<?php
Copyright (C) 2007 Koen Vandenabeele
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Credits:
- curl fetching code by Devil_Kin
// Configuration
$username = 'username'; // aanpassen
$password = 'pass'; // aanpassen
// Don't touch
$clientid = 0;
$servid = 0;
function filter($string) {
$items = array('<br>','</br>','<b>','</b>','<i>','</i>',"onClick=\"MM_openBrWindow2('","','webadmin','schedom')\"><img");
foreach ($items as $item) {
$string = str_replace($item,' ',$string);
return $string;
function clean($array) {
$newarray = array();
foreach ($array as $item) {
if ($item!=' '&&$item!='') {
array_push($newarray,$item);
return $newarray;
function calculate() {
global $username,$password,$clientid,$servid;
$ch = curl_init();
// login
$url = "https://crm.schedom-europe.net/login.php?username=$username&password=$password&op=login";
curl_setopt($ch, CURLOPT_URL, $url);
curl_setopt($ch, CURLOPT_HEADER, 1);
curl_setopt($ch, CURLOPT_USERAGENT, $_SERVER['HTTP_USER_AGENT']);
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_COOKIEJAR, $cookiejar);
curl_setopt($ch, CURLOPT_COOKIEFILE, $cookiejar);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $vars);
curl_exec($ch);
// get servid & clientid
$newurl = 'https://crm.schedom-europe.net/user.php?op=view&tile=mypackages';
curl_setopt($ch, CURLOPT_URL, $newurl);
curl_setopt($ch, CURLOPT_USERAGENT, 'Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1)'); // IE6
curl_setopt($ch, CURLOPT_HEADER, false);
curl_setopt($ch, CURLOPT_COOKIESESSION, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$buffer = curl_exec($ch);
$buffer = explode("\n",$buffer);
foreach ($buffer as $line) {
if (strstr($line,'dslinfo')) {
$line = filter($line);
$line = explode(' ',$line);
$line = clean($line);
$url = parse_url($line[2]);
$query = $url['query'];
$query = explode('&',$query);
$query[0] = explode('=',$query[0]);
$query[2] = explode('=',$query[2]);
$servid = $query[0][1];
$clientid = $query[2][1];
break;
// count
$newurl = "https://crm.schedom-europe.net/include/scripts/linked/dslinfo/dslinfo.php?servid=$servid&password=$password&client_id=$clientid";
if (strstr($line,'downloaded in broadband:')) {
$downloaded = $line[5];
$total = $line[21]+$downloaded;
break;
$fp = fopen('traffic.txt','w');
fputs($fp,time()." $downloaded $total");
fclose($fp);
function lastupdated() {
if (file_exists('traffic.txt')) {
$fp = fopen('traffic.txt','r');
$buffer = fgets($fp);
$buffer = explode(' ',$buffer);
return $buffer[0];
fclose($fp);
} else {
return 0;
if ((time()-lastupdated())>600) {
calculate();
// ------------- show image
header("Content-type: image/png");
// initialize
$im = imagecreatefrompng("./sig.png");
$white = imagecolorallocate($im, 255, 255, 255);
$black = imagecolorallocate($im, 0, 0, 0);
// add text
$buffer = file_get_contents("./traffic.txt");
imagettftext($im,10,0,140,14,$black,"./visitor1.ttf",$buffer[1]." / ".$buffer[2]);
// show
imagepng($im);
imagedestroy($im);
