[Te Koop] 2x Intel Xeon E5-2650 SROKQ 2.00-2.8GHz 8-Core LGA2011
keerekeerweere
Bedankt: 11 keer
Contact:
Berichtdoor keerekeerweere » 26 Okt 2020, 20:49
2 matched CPU's Intel Xeon E5-2650 V1 uit een server systeem.
Richtprijs: 60,- € voor beide samen
Opsturen: via Bpost naar adres 5,7 € of naar afhaalpunt 4,7 €
Afhaling: mogelijk na afspraak in Opwijk
Wordt ook elders aangeboden
Intel Xeon E5-2650 SR0KQ 8 Core H.T. 2 GHz / 2,8Ghz Turbo Socket 2011 20MB C2
Performance Specifications
# of Cores 8
# of Threads 16
Processor Base Frequency 2.00 GHz
Max Turbo Frequency 2.80 GHz
Cache 20 MB Intel® Smart Cache
Bus Speed 8 GT/s
# of QPI Links 2
Intel® Turbo Boost Technology 2.0 Frequency‡ 2.80 GHz
TDP 95 W
VID Voltage Range 0.60V-1.35V
Memory Specifications
Max Memory Size (dependent on memory type) 384 GB
Memory Types DDR3 800/1066/1333/1600
Max # of Memory Channels 4
Max Memory Bandwidth51.2 GB/s
ECC Memory Supported Yes
PCI Express Revision 3.0
Max # of PCI Express Lanes 40
Package Specifications
Sockets Supported FCLGA2011
Max CPU Configuration 2
Advanced Technologies
Intel® Turbo Boost Technology ‡ 2.0
Intel vPro® Platform Eligibility ‡ Yes
Intel® Hyper-Threading Technology ‡ Yes
Intel® Virtualization Technology (VT-x) ‡ Yes
Intel® Virtualization Technology for Directed I/O (VT-d) ‡ Yes
Intel® VT-x with Extended Page Tables (EPT) ‡ Yes
Intel® 64 ‡ Yes
Instruction Set 64-bit
Instruction Set Extensions Intel® AVX
Idle States Yes
Enhanced Intel SpeedStep® Technology Yes
Intel® Demand Based Switching Yes
Thermal Monitoring TechnologiesYes
Intel® Flex Memory Access No
Intel® Identity Protection Technology ‡ No
Security & Reliability
Intel® AES New Instructions Yes
Intel® Trusted Execution Technology ‡ Yes
Execute Disable Bit ‡ Yes
Fastic Subfastic VDSL 85/35 - BBox 3V+ - OPNSense - VOIP OVH on Fritz!Box 7390
keerekeerweere
Bedankt: 11 keer
Contact:
Re: 2x Intel Xeon E5-2650 SROKQ 2.00-2.8GHz 8-Core LGA2011
Berichtdoor keerekeerweere » 27 Okt 2020, 18:49
keerekeerweere schreef:2 matched CPU's Intel Xeon E5-2650 V1 uit een server systeem.
Prijsverlaging: 50,- € voor beide samen
keerekeerweere
Bedankt: 11 keer
Contact:
Berichtdoor keerekeerweere » 02 Nov 2020, 17:50
Bump en laatste poging...
Prijsverlaging: 40,- € voor beide samen
