[Te Koop] MikroTik gear, HDD's, SSD's, QuadCore 16GB RAM, ...
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 17:02
Zo, kuis gehouden vandaag en hierbij nog een beetje stuff
2x (NEW) MikroTik Fiber to Ethernet convertor outdoor RBFTC11 + (USED) Cisco 1000BASE-SX Single Mode Fiber module
Product code RBFTC11
10/100/1000 Ethernet ports 1
Can be used indoors Yes
Can be used outdoors Yes
Max power consumption 3 W
PoE in 12-57V
SFP ports 1
Storage size 1 KB
Storage type FLASH
Tested ambient temperature -40C... +70C
infolink: https://mikrotik.com/product/RBFTC11
Prijs per stuk: 33 Euro incl zending naar DPD punt
1x (NEW) MikroTik CRS105-5S-FB FiberBox outdoor + (NEW) Gbit Mikrotik ethernet SFP S-RJ01 + (USED) 2x Cisco 1000BASE-SX Single Mode Fiber module
Product code CRS105-5S-FB
Architecture MIPSBE
CPU QCA8511
CPU core count 1
CPU nominal frequency 400 MHz
Dimensions 125 x 178 x 48 mm
License level 5
Operating System RouterOS
Size of RAM 128 MB
Storage size 16 MB
Storage type FLASH
Tested ambient temperature -20°C to 70°C
Number of DC inputs 1 (DC jack)
DC jack input Voltage 9-30 V
Max power consumption 11 W
SFP ports 5
infolink: https://mikrotik.com/product/fiberbox
Prijs per stuk: 66 Euro incl zending naar DPD punt
6x (USED) Kingston SSDNOW 300 60GB
Type: SV300S37A60G
Storage: 60GB
Controller: SandForce SF2281
Zie https://we.tl/t-m86BHVZKvJ voor keuze SSD/HDD SMART status
Prijs per stuks: 7,50 Euro incl zending (naar DPD punt vanaf 2+ stuks, bpost voor 1 stuk)
3x (USED) Seagate Barracuda 1TB
Type: ST1000DM003 / ST1000DX001
Storage: 1TB
Prijs per stuks: 12 Euro incl zending naar DPD punt
1x (USED) SAMSUNG SpinPoint 750GB
Type: HD753LJ
Storage: 750GB
Prijs per stuks: 9 Euro incl zending naar DPD punt
1x (USED) Seagate Barracuda 4TB
Type: ST5000DM004 COMPUTE
Storage: 4TB
Prijs per stuks: 40 Euro incl zending naar DPD punt
1x (USED) ASUS M5A78L-M/USB3 + AMD FX-4100 3.6Ghz + 32GB RAM Kingston
ASUS M5A78L-M/USB3 + AMD FX-4100 3.6Ghz +16GB RAM Kingston
Draait perfect VMware ESXI of Citrix Xenserver of Proxmox voor virtualisatie, samen met 6 SATA ports veel opslag mogelijkheid
Gelid 1U Cooler, let op deze cooler werkt nog maar de fan maakt lawaai, is aan vervanging toe!
CPU: AMD FX-4100 Quad Core 3.6Ghz
Chipset: AMD 760G (780L)/SB710
RAM: 4 x DIMM
Video: Integrated ATI Radeon™ HD 3000 GPU
Slots: 1 x PCIe x16 + 1 x PCIe x1 + 2 x PCI
SATA: 6 x SATA 3Gb/s port(s), Support Raid 0, 1, 10, JBOD
LAN: Realtek®, 1 x Gigabit LAN Controller(s)
Ports: 10 x USB 2.0 port(s) (4 at back panel, black, 6 at mid-board) + 2 x USB 3.1 Gen 1 port(s) (2 at back panel, blue)
Form factor: uATX Form Factor ( 24.4 cm x 24.4 cm )
Prijs per stuks: 35 Euro incl zending naar DPD punt
1x (USED) Supermicro SC512 case pakket (3 in één doos)
Supmicro SC512 1U case
1U server case met rack oortjes
Cooler
260Watt voeding inclusief
infolink: https://www.supermicro.com/en/products/ ... SC512-200B
Prijs per stuks: 25 Euro incl zending naar DPD punt
Zending? Dit gaat naar een DPD punt tenzij anders vermeld. Ik ga dit echter enkel op vrijdagen weg doen, dus een iets trage zending.
Tim Bracquez, [email protected], https://www.fusa.be
Dedicated Servers & Promoties - https://fusa.be/nl/hosting/offer
MikroTik Routerboards - https://fusa.be/shop
Block
Bedankt: 50 keer
Re: MikroTik gear, HDD's, SSD's, QuadCore 16GB RAM, ...
Berichtdoor Block » 04 Mei 2020, 17:46
45 euro voor asus mobo +750 gigabyte HD
Scarlet one
Kiwivogel
Bedankt: 15 keer
Berichtdoor Kiwivogel » 04 Mei 2020, 18:05
Volgens mij is het niet met bieden he? Mocht Block het mobo + cpu en ram niet meer willen ben ik kandidaat.
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 18:06
@Kiwivogel: Block heeft een PM, als dit niet door gaat laat ik dit hier weten. Dit is inderdaad de all-in prijs (inclusief zending!). Er zijn ook nog een hele hoop andere schijven en SSD's te koop.
bartlimb
Bedankt: 7 keer
Berichtdoor bartlimb » 04 Mei 2020, 18:09
Doe je eventueel verzending via Bpost voor de Seagate 4TB voor 40 euro?
Bedankt: 587 keer
Berichtdoor ITnetadmin » 04 Mei 2020, 18:11
Voor mij de 4TB HDD aub.
Kan goed dienen als extra backup disk.
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 18:12
@Bartlimb: Sorry enkel DPD, ga niet extra postpunten binnen gaan. DPD kan naar een pickup locatie in je buurt en is met tracking etc. Is goedkoopste en snelste optie voor mij.
bartlimb
Bedankt: 7 keer
Berichtdoor bartlimb » 04 Mei 2020, 18:13
Ok doe dan maar verzending via DPD dan.
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 18:16
@Bartlimb, ITNETADMIN was je voor met zending DPD
bartlimb
Bedankt: 7 keer
Berichtdoor bartlimb » 04 Mei 2020, 18:22
Ok geen probleem
Bedankt: 963 keer
Uitgedeelde bedankjes: 1826 keer
Contact:
Berichtdoor krisken » 04 Mei 2020, 18:57
Graag 4x Kingston SSDNOW 300 60GB (= 30 euro)
GSM = Orange Intense Smartphone + Scarlet Red
TV = App TV + Netflix + Disney+
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 19:00
Volgende nog beschikbaar:
2x (USED) Kingston SSDNOW 300 60GB ( SSD 5 & SSD 6 )
honda4life
Bedankt: 284 keer
Uitgedeelde bedankjes: 164 keer
Berichtdoor honda4life » 04 Mei 2020, 19:03
Geef mij maar zo'n SSD'ke, ideaal voor op m'n oude experimenteer/prutslaptop met Ubuntu ;-)
Ernie
Bedankt: 40 keer
Berichtdoor Ernie » 04 Mei 2020, 19:53
Voor mij SSD 6 graag.
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 19:54
@ERNIE 5 ook goed? de 6 is net door honda4life genomen
Ernie
Bedankt: 40 keer
Berichtdoor Ernie » 04 Mei 2020, 20:02
Ah, honda4life had niets gespecificeerd en ging er van uit dat het dan op volgorde was..
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 20:05
Nee, maar ik had ze toegewezen aan hem, is al ingepakt en zegels plakken er al op :-)
Had je graag de 5 of blijft deze vrij voor iemand anders ?
Ernie
Bedankt: 40 keer
Berichtdoor Ernie » 04 Mei 2020, 20:11
Ok dan SSD 5
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 04 Mei 2020, 23:13
Alles is al ingepakt en staat klaar, iedereen die al screenshot doorgestuurd heeft zal reeds een dpd tracking code krijgen :)
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 05 Mei 2020, 19:03
Zo, enkel nog de fiber gear van MikroTik beschikbaar en de 3x 1TB HDD's
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 11 Mei 2020, 02:44
HDD's ook verkocht
Enkel nog de MikroTik fiberboxen beschikbaar met fiber modules:
- 2x (NEW) MikroTik Fiber to Ethernet convertor outdoor RBFTC11 + (USED) Cisco 1000BASE-SX Single Mode Fiber module
- 1x (NEW) MikroTik CRS105-5S-FB FiberBox outdoor + (NEW) Gbit Mikrotik ethernet SFP S-RJ01 + (USED) 2x Cisco 1000BASE-SX Single Mode Fiber module
wim.pi
Berichtdoor wim.pi » 24 Mei 2020, 13:23
Ik heb interesse in wat er nog over is (de MikroTik fiberbox en de 2 fiber modules), wel een vraag over die Cisco 1000BASE-SX SFP modules. Volgens mij zijn die multimode? En ik vermoed dat die compatibel zijn met die MikroTik modules/box?
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 24 Mei 2020, 13:39
@wim.pi: Klopt, zijn multimode, en inderdaad compatibel met de fiberbox, worden herkend.
oliviermaes
Bedankt: 7 keer
Berichtdoor oliviermaes » 24 Mei 2020, 14:42
Tim.Bracquez schreef:Enkel nog de MikroTik fiberboxen beschikbaar met fiber modules:
Incl PoE injectors?
Welke connector voor fiber?
Verkoop B2B mogelijk of is particulier.
(Interesse gezien lopend topic)
Tim.Bracquez
Twitter: fusabe
Bedankt: 430 keer
Contact:
Berichtdoor Tim.Bracquez » 24 Mei 2020, 14:53
Spijtig genoeg alles al verkocht, en overal zitten POE injectors bij
Gebruikers op dit forum: Geen geregistreerde gebruikers en 3 gasten
