Telemeter doet gek
Geplaatst: 18 dec 2007, 22:15
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.context.ApplicationContextException: Could not load FreeMarker template for URL [/index.ftl]; nested exception is java.io.FileNotFoundException: Template /index.ftl not found.
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:488)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:431)
javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
org.springframework.web.servlet.view.freemarker.FreeMarkerView.checkTemplate(FreeMarkerView.java:210)
org.springframework.web.servlet.view.freemarker.FreeMarkerView.initApplicationContext(FreeMarkerView.java:161)
org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:73)
org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:72)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:302)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1163)
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:293)
org.springframework.web.servlet.view.UrlBasedViewResolver.loadView(UrlBasedViewResolver.java:413)
org.springframework.web.servlet.view.AbstractCachingViewResolver.createView(AbstractCachingViewResolver.java:159)
org.springframework.web.servlet.view.UrlBasedViewResolver.createView(UrlBasedViewResolver.java:378)
org.springframework.web.servlet.view.AbstractCachingViewResolver.resolveViewName(AbstractCachingViewResolver.java:78)
org.springframework.web.servlet.DispatcherServlet.resolveViewName(DispatcherServlet.java:1179)
org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1123)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:879)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:792)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476)
root cause
freemarker.template.Configuration.getTemplate(Configuration.java:489)
[b].............................. <<<<< nog een hoop tussen[/b]
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.9 logs.
Apache Tomcat/5.5.9Dit is wat ik te zien krijg als ik mij inlog bij de telemeter en dit is al verscheidene dagen zo...
heeft nog iemand last van dit probleem?
