[phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1042: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions_str.php(1) : eval()'d code:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4688: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions_str.php(1) : eval()'d code:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4690: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions_str.php(1) : eval()'d code:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4691: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions_str.php(1) : eval()'d code:1)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4692: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions_str.php(1) : eval()'d code:1)
Toon onderwerp - IPv6 pas in 2012-2013 bij Telenet - Userbase
Forum
Internet Protocol versie 6 (IPv6) is de opvolger van Internet Protocol versie 4 (IPv4). Hier kan je over de implementatie ervan discuteren
Moderators: Moderators, Userbase Crew
Re: IPv6 pas in 2012-2013 bij Telenet
Berichtdoor krisken op 30 jan 2011, 23:40
Dat je 65536 ip's hebt :)
Internet = EDPnet "VDSL Pro" (25/10mbit profiel) + Toledo "VDSL Pro" (70/6mbit profiel)
Telefonie = WeePee (inkomend) + Internetcalls (uitgaand) via freePBX
GSM = Proximus Smart20 + Mobile Vikings
Tablet = Proximus GC
TV = Telenet Analoog
Netwerk = 2x Routerboard RB-2011L-RM + Meraki MR12 Wifi. Full gigabit network.
Avatar gebruiker
offlinekrisken
Geregistreerd: 07 nov 2006, 12:11
Woonplaats: Merelbeke - 91GBR0
127 24
Berichtdoor r2504 op 30 jan 2011, 23:42
Hoe kom je daar aan... volgens mij is (128 - 48) ^ 2 heel wat meer dan 65536.
Edit... Krisken is juist... IPv6 heeft een /64 prefix... dus het is (128 - 64 - 48) ^ 2 ... en da's inderdaad 65536.
offliner2504
Geregistreerd: 28 okt 2003, 09:17
510 168
Berichtdoor philippe_d op 31 jan 2011, 14:18
Ik zal het maar niet narekenen en de experts geloven ....
Maar is dat ook geen verspilling ?
Ik vraag één IPv6 adres aan voor mijn thuisnetwerkje, krijg een subnet (2001:6f8:xxxx::/48) en dit blijkt dan 65.536 IP adressen te zijn. Ik kan hiermee niet alleen mijn straat, maar gans mijn dorp (sorry "Stad" sedert 2000 :wink: ) van IP adressen voorzien. Blijkbaar is IPv6 inderdaad onuitputtelijk ?
Philippe.
VoIP: WeePee (vaste nummers geporteerd), Sipgate.de, Sipgate.co.uk, PoivY, FreeVoipDeal (uitgaand België mobiel 0.5ct/min).
Provider: Belgacom "Generation" (50/4 mbps down/up).
Modem/Router: Fritz!Box 7390, FW 84.05.50 VDSL2 Annex B, sync 70/6. IPv6 SIXXS Tunnel.
offlinephilippe_d
Geregistreerd: 28 apr 2008, 10:22
Woonplaats: Waregem
596 39
Berichtdoor r2504 op 31 jan 2011, 14:25
Aangezien IPv6 in princiepe geen NAT meer kent kom je tot dergelijke dingen.
Nu met 128 ^ 2 adressen mag je al serieus wat verspillen.
offliner2504
510 168
Berichtdoor krisken op 31 jan 2011, 14:43
philippe_d schreef:Ik zal het maar niet narekenen en de experts geloven ....
Philippe.
Zin om even hoofdpijn te krijgen Philippe? :-) Reken maar eens mee dan :
An IPv6 /32 is 2^16 (65536) /48 subnets, which in turn are each 2^16 /64 subnets. A /64 is 2^64 addresses, the square of the size of the entire IPv4 Internet. It took me a while to find a calculator that would actually give the expanded result – 18,446,744,073,709,552,000.
I have looked into different IPv6 subnet lengths but because ARIN wants to assign /32s to ISPs and wants the ISP to allocate out a /48 per customer it hasn’t been a pressing issue as of yet.
Avatar gebruiker
offlinekrisken
127 24
Berichtdoor whorre op 09 feb 2011, 13:54
Even voor de duidelijkheid: een /48 zijn wel degelijk 2 ^ 80 (en dus niet 80^2 of 2^16) IPv6 adressen. Het is correct dat er nooit subnets van kleiner dan /64 worden gemaakt. De reden hiervoor: in IPv6 zijn de eerste 64 bits de 'network identifier' en de laatste 64 bits de 'host identifier'. Een netwerk is dus altijd een /64. Dit maakt onder andere stateless autoconfiguration mogelijk.
Als je dus van sixxs een /48 krijgt, dan kan je zelf nog 2 ^ (64-48) = 2 ^ 16 = 65536 netwerken definiëren met daarin telkens 2^64 IPv6-adressen. In een typisch thuisnetwerk gebruik je daar momenteel maar een netwerk van. Bedenk echter dat je in de toekomst misschien ook een netwerk wil definiëren voor al je huishoudtoestellen of voor al je mediatoestellen, etc.
Waarom deelt men dan nu geen kleinere blokken uit, men kan daarna toch extra blokken bijgeven? Dat klopt, maar dan krijg je een versnippering van de adresruimte, wat de routeringstabellen een stuk groter en minder efficiënt maakt. Stel je voor dat er adressen met dezelfde postcode over verschillende gemeenten in het ganse land verspreid zouden zitten, dat zou voor de post ook niet meer werkbaar zijn.
Om alles een beetje in perspectief te plaatsen: een /48 is een 65536 maal kleiner deel van de IPv6-koek dan 1 IPv4 adres van de IPv4-koek. ISPs krijgen typisch één (of enkele) /32. Verhoudingsgewijs te vergelijken met 1 (of enkele) IPv4 adres(sen). Bovendien wordt momenteel op het hoogste niveau nog maar een beperkt deel van de koek uitgedeeld. De (global unicast) adressen die nu uitgedeeld worden zijn in de range 2000::/3. Als blijkt dat men te gul is geweest, kan men nog een aantal keer herbeginnen en dan kleinere blokken uitdelen (4000::/3, 6000::/3, 8000::/3, A000::/3 en C000::/3 zijn ook nog bedoeld voor global unicast).
Het is ook nog niet zeker of de ISPs een /48 aan elke klant gaan geven. Waarschijnlijk wel aan hun zakelijke klanten, maar het zou kunnen dat residentiële klanten een /60 of zelfs een /64 zullen krijgen.
offlinewhorre
Geregistreerd: 20 jan 2011, 10:21
2 0
Berichtdoor r2504 op 24 apr 2012, 13:22
Daarnet nog gevonden op http://klantenservice.telenet.be/conten ... n-met-ipv6 ... staat wel in de initiele post, maar bij deze dus ook een link naar hun support pagina's.
Wanneer zal Telenet starten met IPv6?
Naar verwachting zal Telenet rond 2012 - 2013 geleidelijk aan IPv6 introduceren, naast het bestaande IPv4-adres. Alle Telenet-internetklanten krijgen dan én een IPv4- én een IPv6-adres. Wanneer uiteindelijk iedereen een IPv6-adres heeft, zal het IPv4-internet stilaan uitdoven. Dit is een proces dat jaren in beslag kan nemen.
Telenet biedt de garantie dat zijn klanten de volgende jaren gebruik kunnen blijven maken van IPv4 ondersteunde diensten.
offliner2504
510 168
Berichtdoor Trojan op 24 apr 2012, 17:43
Één ipv6 adres of een /64 zoals het IANA voorziet?
Avatar gebruiker
offlineTrojan
Geregistreerd: 13 aug 2009, 20:10
Woonplaats: Kontich
104 41
Berichtdoor lithion op 24 apr 2012, 19:00
Of een /56?
offlinelithion
Geregistreerd: 21 aug 2006, 12:02
10 4
Berichtdoor Trojan op 24 apr 2012, 19:17
Dan zie ik het liever groots, een /48!
Avatar gebruiker
offlineTrojan
Woonplaats: Kontich
104 41
Berichtdoor krisken op 24 apr 2012, 19:19
Een /48? Jij wilt zeker iedere mier in je tuin een eigen IP geven? :D
Avatar gebruiker
offlinekrisken
127 24
Berichtdoor lithion op 24 apr 2012, 20:07
pakt dan een /32. Kan je ieder stofdeeltje een ip adres geven.
offlinelithion
10 4
Berichtdoor depeje op 24 apr 2012, 20:11
Dan moet je roomba maar een traceroute doen om te weten waar die moet gaan vegen.
Avatar gebruiker
offlinedepeje
Geregistreerd: 22 jan 2011, 00:27
Woonplaats: Herent
21 3
Berichtdoor lithion op 24 apr 2012, 20:16
LOL
offlinelithion
10 4
Vorige
Keer terug naar Internet Protocol versie 6 (Ipv6)
Gebruikers op dit forum: Geen geregistreerde gebruikers. en 0 gasten
