John the ripper
Geplaatst: 08 apr 2006, 13:38
door learning
Heejj,
ik heb juist john the ripper aangeschaft om een gecodeerde map te openen, Maar ik heb geen flauw idee hoe dat programma werkt.
kan iemand mij dat e.v.t. specifiek uitleggen??
dank bij voorbaat
Geplaatst: 08 apr 2006, 13:42
door meon
Nooit van gehoord.
Aangeschaft, lijkt me sterk
Maar goed, wat wil je eigenlijk doen? Je hebt een map gecodeerd? Via wat heb je gecodeerd? Via EFS? Externe tools? En nu ben je het wachtwoord kwijt?
Geplaatst: 08 apr 2006, 14:54
door Robbe
John The Ripper (programma)
John The Ripper (documentatie)
John The Ripper (Darklevel documentatie)
en.wikipedia.org schreef:John the Ripper is a password cracking software tool. Initially developed for the UNIX operating system, it currently runs on fifteen different platforms (11 flavors of Unix, not including flavors who support different architectures, DOS, Win32, BeOS, and OpenVMS). It is one of the most popular password testing/breaking programs as it combines a number of password crackers into one package, autodetects, and includes a customisable cracker. It can be run against various encrypted password formats including several crypt password hash types most commonly found on various Unix flavors (based on DES, MD5, or Blowfish), Kerberos AFS, and Windows NT/2000/XP/2003 LM hash. Additional modules have extended its ability to include MD4-based password hashes and passwords stored in LDAP, MySQL and others.
John operates by the so-called dictionary attack. It takes text string samples (usually from a file containing words found in a dictionary), encrypting it in the same format as the password being examined, and comparing the output to the encrypted string. It can also perform a variety of alterations to the dictionary words and try these. It also offers a brute force mode.
John the Ripper is a perfectly safe program to install and run on your computer. If you are running a multi-user system, you should make sure you are shadowing your password file such that the hashes are not visible; however even if you are not, not installing John will not prevent a malicious user from running John on their own computer with your hashes.
en.wikipedia.org schreef:The EFS or Encrypting File System is a file system available in Microsoft's Windows 2000, Windows XP,Windows Server 2003, and now Windows Media Center 2005 operating systems. The technology transparently allows files to be stored encrypted on NTFS file systems to protect confidential data from attackers with physical access to the computer.
User authentication and access control lists can protect files from unauthorized access while the operating system is running, but are easily circumvented if an attacker gains physical access to the computer. A solution is to store the files encrypted on the disks of the computer. EFS does this using public key cryptography, and aims to ensure that decrypting the files is practically impossible without the correct key. However, EFS does not prevent brute-force attacks against the user account passwords. In other words, file encryption doesn't provide much protection if the account password is easily guessed.
Hackers.nl schreef:Hoe werkt John The Ripper?
john [OPTIONS] [PASSWORD-FILES]
Geplaatst: 08 apr 2006, 16:16
door The_Borg
Zullen we in de eerste plaats maar eens vragen, wat je exact wil openen en waarom je geen paswoord hebt
. Je wil echt niet enkel dictionary attacks gebruiken, beetje achterhaald (wanneer niet gebruikt in combinatie met rainbowtables).
Geplaatst: 08 apr 2006, 17:28
door Blue-Sky
meon schreef:Nooit van gehoord.
Beter houden bij,... geen commentaar, men zou zo ook 'n handleiding kunnen opvragen, hoe kraak je een kluis?
zie punt 2 (geen verwijs naar illegale sites)
Goed zoekwerk overigens, door "Robbe".
Geplaatst: 08 apr 2006, 19:38
door The_Borg
Bwah, op zich is daar niks mis mee hé blue-sky. We voeren hier nog altijd een vooral technische discussie. Een geëncodeerd bestand decoderen is nog altijd niet illegaal lijkt mij (waarschijnlijk komt er hier wel iemand aandraven met wetteksten die het tegendeel beweren, bij deze mijn verontschuldigingen
Ik denk alleen dat je aan een dictionary attack niet veel gaat hebben, je gaat behoorlijk lang bezig zijn. Moest je ons nu vertellen wat voor een bestand het is, dan zouden we je kunnen voort helpen in de mate dat we dat ethisch verantwoord vinden (Nu zijn de pezewevers ook content
Geplaatst: 08 apr 2006, 20:09
door netdata
The_Borg schreef:Bwah, op zich is daar niks mis mee hé blue-sky. We voeren hier nog altijd een vooral technische discussie. Een geëncodeerd bestand decoderen is nog altijd niet illegaal lijkt mij (waarschijnlijk komt er hier wel iemand aandraven met wetteksten die het tegendeel beweren, bij deze mijn verontschuldigingen
Zolang er geen concrete illigale dingen worden vernmoemd lijkt mer er ook niets fout mee.
Zolang men ook duidelijk de lijn trekt dat dit enkel op je eigen infrastructuur/bestanden mag is er niets fout mee.
Maar het is idd een donkerbruin puntje...
Geplaatst: 08 apr 2006, 21:59
door Blue-Sky
Mag wel zijn dat daar niets verkeerd mee is, zelf wil ik geen risico nemen om daar iets over prijs te geven. (als ik het dan zou weten)
Ben ooit zelf wel eens een wachtwoord vergeten, een nieuw aanvragen is de boodschap.
Nu, als je er onder studenten een spel wil van maken, voor mij niet gelaten, alleen dat ik daar niet in meespeel.
Er altijd zorg voor dragend dat UB geen vervelende vragen moet beantwoorden aan een officier van de veiligheid.
Op die wijze zou een sluwe onderzoeker ook een bliekje kunnen werpen om een snoekje te vangen, zo met het idee... eens zien hoever de bekwame experten van UB daarin willen gaan om daar iets over los te laten.
(voor aprilvissen is het nu wel te laat)
Geplaatst: 09 apr 2006, 17:27
door netdata
Blue-Sky schreef:Mag wel zijn dat daar niets verkeerd mee is, zelf wil ik geen risico nemen om daar iets over prijs te geven. (als ik het dan zou weten)
Bwa blue-sky das relatief he.
Ik heb hier thuis ook vele netwerk tools die alleen maar voor hacking bedoeld zijn.
Maar ik gebruik deze voor legale doeleinde.
Namelijk security audits doen...
Geplaatst: 10 apr 2006, 12:15
door gedeco
Alle info over John de ripper en meer vindt je heel makkelijk terug via google.
De tool zelf is niet illegaal en kan gebruikt worden om een assesment te doen van het eigen beveiligingsniveau.
In feite wordt deze tool meer gebruikt door admins die hun beveiliging testen dan hackers.
Enkel maar het gebruik kan illegaal zijn....
Streetraces zijn ook illegaal, maar meestal zijn de wagens die deelnemen wel legaal (of bijna).
