Re: Bbox3 Sagem Tool
Geplaatst: 27 mei 2015, 17:22
Lol....mooi voorbeeld van hoe snel een lijnsnelheid toch kan verbeteren
Van 16/0,5 naar 70/10 op hoeveel tijd?
B-Box 3 Sagem Tool v0.8
Device: B-Box 3 Sagem
Downstream current bit rate: 69.999 kbps
Upstream current bit rate: 10.064 kbps
Downstream max bit rate: 121.359 kbps
Upstream max bit rate: 25.288 kbps
Downstream attenuation: 12,7 dB
Downstream noise margin: 20,9 dB
Upstream noise margin: 15,3 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: Yes
Proximus profile: LP145
DLM: No
Repair: No
Distance (experimental): 281 m
B-Box 3 Sagem Tool v0.9
Downstream current bit rate: 69 999 kbps
Upstream current bit rate: 10 064 kbps
Downstream max bit rate: 90 953 kbps
Upstream max bit rate: 15 049 kbps
Downstream attenuation: 11,5 dB
Downstream noise margin: 11,9 dB
Upstream noise margin: 8,2 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: Yes
DLM: No
Repair: No
Distance (experimental): 275 m
Downstream current bit rate: 49,999 kbps
Upstream current bit rate: 6,063 kbps
Downstream max bit rate: 111,131 kbps
Upstream max bit rate: 25,592 kbps
Downstream attenuation: 16.3 dB
Downstream noise margin: 25.1 dB
Upstream noise margin: 19.8 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: Yes
Proximus profile: LP137
DLM: No
Repair: No
Distance (experimental): 442 mCode: Selecteer alles
Downstream current bit rate: 50,199 kbps
Upstream current bit rate: 10,004 kbps
Downstream max bit rate: 63,982 kbps
Upstream max bit rate: 10,004 kbps
Downstream attenuation: 13.4 dB
Downstream noise margin: 12.8 dB
Upstream noise margin: 0.0 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
Proximus profile: LP058
DLM: Yes
Repair: No
Distance (experimental): 355 mK'wist dat je al een manier had voor de Technicolor, maar ook voor de Sagem? Nice!Petervanakelyen schreef:Kom eens langs, daar kan voor gezorgd worden
Downstream max bit rate: 124 311 kbps
Upstream max bit rate: 22 270 kbps
Downstream attenuation: 11,6 dB
Downstream noise margin: 22,4 dB
Upstream noise margin: 13,1 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: Yes
DLM: No
Repair: No
Distance (experimental): 270 m
Device B-Box 3 Sagem
Downstream current bit rate 69†999 kbps
Upstream current bit rate 10†049 kbps
Downstream max bit rate 84†611 kbps
Upstream max bit rate 10†049 kbps
Downstream attenuation 10,0 dB
Downstream noise margin 11,1 dB
Upstream noise margin 0,0 dB
DSL standard VDSL2
VDSL2 profile 17a
Vectoring Yes
Proximus profile LP145
DLM No
Repair No
Distance (experimental) 225 mCode: Selecteer alles
Downstream current bit rate: 50 200 kbps
Upstream current bit rate: 10 054 kbps
Downstream max bit rate: 89 179 kbps
Upstream max bit rate: 128 kbps
Downstream attenuation: 11,0 dB
Downstream noise margin: 19,4 dB
Upstream noise margin: 11,5 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
DLM: Yes
Repair: No
Distance (experimental): 245 m
Downstream current bit rate: 50.200 kbps
Upstream current bit rate: 10.054 kbps
Downstream max bit rate: 59.117 kbps
Upstream max bit rate: 10.054 kbps
Downstream attenuation: 11,3 dB
Downstream noise margin: 8,8 dB
Upstream noise margin: 0,0 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
DLM: Yes
Repair: No
Upstream current bit rate: 10.049 kbps
Downstream max bit rate: 52.211 kbps
Upstream max bit rate: 10.049 kbps
Downstream attenuation: 11,2 dB
Downstream noise margin: 6,6 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
DLM: Yes
Repair: No
Distance (experimental): 239 m
Je moet de login gebruikt die op de Bbox staat. Ben je zeker dat 'user' is aangeduid? Dat je hoofdletters hebt gebruikt in het wachtwoord waar nodig? Een nul of een o hebt verwisseld?fsi01 schreef:Bij het inloggen als user in de Sagem Tool krijg ik steed de meldong login incorrect
Downstream current bit rate: 30 057 kbps
Upstream current bit rate: 4 046 kbps
Downstream max bit rate: 42 677 kbps
Upstream max bit rate: 4 046 kbps
Downstream attenuation: 18,1 dB
Downstream noise margin: 16,4 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
Proximus profile: LP039
DLM: Yes
Repair: No
Distance (experimental): 602 m
Inderdaad waarschijnlijk 8d, zone 3, 16.5/2 > DLM 30/4hardyscript schreef:Wat ik mij hier afvraag of het werkelijk een 17a profiel is... volgens mij is dit een 8d profiel.Code: Selecteer alles
B-Box 3 Sagem Tool v0.9 ----------------------- Device: B-Box 3 Sagem Downstream current bit rate: 30 057 kbps Upstream current bit rate: 4 046 kbps
Klopt dit ?
VDSL for me now =) Thanks Pyro85 for this softphilippe_d schreef:@pyro85
Ik heb wat promotie gemaakt voor jouw tooltje op het Franstalig Forum, waar ze ook zeer enthousiast reageren. De vroegere B-box2 modem tool van Arowan was hier ook zeer geliefd.
https://forum.adsl-bc.org/viewtopic.php ... 2#p1446932
Hieronder - voor jouw statistieken - een aantal resultaten voor het Franstalig gedeelte:
Arowan » 04 Fév 2015 17:12Code: Selecteer alles
Bbox 3 Sagem Tool v0.3 ---------------------- Downstream current bit rate: 4.448 kbps Upstream current bit rate: 512 kbps Downstream max bit rate: 4.864 kbps Upstream max bit rate: -1 kbps Downstream attenuation: 48,5 dB Upstream attenuation: -0,1 dB Downstream noise margin: 15,0 dB Upstream noise margin: 6,1 dB Proximus profile: unknown VDSL2 profile: unknown DLM: False Repair: False Vectoring: False
Dat zal inderdaad geen vectoring profiel zijn, de upload zou anders 10064 zijn. Ik zal hiermee rekening houden in de volgende versie.AndRo555 schreef:Volgens mij waren de waarde vroeger met een bbox2 en DLM op 70/6 vergelijkbaar, 84Mbps down is niet echt vectoring waardig imho.Code: Selecteer alles
B-Box 3 Sagem Tool v0.9 ----------------------- Device B-Box 3 Sagem Downstream current bit rate 69†999 kbps Upstream current bit rate 10†049 kbps Downstream max bit rate 84†611 kbps Upstream max bit rate 10†049 kbps
Ook verdacht dat de upstream max bitrate exact hetzelfde is waarop de modem zich intraint.
Dit zal een bug zijn, in de volgende versie herschrijf ik de functies die de max bitrate sophalen om ze efficienter te maken, dus hopelijk zal het dan opgelost zijn.Dizzy schreef:Upstream max bit rate lijkt me raar???Code: Selecteer alles
Downstream max bit rate: 89 179 kbps Upstream max bit rate: 128 kbps
Kan misschien liggen aan het moment op de dag waarop je de test gedaan hebt. Ik vermoed dat op de daluren de waarden wat beter zijn aangezien er dan minder crosstalk is?brampiec schreef:Al lijken mijn lijnwaarde lichtjes verbeterd te zijn. Waar aan zou dit kunnen liggen?
De tool heeft het profiel uit zone 2 gekozen omwille van de afstand, terwijl het inderdaad een zone 3 profiel zou moeten zijn. Ik denk dat de afstandbepaling wat te optimistisch is voor langere afstanden.philippe_d schreef:Ja, maar een 17a profiel, zelfs achteraan in zone 2, zou waarschijnlijk een veel betere "downstream max bitrate" geven?
You're welcome. Your speed increased more then 10 times, you must be happyarowan schreef:VDSL for me now =) Thanks Pyro85 for this soft
Post made via mobile device ]
Post made via mobile device ]Code: Selecteer alles
Downstream current bit rate: 16 550 kbps
Upstream current bit rate: 2 054 kbps
Downstream max bit rate: 35 097 kbps
Upstream max bit rate: 2 054 kbps
Downstream attenuation: 19,7 dB
Downstream noise margin: 18,9 dB
DSL standard: VDSL2
VDSL2 profile: 8d
Vectoring: No
Proximus profile: LP106
DLM: Yes
Repair: No
Distance (experimental): 642 m
Downstream current bit rate: 20.061 kbps
Upstream current bit rate: 6.048 kbps
Downstream max bit rate: 91.634 kbps
Upstream max bit rate: 1.256 kbps
Downstream attenuation: 14,5 dB
Downstream noise margin: 30,8 dB
Upstream noise margin: 19,5 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
Proximus profile: LP707
DLM: No
Repair: Yes
Distance (experimental): 367 m
De windows versie zou niks mogen uitmaken, zolang .NET 4 geïnstalleerd is. K'heb zo het vermoeden dat het telnet commando 'vdsl pstatex' niet zal lukken met een ADSL verbindingAmazor schreef:De modem is nog geen jaar oud, dus hardware-matig wellicht een van de laatste b-box2's en heeft nieuwste firmware, niet onbelangrijk om te vermelden is dat het om een ADSL-verbinding gaat. De tool (0.9) werd getest met Windows 10 Pro x64, onder Windows XP (ik weet het, andere uiterste) krijg ik de tool helemaal niet aan de praat.
Upstream current bit rate: 10 039 kbps
Downstream max bit rate: 91 595 kbps
Upstream max bit rate: 192 kbps
Downstream attenuation: 7,9 dB
Downstream noise margin: 14,5 dB
Upstream noise margin: 12,0 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: Yes
DLM: No
Repair: No
Distance (experimental): 150 m
Upstream max bit rate: 1.256 kbps--------------------------------
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
DLM: No
Repair: Yes
Upstream max bit rate: 20.808 kbps------------------------------
Upstream noise margin: 19,3 dB
DSL standard: VDSL2
VDSL2 profile: 17a
Vectoring: No
DLM: No
Repair: Yes
