Planet PoE Injector Hub (Model PoE-1200)
shiseido
Bedankt: 18 keer
The PLANET POE-1200 is a 12-Port IEEE 802.3af Power over Ethernet injector hub and complies with IEEE 802.3, IEEE 802.3u and IEEE 802.3af standards. With 12 10/100Base-TX Fast Ethernet ports, this device supports full 48VDC power for any remote IEEE 802.3af powered device (PD) like Wireless LAN Access Point, IP phone, and IP Camera. Supporting power supply of 110 watts, POE-1200 provides sufficient power to 12 remote PD devices. The POE-1200 is installed between a regular Ethernet Switch and the powered devices, injecting power without affecting the data transmission. It offers a cost effective and quick solution to upgrade network system to IEEE 802.3af Power over Ethernet system without replacing the existing Ethernet Switch.
Hardware Specifications
Ethernet Ports: "Data" Input Ports: 12 x RJ-45 STP, "Data + Power" Output Ports: 12 x RJ-45 STP, Management Port: 1 x RJ-45; 10/100Base-TX, auto-negotiation, auto-MDI / MDIX
PoE Ports: 12
Power Requirement: 100-240V AC, 50/60 Hz
Power Consumption: 130 watts max.
LED Display: System: Power x 1 (Green); Management Port x 2: 10/100 (Green / Orange); Per PoE Port: PoE in Use x 1 (Green)
Dimension (W x D x H): 440 x 200 x 44 mm
Weight: 2.7kg
Operating Temperature: 0 ~ 50 Degree C, 5 ~ 95% (Non-condensing)
Power over Ethernet Specifications
PoE Standard: IEEE 802.3af Power over Ethernet / Mid-Span PSE
PoE Power Supply Type: Mid-Span
PoE Power Output: Per Port 48V DC, 350mA . Max. 15.4 watts
Power Pin Assignments: 4/5(+), 7/8(-)
PoE Power Budget: 110 Watts
Regulation Compliance: FCC Part 15 Class A, CE
Standards Compliance: IEEE 802.3 10Base-T Ethernet, IEEE 802.3u 100Base-TX Fast Ethernet, IEEE 802.3af Power over Ethernet
Full specs: http://www.planet.com.tw/en/product/ima ... 00v2_s.pdf
Toestel heeft enkele krasjes aan de boven & onderzijde (zie foto's).
Fan is aan vervanging toe (sleept soms zachtjes)
Bieden vanaf 10 euro excl. -- meeneem is 20 euro.
Verzending via B-post, of ophaal te Lier.
Afsluiting 72u na het hoogste bod.
Cheers,
Shiseido
SpecialK
Bedankt: 148 keer
10 eur.
petzl
Bedankt: 83 keer
15 euro, met rondleiding in het fort van lier op vrijdag 24/03 :)
petzl
Bedankt: 83 keer
maak er maar 20 euro van :) en je mag hem bezorgen op het fort van lier :) met rondleiding.
hier alvast een voorproefje van de buitenkant :
shiseido
Bedankt: 18 keer
Dealio!
PM komt eraan :-)
