dmesg met de hele boot sequence van de mood:
0 (usable)
Initial ramdisk at: 0x80310000 (2347008 bytes)
On node 0 totalpages: 32768
zone(0): 32768 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram0 rw console=ttyS0,115200 usb_ohci=base:0x14020000,len:0x100000,irq:26
calculating r4koff... 00317040(3240000)
Using 324.000 MHz high precision timer.
Console: colour dummy device 80x25
Calibrating delay loop... 323.58 BogoMIPS
Memory: 121720k/131072k available (1857k kernel code, 9352k reserved, 2412k data, 112k init, 0k highmem)
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Inode cache hash table entries: 8192 (order: 4, 65536 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 8192 (order: 3, 32768 bytes)
Page-cache hash table entries: 32768 (order: 5, 131072 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
Autoconfig PCI channel 0x8030f3a8
Scanning bus 00, I/O 0x00000300:0x00100000, Mem 0x40000000:0x50000000
00:05.0 Class 0000: 104c:9065 (rev 01)
Mem at 0x40000000 [size=0x400000]
Mem at 0x40800000 [size=0x800000]
I/O at 0x00000300 [size=0x10]
Non-coherent PCI accesses enabled
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (
rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
i2c-core.o: driver i2c-dev dummy driver registered.
i2c-dev.o: Registered 'pb1550 adapter (PSC2)' as minor 0
i2c-core.o: adapter pb1550 adapter (PSC2) registered as adapter 0.
i2c-dev.o: Registered 'pb1550 adapter (PSC3)' as minor 1
i2c-core.o: adapter pb1550 adapter (PSC3) registered as adapter 1.
i2c-proc.o version 2.6.1 (20010830)
Serial driver version 1.01 (2001-02-08) with no serial options enabled
ttyS00 at 0xb1100000 (irq = 0) is a 16550
ttyS01 at 0xb1200000 (irq =
is a 16550
ttyS02 at 0xb1400000 (irq = 9) is a 16550
AMD Alchemy Au1550 RTC Driver v0.6, initialized.
Au1550 SPI driver
RAMDISK driver initialized: 16 RAM disks of 10240K size 1024 blocksize
au1000eth.c:1.4
ppopov@mvista.com
eth0: Au1x Ethernet found at 0xb0500000, irq 27
ethaddr not set in boot prom
eth0: No mac address found
eth0: Micrel KS8721b/BT 10/100 Base Tx/Fx PHY at phy address 1
ks8721m_init - phy = 1
eth0: Using Micrel KS8721b/BT 10/100 Base Tx/Fx PHY as default
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
hda: probing with STATUS(0x50) instead of ALTSTATUS(0x08)
hda: WDC WD800UE-22HCT0, ATA DISK drive
hdb: probing with STATUS(0x00) instead of ALTSTATUS(0xb0)
ide0 at 0xc0174000-0xc0174007,0xc01741c0 on irq 62
hda: attached ide-disk driver.
hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=155061/16/63, (U)DMA
Partition check:
/dev/ide/host0/bus0/target0/lun0: p1 p2 p3
ac97_codec: AC97 Audio codec, id: VIA97 (Unknown)
Au1550 psc audio: AC'97 Base/Extended ID = 6d50/0205
physmap flash device: 4000000 at 8000000
CFI: Found no phys_mapped_flash device at location zero
Mood 300 flash: probing 16-bit flash bus
ioremap(0x1fc00000, 0x00400000) = 0xbfc00000
Mood 300 flash: Found 1 x16 devices at 0x0 in 16-bit bank
Mood 300 flash: Found an alias at 0x200000 for the chip at 0x0
Amd/Fujitsu Extended Query Table at 0x0040
Mood 300 flash: JEDEC Device ID is 0xC4. Assuming broken CFI table.
Mood 300 flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Creating 5 MTD partitions on "Mood 300 flash":
0x00000000-0x00050000 : "all"
0x00000000-0x00030000 : "uboot"
0x00030000-0x00040000 : "parameters"
0x00040000-0x00050000 : "parameters-sysdef"
0x00050000-0x00200000 : "misc"
yxa: 0xec:0x76
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00400000 : "Mood 300 NAND FS 0"
0x00400000-0x04000000 : "Mood 300 NAND FS 1"
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
host/usb-ohci.c: USB OHCI at membase 0xb4020000, IRQ 26
host/usb-ohci.c: usb-builtin.OHC, non-PCI OHCI
usb.c: new USB bus registered, assigned bus number 1
usb.c: kmalloc IF 87f92300, numif 1
usb.c: new device strings: Mfr=0, Product=2, SerialNumber=1
usb.c: USB device number 1 default language ID 0x0
Product: USB OHCI Root Hub
SerialNumber: b4020000
hub.c: USB hub found
hub.c: 2 ports detected
hub.c: standalone hub
hub.c: ganged power switching
hub.c: no over-current protection
hub.c: Port indicators are not supported
hub.c: power on to power good time: 4ms
hub.c: hub controller current requirement: 0mA
hub.c: port removable status: RR
hub.c: local power source is good
hub.c: no over-current condition exists
hub.c: enabling power on all ports
usb.c: hub driver claimed interface 87f92300
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 1024 buckets, 8Kbytes
TCP: Hash tables configured (established 8192 bind 16384)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 2292k freed
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 112k freed
Algorithmics/MIPS FPU Emulator v1.5
>> dm642pci_fxn_probe called
Writing Warm Reset (WARMRESET) to HDCR
enable_irq(1) unbalanced from c017a1b8
>> PCILINK: Initializing...
>> PCILINK: Init completed!
mmbfb: Using DSP image version 4.18
mmbfb: Define DSP fb0 720x576+0+0@32
mmbfb: Define DSP fb1 720x576+0+0@8
mmbfb: Setting DSP system = PAL
mmbfb: Initializing framebuffer 0 (of 2)...
mmbfb: DSP addr: 0x8026a000
mmbfb: DSP reported size: 720x576x32
mmbfb: FB uses 1658880 bytes (line length: 2880, xres: 720, yres: 576, available: 1658880)
Console: switching to colour frame buffer device 90x36
mmbfb: Initializing framebuffer 1 (of 2)...
mmbfb: DSP addr: 0x80204000
mmbfb: DSP reported size: 720x576x8
mmbfb: FB uses 414720 bytes (line length: 720, xres: 720, yres: 576, available: 414720)
kjournald starting. Commit interval 2 seconds
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,2), internal journal
EXT3-fs: mounted filesystem with ordered data mode.
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,3), internal journal
eth0: link up
au1550_control(0x80308358, 0x00000731, 0x00000000)
i2c-algo-au1550: adapter already configured as master, ignoring request
au1550_control(0x80308358, 0x00000730, 0x00000066)
i2c-algo-au1550.o: Setting slave mode - (0x00000066)
request_irq retval == 0
DM642PCI_EMIF_GBLCTL 00 0x00000020
DM642PCI_EMIF_CECTL0 02 0xffffffd3
DM642PCI_EMIF_CECTL1 01 0x00000000
DM642PCI_EMIF_CECTL2 04 0x00000000
DM642PCI_EMIF_CECTL3 05 0x00000000
DM642PCI_EMIF_SDTIM 07 0x00000928
DM642PCI_EMIF_SDEXT 08 0x0005052d
DM642PCI_EMIF_CESEC0 18 0x00000000
DM642PCI_EMIF_CESEC1 17 0x00000000
DM642PCI_EMIF_CESEC2 20 0x00000002
DM642PCI_EMIF_CESEC3 21 0x00000073
DM642PCI_EMIF_SDCTL 06 0x47228000
Au1550 Crypto 0x20 is 3
Au1550 Crypto 0x2C is 1
Driver 'udm' loaded successfully
mmbfb: Using DSP image version 4.29
