upgrade firmware voor wag200g annex A op linksys site
Geplaatst: 04 jan 2008, 00:07
door yama
Linksys, A division of Cisco Systems, Inc.
Product: WAG200G Annex-A
Classification: Firmware Release History
Release Date: 17 December, 2007
Firmware Version: 1.01.06 (ETSI)
Language: Multi-language
Note: Not to be used with Annex B models (DE and E1)
____________________________________________________________
1.01.06
- Fixes security issue with XSS and CSRF.
- Fixes issue with UPnP crash when opening 10+ port forwarding.
- Fixes issue with port 5190, 5566, 4443 opening.
- Fixes issue with DSL performance degradation when running P2P program for long time.
- Fixes issue with Access Restriction
- Use new Cisco/Linksys Logo.
- Added Single Port Forwarding entries to 20.
1.01.05
- Add 3 more portmapping fields on Port Forwarding
- Fixes issue with WAN connection not comming up after unplug/plug dsl cable back.
- Fixes issue with Setup Wizard security
- Fixes issue with UI display on 120 DPI.
- Avoides hard rebooting when making changes on 'Basic Setup' and 'Management' page.
- Add Brazilian Portuguese language.
- Updates new cisco Logo.
- Updates Help pages.
1.01.04a
- Fixes issue with not displaying correct value in upstream/downstream transmit power in DSL Connection page
- Fixes issue with ATT VPN client not connecting to ATT VPN network
- Fixes issue with Security information disclosure for UDP port scan packet.
1.01.03
Note: If doesn't self-reboot after upgrade, power off/on WAG200G
- Fixes issue with no disconnect button when GUI language is German
- Fixes issue with Remote Management when WLAN is disabled
- Fixes issue with email address not taking letters '.', '-', and '_'.
- Fixes issue with PPTP connection when PPTP is behind WAG200G
- Fixes issue with Add/Edit services for blocked services
- Fixes issue with DDNS status showing connecting.
1.01.01
Note: If upgrade from current firmware to v1.01.01 is not possible, upgrade to v1.00.09 first.
- Fixes issue with incorrect port range for blocked services
- Fixes issue with WAN DHCP request/offer packet length
- Fixes issue with error for overlapping ports entries on blocked services
- Fixes issue with WAN DHCP LCP echo request
- Fixes issue with Device automatically connecting to the Internet during startup when Connect on Demand is configured
- Fixes issue with WEP key range restriction not enforced
- Fixes issue with incorrect range restriction for MTU Size
- Fixes issue with Internet LED lit when WAN interface disconnected
- Fixes issue with WEP 128-bit generating only 1 WEP Key through pass-phrase
- Fixes issue with PPPoE Connect on Demand not disconnecting after idle timeout period
- Adds incoming and outgoing logs to display network activity
- Adds multiple language feature to firmware, which can be changed without firmware upgrade
1.00.09
- Multi-language DE-EN-FR firmware
- To upgrade from previous firmware versions
1) Upgrade using firmware: WAG200G_V1.00.09_EN.img
2) Upgrade using firmware: WAG200G_A_1.00.09_International.img
1.00.05
- Initial Release
General Notes:
- This firmware is only for usage in Europe with WAG200G Annex A
hardware.
- Disconnect all wireless clients from the Gateway during
the upgrade process. Make sure no wireless clients
attempt to associate with the Gateway until the upgrade
process is complete.
voor de geintereseerden
http://www-nl.linksys.com/servlet/Satel ... siondetail
Geplaatst: 04 jan 2008, 02:12
door laurens7
thxs!
Geplaatst: 04 jan 2008, 20:44
door klooooon
idd hier ook thx
upgrade goed gelukt
Geplaatst: 04 jan 2008, 21:37
door yama
np :wink:
