[EN] Playstation 4 - avoiding NAT3 in Belgium
komaeu
Berichtdoor komaeu » 05 Feb 2015, 11:49
Currently I have telenet and it is not possible to setup NAT2 for PS4. This is caused by poor quality router, even when PS4 is set as DMZ it works in NAT3. Soon I will move and in new flat I can get:
belgacom
Voo
Both offers the same things but I wonder if PS4 NAT2 works fine any of them.
r2504
Bedankt: 1962 keer
Re: [EN] Playstation 4 - avoiding NAT3 in Belgium
Berichtdoor r2504 » 05 Feb 2015, 12:01
I know several people with a PS4 and Telenet... none of them has issues... so I guess something else is wrong.
The is what I could find BTW...
Yeah, NAT 1 is straight from the modem to the PS3. NAT 2 is CORRECTLY running from a router to the PS3, and NAT 3 in INcorrectly running from a router to the PS3. The main thing that causes NAT 3 is not having the correct ports opened up on the router.
komaeu
Berichtdoor komaeu » 05 Feb 2015, 12:03
I got bbox 3 router. Even when I set PS4 in DMZ it is still NAT3. You can still play online but then you are not able to host games for other players.
edit: i tried also forward all ports. As far as I know there is well know issue with bbox 3 and PS4 (maybe not affecting PS3).
Laatst gewijzigd door komaeu op 05 Feb 2015, 12:04, 1 keer totaal gewijzigd.
r2504
Bedankt: 1962 keer
Berichtdoor r2504 » 05 Feb 2015, 12:04
Even in the DMZ you still need to forward the required ports !
komaeu
Berichtdoor komaeu » 05 Feb 2015, 12:08
I forwarded them just to check all combinations(with/without DMZ), didn't work.
Anyway I am suprised when you say that DMZ needs port forwarding.
Application TCP Ports UDP Ports
PlayStation 4 80, 443, 1935, 3478-3480 3478-3479
r2504
Bedankt: 1962 keer
Berichtdoor r2504 » 05 Feb 2015, 12:11
komaeu schreef:Application TCP Ports UDP Ports
Isn't this game dependant ?
r2504
Bedankt: 1962 keer
Berichtdoor r2504 » 05 Feb 2015, 12:13
Just check this... http://playstationclan.be/index.php?topic=36.0 (BTW disabling homespot is nonsens).
komaeu
Berichtdoor komaeu » 05 Feb 2015, 12:14
Ok man. I will try to do some more research today, maybe I will achieve something. Thanks.
Bedankt: 256 keer
Uitgedeelde bedankjes: 465 keer
Berichtdoor Tomby » 05 Feb 2015, 12:15
r2504 schreef:Even in the DMZ you still need to forward the required ports !
Care to elaborate ? AFAIK putting a client in the DMZ causes all incoming connections to be sent to that client anyway. If you put a PS4 in the DMZ, there should be no port forwarding rules required.
Kenw00t
Bedankt: 248 keer
Uitgedeelde bedankjes: 345 keer
Berichtdoor Kenw00t » 05 Feb 2015, 12:23
A Telenet user with a Bbox3? Not the usual combination. :-)
Proximus Internet Comfort + TV @ Fritz!Box 7360 v2 6.52 @ 85/15
Orange @ Sony Xperia Z3 Compact
r2504
Bedankt: 1962 keer
Berichtdoor r2504 » 05 Feb 2015, 12:32
Tomby schreef:Care to elaborate ? AFAIK putting a client in the DMZ causes all incoming connections to be sent to that client anyway.
I don't know how TN implemented their DMZ... but I see everyone with for example a second router in the DMZ doing port forwards ?
Haven't tested it myself, so I can't confirm the requirement 100%.
komaeu
Berichtdoor komaeu » 05 Feb 2015, 12:39
They should just burn those devices ;) BBox3 is worst router I have ever seen.
Even forwarding ports(setup via www) fails and crash from time to time. Whole web interface lags a lot and freezes. Applying setting in 60% fails. This device is nightmare( I had alrady 2 different bbox3).
sirWard
Twitter: sirWard
Bedankt: 87 keer
Berichtdoor sirWard » 05 Feb 2015, 13:26
Bbox3 and Telenet? The bbox3 is a Proximus (former Belgacom) device...
You should check the manufacturer of the Bbox3 you have. There are 2 suppliers (Sagem and Technicolor), so you should check on the bbox3 who fabricated the modem. If it's a Technicolor, try to catch a Sagem Bbox3 sinds the Technicolor model is known for NAT issues with the PS4.
[EDIT] I understand your post(s) better now. If returning to Proximus or any other xDSL provider for that matter, check the manufacturer like I wrote before. Or better: ask a Sagem device and explain that you do have a PS4.
On the other hand it seems strange that you do experience NAT issues. Never had them on the PS4 when I still was a Telenet customer... All worked out of the box.
Bedankt: 2387 keer
Recent bedankt: 37 keer
Uitgedeelde bedankjes: 645 keer
Contact:
Berichtdoor philippe_d » 05 Feb 2015, 13:54
komaeu schreef:They should just burn those devices ;) BBox3 is worst router I have ever seen.
If you believe other routers do better, then just use the B-box3 (any brand) or B-box2 as a modem only, and start the PPPoE session on your own router. Then you'll have all the freedom to customise your own settings.
Modem/Router: Proximus B-box3 + Fritz!Box 7590 int, FW 07.00, met PPPoE.
wouterajoin
Berichtdoor wouterajoin » 16 Sep 2016, 22:13
I'm a ps4 gamer , playing mostly destiny. i got a new router from proximus. B-box3... when i game online i get booted a lot due to poor connection. anybody can help me?
Terug naar “Overstappen”
Wie is er online
