Dat begrijp ik ook niet echt.
Volgens het vdsl toolke dat ik vroeger gebruikte was de snr met de sagem modem vroeger tussen de 15 a 20 db nu nog 9 db
dit zijn lijnwaarden van 2012
* VDSL2Tool 2.3 -
http://hierzo.net/ *
                        download          upload
Line:                  30064 kbps        6048 kbps
Modem max:             95776 kbps        n/a Estimated!
Calculated max:        78637 kbps         16476 kbps Estimated!
Profile:               17a
Line length:           226 m Estimated!
Training margin:       24.2 dB
Attenuation:           5.9 dB
Heb even contact opgenomen met edpnet.
Volgens edpnet zijn mijn lijnwaarden uitstekend.
Training marging , hoe hoger hoe beter dus 24.2 is zeer goed
Attenuation : hoe lager hoe beter dus 6 is zeker niet slecht
Heb deze tekst gevonden op het internet :
SN Margin (AKA Signal to Noise Margin or Signal to Noise Ratio)
Relative strength of the DSL signal to Noise ratio. 6dB is generally the lowest dB manufactures specify in order for the modem to be able to synch. In some instances interleaving can help raise the noise margin to an acceptable level. Generally speaking, as overall bandwidth increases, your signal to noise ratio decreases. So a customer that upgrades from 1.5 to 6.0 service will typically see a corresponding decrease in the signal to noise ratio. The higher the number the better for this measurement.
6dB or below is bad and will experience no synch or intermittent synch problems
7dB-10dB is fair but does not leave much room for variances in conditions
11dB-20dB is good with no synch problems
20dB-28dB is excellent
29dB or above is outstanding
Line Attenuation
Measure of how much the signal has degraded between the DSLAM and the modem. Maximum signal loss recommendation is usually about 60dB. One of the biggest factors affecting line attenuation is distance from the DSLAM. Generally speaking, bigger distances mean higher attenuation. The lower the dB the better for this measurement.
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
