:45.718 CCcam: starting CCcam 2.0.11 compiled on Dec 5 2008@23:41:47
21:11:45.718 CCcam: online using nodeId 9f8a7676e7b8f37f
21:11:45.721 CCcam: create 1 cam device(s)
21:11:46.035 CCcam: calculated EGT: 0 us
21:11:46.035 CCcam: seca card found
21:11:50.036 CCcam: card init fail
21:11:50.037 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
21:11:50.037 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
21:11:50.038 CCcam: static cw not found or bad
21:11:50.039 CCcam: parsed 0 entries from /var/etc/CCcam.prio
21:11:50.052 CCcam: added 1284 provider names from /var/etc/CCcam.providers
21:11:50.053 CCcam: readChannelList: cannot open /var/etc/CCcam.channelinfo or not found
21:11:50.053 CCcam: server started on port 12000
21:11:50.340 CCcam: calculated EGT: 0 us
21:11:50.340 CCcam: seca card found
21:11:52.575 CCcam: new tcp client from 192.168.0.20
21:11:52.577 CCcam: user xubuntuserver login attempt from 192.168.0.20
21:11:52.578 CCcam: client xubuntuserver@baa83e1a1959c936, running CCcam 2.0.11
21:11:52.579 CCcam: 0 cards --> client 192.168.0.20(xubuntuserver)
21:11:54.340 CCcam: card init fail
21:11:55.656 CCcam: calculated EGT: 0 us
21:11:55.656 CCcam: seca card found
21:11:59.656 CCcam: card init fail
21:12:00.962 CCcam: calculated EGT: 0 us
21:12:00.962 CCcam: seca card found
21:12:04.960 CCcam: card init fail
21:12:06.264 CCcam: calculated EGT: 0 us
card init fail: aan wat kan dit liggen? (met violet phoenix reader aan een usb2serial converter).
Re: cccam foutmelding:
Geplaatst: 23 feb 2009, 22:55
door rottekop
http://www.wizardmods.co.uk/forum/showt ... hp?t=35856 :oops:
Koop een Smargoreader. Je gaat er geen spijt van krijgen 8)
https://www.cardwriter.nl/nl/pd1184675949.htm
Geplaatst: 23 feb 2009, 23:24
door silencer
mja de seca2 kaart wordt al herkend!, wss ergens een driver probleem? ik krijg foutmledingen als ik volgende zaken doe:
Instructions to install new driver
You may require the sources matching the current kernel to be installed on your system (and built).
There are many helpfull websites that can assist you with this step and it isnt as daunting as you first think!
Try http://www.osnews.com/story.php?news_id=2949&page=2 as a first step if the link is still available.
To install the ftdi_sio driver use the following steps:
1. Create a temporary folder in your linux machine.
2. Extract the files from ftdi_sio.tar.gz file to your temporary folder
"gunzip ftdi_sio.tar.gz"
"tar -xvf ftdi_sio.tar"
3. Build the driver
"make"
4. Plug in your ftdi device
5. Check to see if default driver was loaded
"lsmod" - you will see ftdi_sio if a driver is loaded
6. Remove the default installed driver
"rmmod ftdi_sio"
7. Install the newly built driver
"insmod ftdi_sio.o"
NOTES:
1.This driver was adapted from the 2.4.32 kernel to support both the 2232C and 232R chip
2.There is no need to follow this procedure if you want 232R chip supprt. The 232BM driver will
be sufficient.Changes made to the driver for the 232R chip are purly cosmetic (plug/unplug will appear as a 232R chip in
the kernel log).
Geplaatst: 24 feb 2009, 08:29
door rottekop
Dan ligt het volgens jou aan die convertor?
Koop een Smargo en je hebt die niet nodig en je zorgen zijn voorbij. 8)
Of plaats een com-poort in je PC en het is ook opgelost ( onder voorbehoud dat het probleem bij die convertor ligt )
Geplaatst: 24 feb 2009, 08:31
door rottekop
Is die client een Dreambox? Stop dan die kaart daar in en maak van de Dreambox een server.
Geplaatst: 24 feb 2009, 08:49
door silencer
IK denk het wel, via de com poort werd er trouwens niets gedecteerd, ook geen seca kaart (er was ook geen lichtje,dat er nu wel is).
Er is een driver geïnstalleerd, maar de laatste versie krijg ik niet geïnstalleeerd(dtfi).
Die dreambox gaat binnnenkort weg.
Geplaatst: 24 feb 2009, 09:07
door rottekop
silencer schreef:IK denk het wel, via de com poort werd er trouwens niets gedecteerd, ook geen seca kaart (er was ook geen lichtje,dat er nu wel is).
Had je voor de compoort ( niet de convertor! ) dan wel het juiste pad in CCcam.cfg staan?
PHOENIX READER PATH : /dev/tts/0
Jouw pad kan verschillen met bovenstaande. Het kan evengoed dit zijn:
PHOENIX READER PATH : /dev/ttyS0
0 = nummer van COM-poort, kan evengoed 1 of iets anders zijn.
Geplaatst: 24 feb 2009, 09:27
door silencer
heb elk denkbaar pad gebruikt, het werkt niet.Moet je iets speciaals installeren voor de compoort?(heb bios settings al aangepast, alleen irq 1-4 worden herhend door xubuntu), heb de indruk dat de com porrten inactief zijn/bezet zijn, waarmee zou ik dit (eenvoudig) kunnen testen?
via usb: ttyUSB0 gaat het wel(seca card detect, meer niet).
Geplaatst: 24 feb 2009, 09:44
door rottekop
silencer schreef: heb elk denkbaar pad gebruikt, het werkt niet.Moet je iets speciaals installeren voor de compoort?(heb bios settings al aangepast, alleen irq 1-4 worden herhend door xubuntu), heb de indruk dat de com porrten inactief zijn/bezet zijn, waarmee zou ik dit (eenvoudig) kunnen testen?
Nog nooit heb ik hiervoor een driver moeten installeren. Alleen gebruikte ik SuSe ipv xubuntu. Nu ik er aan denk: bij een vriend heb ik ook eens gezocht op een dergelijk probleem. De hele avond zoeken zonder resultaat.
Ik zeg gooi er SuSe op en het was meteen in orde. :beerchug:
Hoe je kan testen of iets al dan niet in gebruik is weet ik niet.
Geplaatst: 24 feb 2009, 10:31
door Opus
op mijn debian server heb ik nooit iets moeten installeren .
alles werkte vanaf het moment dat ik het aansloot en een reboot deed.
en nu met de smargo('s is het helemaal makkelijk.
Geplaatst: 24 feb 2009, 10:40
door silencer
suse heb ik eergisteren gedownload(dvd versie,welke desktop versie is dat dan?), gebruik je eigenlijk de desktop versie? (is voor een p3 800mz).Static ip instellen lukte mij niet goed met de vi editor:(broadcast ip e.d.).
Was het ook al aan het overwegen, fedora(geen desktop hier met kde versie) geeft precies dezelfde problemen als ik het zo lees op het net.Zal er vanavond mee starten.
Heeft de dvd versie van suse 11.1 ook een desktop? welke desktop wordt er gebruikt bij de livecd?
Wat presteerd het best als desktop(voor cccam) of is het verschil verwaarloosbaar(ik heb ervaring met de 3 omgevingen)?
* GNOME 2.24
* KDE 4.1 und KDE 3.5
* Xfce und viele mehr!
en mss de belangrijkste vraag: hoe kan je de desktop uitschakelen eens alles in orde is?
Geplaatst: 24 feb 2009, 10:42
door silencer
Opus schreef:op mijn debian server heb ik nooit iets moeten installeren .
probleem is er maar sinds ubuntu 8.04 (volgens sommige bronnen).
Geplaatst: 24 feb 2009, 11:12
door rottekop
silencer schreef: suse heb ik eergisteren gedownload(dvd versie,welke desktop versie is dat dan?), gebruik je eigenlijk de desktop versie? (is voor een p3 800mz).Static ip instellen lukte mij niet goed met de vi editor:(broadcast ip e.d.).
* GNOME 2.24
Bij SuSe kan je kiezen maar ik heb altijd KDE genomen. Ja, gewone desktop geen serverinstallatie.
De presentatie is dezelfde namelijk een terminal.
Vast IP instellen doe je via het start-> configuratiecentrum. Daar kies je YaST2-modules. Kies daar Netwerk apparaten en dan Netwerkkaart. Inloggen als root Dan zie je je netwerkkaart staan. Klik daar op wijzigen en vul maar in. :banana:
Geplaatst: 24 feb 2009, 11:48
door silencer
* GNOME 2.24
Welke meerwaarde heeft de dvd eigenlijk?(kun je daarmee eenvoudiger switchen tussen kde/gnome/xfce?)
Vastip instellen via vi editor lukt mij niet(2 instellingen wist ik niet),via interface uiteraard wel.
Geplaatst: 24 feb 2009, 13:15
door silencer
welke versie is/was dat dan? met welke reader? deze violet trekt stroom via usb, en communiceert via de seriële poort.
@Iedereen bedankt voor de hulp, zag het even niet meer zitten.
Geplaatst: 24 feb 2009, 23:13
door silencer
hmm dezelfde meldingen in suse :s seca card found, card init failed (via usb2serial), zonder usb lukt het gewoon niet.
Geplaatst: 25 feb 2009, 10:35
door lithion
Domme vraag misschien, maar welke kaart is het juist? TV Vlaanderen kaart? Gebruik eventueel eens newcs waar je met cccam op connecteert.
Geplaatst: 26 feb 2009, 14:40
door rottekop
lithion schreef:Domme vraag misschien, maar welke kaart is het juist? TV Vlaanderen kaart? Gebruik eventueel eens newcs waar je met cccam op connecteert.
En ook: werkt de kaart met CCcam in zijn Dreambox? Als dat al niet werkt dan is de kaart niet geactiveerd of kapot of eender wat.
Geplaatst: 26 feb 2009, 23:48
door silencer
heb reeds een smargo werkt perfect,allleen blokt de firewall van xubuntu poorten(weg ermee).
