Dit is de configuratie:
; supervisor config file
[unix_http_server]
file=/var/run/supervisor.sock ; (the path to the socket file)
chmod=0700 ; sockef file mode (default 0700)
[supervisord]
logfile=/var/log/supervisor/supervisord.log ; (main log file;default $CWD/supervisord.log)
pidfile=/var/run/supervisord.pid ; (supervisord pidfile;default supervisord.pid)
childlogdir=/var/log/supervisor ; ('AUTO' child log dir, default $TEMP)
; the below section must remain in the config file for RPC
; (supervisorctl/web interface) to work, additional interfaces may be
; added by defining them in separate rpcinterface: sections
[rpcinterface:supervisor]
supervisor.rpcinterface_factory = supervisor.rpcinterface:make_main_rpcinterface
[supervisorctl]
serverurl=unix:///var/run/supervisor.sock ; use a unix:// URL for a unix socket
[inet_http_server]
port = 127.0.0.1:9001
; The [include] section can just contain the "files" setting. This
; setting can list multiple files (separated by whitespace or
; newlines). It can also contain wildcards. The filenames are
; interpreted as relative to this file. Included files *cannot*
; include files themselves.
[include]
files = /etc/supervisor/conf.d/*.conf
Mijn commando
[program:smaem2influxdb]
command=/usr/bin/python /home/pi/smaem2influxdb.py
autorestart=true
autostart=true
stderr_logfile = /var/log/sma2eminfluxdb-stderr.log
stdout_logfile = /var/log/sma2eminfluxdb-stdout.log
er gewoon onderaan toevoegen of apart onder /conf.d/ in een aparte file steken resulteert altijd in hetzelfde :
http://localhost:9001 refused connection
Iemand enig idee?
